hp estimate Please!!!!!!!
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: automatic
with the setup gong in my 89, i want to know what sort of power will be puttin out
350 bored 0.030 over
10.5:1 compression
vortec heads
.525 int. exh rollercam
1 7/8 inch long tube headers
edlebrock tunnel ram intake
2- 400 cfm 4 barrel carbs
MSD distributor
MSD Blaster coil
MSD Wires
bosch 4 plugs
around what should i be expecting
10.5:1 compression
vortec heads
MSD distributor
MSD Blaster coil
MSD Wires
bosch 4 plugs
Transmission: 4L80E/4L80E
Need more data on the cam.
Unless that cam has about 250 degrees duration @ .050", you're going to have about a 1000 RPM powerband.
Car: 4
Engine: 6
Transmission: 5
If that's the LT4 HOT cam, you'll get alot more useful power and speed out of a single 750 carb and a Perf RPM, with a whole lot less trouble and gasoline expense if you drive it on the street.
Also, I'd hate to even think about putting 1-7/8" headers on a SBC with the stock flange. AFAIK they'd about have to be a Stahl flange, or they'd have to be severely dimpled around the bolts. For a 350 with a 220 degree cam like that one, you don't need that sort of thing. 1-3/4" ones will work just fine, in fact might even make the car faster than the larger ones.
The ignition stuff is irrelevant. Don't bother including it in your HP estimate. You could stick a stock HEI and regular AC plugs on there and get the same results, if it all works right and has the right timing curve for the rest of the motor.
With the combo I gave you, you should get about 400-420 HP peak, with a good wide torque band, within 10-15% from about 2500 to about 5000 RPM. With the tunnel ram, you'll have no torque at all below 3500 RPM or so, and about the same peak HP. I'd guess it would probably give up .4 in the 1320 compared to the RPM.
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
Yes don't go tunnel ram. Those are for motors turning like 8500 or more rpm. I have about 350-375 RWHP, who really knows and who cares, getting it to the ground is what counts. I don't really know what the numbers are on my setup, except the track numbers. See below... PM me if you have any questions on my setup I will be happy to tell you about it.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Huh? Last time I checked, there was no tunnel ram that worked with Vortec heads!
Better be sure, if you do want to try that. Vortec heads are different from standard SBC heads.
