Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
Honda vs me
Old Nov 14, 2004 | 10:14 AM
custom88camaro's Avatar
Car: 88 camaro
Engine: carby 350
Transmission: t-5 from v6 car
Honda vs me
I was at a stoplight on my way out for a real drag race, and a friend of mine pulled up next to me in a civic. It isn't stock but not highly modded either. His only real power builder is "Squeeze". So the light turns green, and I take off sorta hard, and he takes off a little harder, so I get into the gas a little more. I am just into the secondaries in carb, only giving it enough gas to stay ahead. I shift to second ( at about 5500, I usually shift at 6900) and just give it enough to stay ahead. He has a look on his face like he can't believe he is keepin up with me, so I punch it and my tires start spinning. I slowed so he could catch up, and the look on his face was PRICELESS.
Old Nov 14, 2004 | 12:02 PM
megaracerx's Avatar
nicw kill...but wtf is "squeeze"?
Old Nov 14, 2004 | 12:11 PM
patRIOTik's Avatar
Car: 1986 Chevy Camaro Z28
Engine: 4BBL 350
word.
Old Nov 14, 2004 | 12:31 PM
stu
Guest
Posts: n/a
It's nitrous.
What kind of times do you run? And what shot is he running?
Old Nov 14, 2004 | 06:52 PM
Car: 88 camaro
Engine: carby 350
Sorry guys, I was at work. He has a 75 shot, but he didn't use it. I call it "Squeeze" because I hate hate hate hate it when people call it "NAWS". It drives me nucking futs. It was cool that we got to race a bit though, because the drag I was on my way out to (Against a 70-something nova) didn't happen because too many people followed us out. What happens when 15 loud cars head out of the cruise strip all at once??? The five-o follows.
Edit: Spelling
Old Nov 14, 2004 | 06:55 PM
Car: 88 camaro
Engine: carby 350
BTW, Stu, I knew you would jump on this one. I haven't had my car to the strip, and my mods are a long list.
Old Nov 14, 2004 | 07:06 PM
stu
Guest
Posts: n/a
From the sound of the story, it sounds like he'd give you a run, if not beat you if he used the nitrous. Am I reading this wrong?
Old Nov 14, 2004 | 07:16 PM
Car: 88 camaro
Engine: carby 350
Yes.
I really don't think his car would have a chance against mine even with the juice. Not enough horsepower, and his car doesn't even hook as good as mine. Granted he weighs a lot less, I probably have almost twice his HP even on bottle.
According to Dyno 2000(not sure how accurate)my engine makes 509 at 6500. It makes over 400 from 4700 to 7000. That is why I shift at 6900 or so.
Old Nov 14, 2004 | 07:23 PM
stu
Guest
Posts: n/a
Oh never mind then. I must have read wrong, I was thinking that you were pacing him at like 3/4 throttle. You are right, 500hp is no match of a stock Honda on a 75 shot.
Old Nov 14, 2004 | 08:42 PM
Car: 88 camaro
Engine: carby 350
Realistically, prob only about 450-475 fwhp. I don't think Dyno 2000 is as accurate as I would like it to be. It doesn't let you factor in rod length, air temp or elevation. It doesn't even let you put in real flow numbers for benched heads.
Old Nov 14, 2004 | 09:14 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
Whats your setup out of curiosity?
Old Nov 14, 2004 | 09:35 PM
Car: 88 camaro
Engine: carby 350
SHHHHHHH It's a secret!
I don't usually just blab it off to anybody, but this is the internet, so........
88 Camaro
355 ci SBC
Hyperuetectic cast flat tops
Stock crank/rods
4 bolt main 010 block
.030 over Torque Plated
Plasma rings
Dart IE heads
---230cc intake runner
---2.08/1.65 valves
---64cc chambers
---1.44 dual valve springs
Crane Gold 1.5 rockers (full roller)
Comp xr280r solid roller cam
---242*/248* @.050
---.570/.576 lift
Edelbrock Victor Jr. (short)
Edelbrock perf series 750 cfm carb
14x3 K&N open element
---(CAI in the works)
Hedman shorties/ Y pipe
---Y pipe has been converted to 3" at Y
Off road pipe (NO CAT)
Flowmaster 3" mandrel bend CATBACK (SINGLE)
Electric fan
B/W T-5
---B&M Short throw shifter
3.42 posi rear (disc)
Eibach Pro Kit
KYB GR-2's all around
Need some LCA Relocation brackets
Want some Nitto 555R's
Old Nov 14, 2004 | 09:42 PM
Car: 88 camaro
Engine: carby 350
Didn't I say the list was long?
Old Nov 14, 2004 | 10:38 PM
Nice setup, how much compression you running?
Old Nov 14, 2004 | 11:35 PM
Car: 88 camaro
Engine: carby 350
I have never checked static compression. (PSI) I think the ratio is about 10.25:1, but I am not sure. 64cc head with flat tops 4 valve reliefs. I think that is similar to say----78 corvette. Should be somewhere around 10:1.
Old Nov 15, 2004 | 01:05 AM
TexasLT1's Avatar
Car: '92 RS
just out of curiousity, why did you go with 230cc heads? those are usually reserved for big inch small blocks
Old Nov 15, 2004 | 02:49 PM
Car: 88 camaro
Engine: carby 350
doh
When I saw the heads on ebay brand new assembled for under 800, I just ordered them without thinking. I talked to a few people later, and they were like "Holy Crap, they are how big????" So I didn't realize how big they were until they were on the way. I decided to put them on anyway, they work well, but you really have to rev it to get the power. I plan on building a 406 later, so they will be good when that time rolls around.
ALIENhumanoid
Members Camaros
80
Apr 23, 2016 11:35 PM
InfinityShade
Aug 22, 2015 08:00 PM
TriGenRS
Nov 22, 2001 09:46 PM
Brent Swan
Oct 31, 2001 07:59 AM
Camarocks
Jan 28, 2001 01:27 PM
