Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
How much power/1/4 mile times?
Old Dec 17, 2004 | 11:32 AM
badbird1984's Avatar
Im looking into buying this car and I was just wondering what I could expect out of this engine? Its got a 700R4 with a 2000 RPM converter and a shift kit. Not sure of the rear end gears.
'87 L98 steel crank shaft; pink rods; flat top pistons rotating assembly has been balanced; fluidampr harmonic damper; 1.94 intake and 1.50 exhaust; stainless steel valves; screw in studs; guide plates; 1.5 roller rockerarms; 24 lb. fuel injectors; rebuilt distributor; hypertech computer chip
Old Dec 17, 2004 | 11:50 AM
/\/3\/\/l8l3's Avatar
i'd figure mid low 13's
Old Dec 17, 2004 | 02:03 PM
ljnowell's Avatar
Hard to tell, if its basically stock heads with screw in studs, stock cam and a hypertech chip, it could be mid 14's or worse. Without cam specs or HP improving mods to the heads, its a blind guessing game, like playing pin the tail on the donkey. Off the shelf chips suck too, the only way to go is a custom burnt chip.
Old Dec 17, 2004 | 04:00 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
i have run 14.02 with full exhaust/header, CAI, and 2800 stall on 2.77 gears and worn out street tires. i should have high 13.9's on it as it sits now, and with 3.27's and new tires, i should hit 13.8's i am hoping for. i feel that the car has it in it.
2000rpm converter isnt going to help as much over stock. get atleast a 2400rpm-2800rpm converter. it will open that car up LOL
Old Dec 17, 2004 | 04:22 PM
Thanks guys!
Old Dec 17, 2004 | 07:28 PM
Steve86TA's Avatar
Car: To many to list
From a mostly stock motor?I would agree with ljnowell,mid-low 14's.
Old Dec 18, 2004 | 12:53 AM
gary sanders's Avatar
Car: 89 trans am GTA,90 model trans am 350 tuneport,87 firebird
Engine: 355 small block
Transmission: 5 speed,auto 700r4
7 years ago,when i bought my 90 tuneport ,it ran 13.78,with almost the same mods,it was a 277 gear,had drag tires to do this.
Old Dec 18, 2004 | 10:26 AM
CHEVY_EATER's Avatar
Car: 93 Mustang GT
Engine: 5.0
14's..
Old Jan 3, 2005 | 11:13 PM
nick418's Avatar
Engine: L98, Hemi 6.2
low 14s is my guess
Old Jan 3, 2005 | 11:47 PM
phoenix305's Avatar
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
i don't see why you would go through the heads like that and not up grade the cam. Basically the only thing there givining you a horsepower gain is the roller rockers (and maybe the chip, but it could also be hurting the performance). But there is one good thing to be said about it, it's an awfully good starting point.
Old Jan 4, 2005 | 12:35 PM
Project's Avatar
Car: 85 Camaro Z28
Transmission: 700-R4
i think it is 13second material
Old Jan 4, 2005 | 07:21 PM
ljnowell's Avatar
There is nothing there greater than stock. A rebuilt ditributor doesnt add power, its still got stock sized valves, no porting. Screw in studs dont do anything. Hypertech chip is next to worthless. The roller rockers may help, because the stock ones suck so bad. With a stock cam, its not going to do much more than a stock car would.
Old Jan 4, 2005 | 07:36 PM
Steve86TA's Avatar
Exactly.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Andrew6.688
Dec 13, 2015 10:59 AM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
jharrison5
Aug 19, 2015 05:53 PM
