how fast is ur thirdgen
Car: 1992 rs 355 TBI **swapped**
Engine: 80 Ford Fiesta GHIA dual carb
Transmission: 72 Cutlass S 350/350 3.42
Axle/Gears: s10 tq converter/stock rear gear
what type of body and suspeneion modifications will be required to approach the 200 mph barier given that my motor can push the hp to attain those speeds. I've heard that the body isnt much for stability past like 155, but can be lowered and run safely to near 180. Does anyone here have any experience when it comes to reaching these speeds? I'm not looking for like bonneville style mods, I just wanna know what'd it'd take to make a street car run nascar speeds.
DO I have the power? I run a balanced 355, that is torque biased, and strapped with a 125 hp nitrous hit. Its good for 13.2's at the track on the bottle, but I think it will need forged pistons before I get to punchy with the nitrous on the highway.
Also, is there any way to eliminate kickdown on a 700r4? I mean even with the modified valving my car will kick back into third if I FLOOR it.... but I want to be able to give it all the gas I can. Kicking into 3rd evan at the 115 limiter is bad enough, *** help me if I was clocking a buck55.
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
I am by no means an aerodynamic expert on the thirdgen, but I'd think a body pan would help @ those speeds.
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
Axle/Gears: Limited 9 bolt, 3.45
it would help but a 180 i dont think it would be super bad the right tires, a decent motor, if you have a camaro just turn the intake into a real ram air, put on headlight covers, a decent shaft, and nitrous would help. Remove the governor/chip I know mine shuts off at 145. and your set, a manual tranny is a help
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
ive hit 160 in my iroc before,
i cant help it i go to a deserted road every time i take it out of the garage and top out 5th gear which is 155
i dont know who is saying our cars are not very aerodynamic but in stock form are rated for 300mph without any modification
our drag co efficent is .34 which is so low.
and to hit 200 which is my goal you need to re do the entire suspension 15yo suspension is not good doing those speeds, so sub frame connectors all new joints/bushings/ ends stiff springs and shocks
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
my car can go mach .0000000000000000000000000001 i think... lol havent you heard.... our cars can go 300mph stock and the corvettes can sustain warp speed stock....*sigh* i had to
Car: 88 Trans-Am 305 TPI, Yokahama dbs s2 front/ avs ES100 rear, Shift kit, K&N, complete 4th gen rear end, sun roof, 80's pinstripping, 4 point harnesses, memphis car audio
my aircraft grade lead fenders start to melt at 400 MPH.....not to mention the mass amount of june bugs i hit, and the wind messes up my hair.
Car: 86 trans am
Engine: 370
Transmission: TH350 W/A STALL
best first time out was 109 in the 1/4. un-tuned, crapy exhaust system, ****ty intake set up, poor burn out, no clue on shift points, slight miss off the line and all in all a bad run...
Engine: 5.7tpi 350,
i hope your kidding that to me sounds a little R I C E Y
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
took this from video,
http://www.transamws6.com/video/130mph.wmv
this was with my stock 305TPI Auto.
At the track, it ran a 15.2 @ 90mph.
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
you guys do know that speedo stops working around the MPH area. my stock tpi 305 found that out (years and years ago) hit the brakes and just as my speedo hit 90 mph a cop came up a side road and clocked me got a ticket for that one
Car: 1986 Trans Am
Engine: carb 305 LG4
Transmission: TH700-R4
If a tree falls in the forest and no one is around does it make any noise?
If a vette goes 140mph or does a burnout and no one is around, does it make any noise?
Just because you don't see it doesn't mean it doesn't happen. go to the track if you want to see vette drivers get on it.
~Matt
~Matt
My 89 2.8L Got up to 120 at virtually full throtle. I know running at as high of RPM as I did is bad for the car but I had to test it out. I haven't tested my new 5.7L yet. Still waiting for an open track day.
It was at just under 5K, but I ran it like that for just under a mile
Note: the car had 200K + miles, and I was in the process of getting a replacement so I wasn't to worried about it. I'm surprised it was able to do what it did.
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
i used to have a 88 beretta with the 2.8, got it up to 110 daily with now problem, havn't had time to really test out my camaro, hits 100 easily though.
Car: 1992 Z28 (Heritage Edition)
Well the fastest i've gone in my camaro is about 103. I am real ***** when it comes to my car. Generally speaking i dont drive it more than 55 on regular roads and 70 on highways. The only reason i took it up to 103 was because i had just gotten it and i wanted to see how it pulled up there. I made a pass on the road just to make sure there were no cops before i did it.
Thats what i'm worried about, cops. If i'm gonna go be reckless and risk tickets i'll do it when i pay for my own insurance. Right now my parents pay for my insurance and thats a ****load for a 16 year old driving a sportscar. I'm not gona make them pay anymore (hopefully).
On a similar note, instead of driving really fast, i tend to have fun w/ my car with its handling...which is superb, might i add!!
Car: 2001 Camaro SS
i am sort of the same way.....all my friends want me to do burnouts and doughnuts all day, but their not the ones that had to maintain a good GPA in order to get the car....getting a speeding ticket would get my car taken away...but....not saying i havent dont those things before
...ive taken mine about 110 on the freeway once..not a bad experience...quiet a rush i might say. but yes im the same way mack. the car handles great and its fun to see what it can do around "round-a-bouts" and all those things, but dont do stupid stuff that would make ur parents ever think about taking ur car away..my cars my baby, i would be crushed if my parents took it away
Car: 1991 Camaro RS
Engine: 357cid
Originally posted by a mack6
Yea man, i know exactly how you feel. My car is my baby too.
Originally posted by Saigon_Bob
tru tru.. what u need to do is baby that heritage edition and buy another to have fun with.... oh yea, look for subdivisions that are under construction. they can be very very fun at night
What do you mean subdivisions, like highways that are being built? They're making this bigass bypass by my house and its done i think they're just paintin the lines or something, your not supposed to go in there but i guess you could if you wanted to...is that what your talking about???
Car: 91 Camaro RS
Engine: 305 TBI
a mack6,
Taking it up to speed is fun, but that kind of responsibility you have to not make someone else pay for your mistakes will really get you far in life.
thanks man...its nice to know i got something good 2 look foward to in my future...
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
Buried the needle so far it seemed like forever till it started to read again. Now I go to the track and blow my car up 1/4 mile at a time
Car: 1991 Camaro RS
Engine: 357cid
LOL i guess it must be a locational thing.. here in FL a subdivision is what we call the suburbs... they are small, usually walled in, neighborhoods. when they are still being built there are no houses but the roads are there, and empty. drift practice.. lol
ohh...now i know what you mean. Can't say there are too many of those around here. To make up for it though, we got some beautiful country roads out here that wind for miles and miles through like rural areas. Its heaven on earth. I love taking my car down those roads.
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Originally posted by PETE
pic of the most recent casualty
I've taken my 4th gen up to 140 once, 130 a few times. feels like it's glued to the ground and it's still pulling pretty hard. Wouldn't be hard to hit it's factory top speed of 155. I'd hope to hit 157 with my mods.
Engine: 5.7tpi 350,
Originally posted by urbanhunter44
that head gasket will buff right out! good as new!
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
going back to what i was saying about the faster my car is, the less i speed.....
since ive been daily driving the LS1 car the last month, i touched 100mph twice.... once was just a floor it to pass and held it for a couple seconds, realized how fast i was going, and let off..... the other was on a on ramp...... same thing though, accelerated up the ramp (this is the start of the hwy, no traffic anywhere)glanced down, and realized my speedo was pegged... 40 to 115+ time is only a couple seconds now.. lol.
Car: '72 Chevy Nova
Transmission: TH350
i have ****ty gears!
but once i stick 373s in there i don't think i will have much of a top speed anymore.
Car: 89 20th Ann. TA
Engine: Turbo 3.8 V6
Transmission: 200 4R
Know what you mean about the needle taking forever to come back and start reading. Took awhile for mine to read again after staying into it
Car: 1989 TTA #1240
Transmission: 2004r
That caualty was 3 minutes after going to the gas station. I was tuned on 93 (17psi) put $7 in the tank. Retarded teenager put 87 in drove a 2 miles down the road got into boost and that's all it took!
3rd time changing hg's I'm getting pretty good at it
Gonna get her tuned this time and that's all she wrote, I'll be looking for an older muscle car as my next project.....
Car: 89 formula 350
Engine: 5.7 tpi
iv had my 89 formula up to 150mph be for my rebuild just got it back a little wail ago and i can shift it in to overdrive at 130mph. we think the top end should hit 170mph but havent had enogh time or road to try.
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
if ive got a lil bit over 200k miles on it, and i can still abuse the heck out of it, u thynk it would be able to hit pretty high in the mph witout too much damage.
Car: 90 firebird
Engine: 4BBL L98 350
Transmission: WC T5
I ran a wrx sti on the freeway today the bov was loud as hell and it had a big fart pipe on it I dont know how fast I was going It didnt mater all I was concerned with was stomping the crap out of another ***** I ran it up to 5400rpm in 5th with a .63overdrive and 4.11 rear gears i pulled really hard on the wrx. another one bites the dust
Car: 1991 Trans Am GTA
Engine: 355
Transmission: 4L60
Axle/Gears: 4th gen 10 bolt 3.42 posi
my gta's speedo was off. the higher it went the farther off it was.48 was 55 and 65 was 75 and so. i saw it get to 138 so you guys do the math. i've had my subaru svx to 145.
Terrell351
Jun 13, 2021 01:13 PM
Fast355
Dec 2, 2016 06:33 PM
So still don't know what it will do.
