Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
Which is faster?
Old Mar 29, 2005 | 10:05 PM
MMroc86's Avatar
Car: 1986 IROC-Z28 & 1987 GTA
Engine: 305 TPI & 350 TPI
Which is faster?
Just wondering, how did the 85-90 tpi 5.0 305's fare against the 5.0 Mustangs?
Does anyone one the specs on the mustangs?
Old Mar 29, 2005 | 10:48 PM
25thmustang's Avatar
Car: Mustang
Engine: Bolt Ons
Transmission: Stock
Hmmm specs on Mustangs, I think some guys on here might know...
I will say this, it all depends. A 5.0 GT vert with an auto and junk gears is a mid 15 second car, and pretty much any TPI is as fast if no faster. A 5.0 notch with a stick and 3.08 gears will pretty much walk any TPI car, even the 5-speeds. Heres my guess on the cars...
TPI auto: 14.9-15.4
TPI stick: 14.6-15.1
Mustang auto: 14.9-15.4
Mustang stick: 14.2-14.8
Its all about the car, mods, drivers, tune, etc...
Old Mar 29, 2005 | 11:04 PM
phoenix305's Avatar
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
thats pretty close though.
Old Mar 29, 2005 | 11:39 PM
Mike-in-Orange's Avatar
Car: 1992 Camaro RS
Engine: 3.1L
Originally posted by 25thmustang
TPI auto: 14.9-15.4
Those times fit right in with what I've witnessed at the track - nice to see people not trying to blow smoke about performance!
And that last line is so right on, and so often overlooked (which continues to amaze me!). A fast car in the hands of a slow driver is no longer a fast car!!
Old Mar 30, 2005 | 12:20 AM
Whitels1's Avatar
Car: 99 Z28
Engine: ls1
Transmission: A4
Axle/Gears: 3:42
I dunno guys I have a 1989 iroc 305TPI. Since I bought it i gave it a full tune up, fixed vacuum leaks etc. and I have had it to the track twice 7 runs all together, fully stock other than the shift kit, best time was 16.26@82mph...2.275 60'. Guess I got a slow roc
Old Mar 30, 2005 | 07:17 AM
WaOnFiRe's Avatar
Car: 1988 Pontiac Firebird Formula 350
Engine: 5.7L
Transmission: Automatic 4 speeds
Axle/Gears: 2.77
Something is wrong, you should be in the 15s...
Old Mar 30, 2005 | 08:42 AM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
My old 87 t/a has a 305 tpi and 700r4 with a couple of free mods and a flowmaster cat back,nothing big and it ran 15.1.
Old Mar 30, 2005 | 10:59 AM
Car: Mustang
Engine: Bolt Ons
Transmission: Stock
Again my times listed assume a perfect tune and a good running motor. They also are times you will see at sea level. Factor higher elevation, worse track prep and temps, bad tune, old age, bad driver, there are so many variables... I would say that 16.2 shows there is something wrong, or your at a higher elevation. There are going to be cars that fall out of those numbers, thats life, these are just what the times should be around under decent conditions, and the car in the right tune!
Old Mar 30, 2005 | 11:40 AM
freestylzz's Avatar
Car: 1987 Iroc Z28
Engine: The KING of the 3rd gen TPI's.
Transmission: Beefed up T5
Axle/Gears: Aussie 3.45's
Key word is "best" time. Wonder what the other times were. Could be something restrictive you got there. I'd check everything from the rad back. You may have replaced a part that is restrictive, or have something causing a restrictive problem. Stock and new you should be running a mid 15.
But hey, if you can't go fast at least you can look good cruising
Old Mar 31, 2005 | 09:08 PM
Coult_91's Avatar
Car: 91firebird, 2000 camaro
Engine: 305 tbi,K&N, edelbrock intake & 3.8
Their pretty close but the mustang got you by a bit.....
Old Mar 31, 2005 | 09:32 PM
blacksheep-1's Avatar
Car: 83 Z28
Engine: vortec 305 for now
Transmission: 5 speed
put a gate job on 'im, it's just street racing it's not like you're gonna get a red light or anything.
no green
Mar 3, 2016 05:19 PM
toones
Jan 6, 2016 06:00 PM
Thirdgen89GTA
Oct 19, 2015 09:27 AM
Americanmouse
Sep 7, 2015 12:10 PM
luvofjah
Aftermarket Vendor Review
Aug 31, 2015 11:22 AM
