Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
Fast as it should be?
Old May 20, 2005 | 11:32 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
I know some of U guys have these computer programs that U can enter all the info about a car and it gives a readout of what U should be running in a 1/4 mile--rpm's--torque--ETC. Could one of U put my info in and see what I should be running--I am real curious about whether my stuff (such as it is at the moment) is living up to it's full potenal.Let me know if U need any other info!
Thanks in advance!
Craig
Bottom end OEM stock--balanced + blueprinted--ARP bolts
OEM L98 iron heads, port, polish, CC, 3 angle--Comp Cam springs
K+N Air Filters--gutted air box--air pump and egr delete
Bosch modified MAF sensor
TPIS mini-ram w/edelbrock 52mm throttle body, SVO 24#inj.
TPIS ZZ9 cam (lift .520 ex/.484 in-- dur. 282 ex/270 in)
Comp Cam Pro Mag steel 1.52 roller rockers
Hooker shorty headers--3" Flowmaster to rear bumper (cat gutted)
MSD #8366 dist.--MSD #8226 coil--MSD 6A ignition box
MSD 8.5 Super conducter wires--R+M plug wire loom
Custom burned chip
MDB SFI 18.1 harmonic fluid dampner
Randy Petty custom built 2 row alum. rad. w/dual Flexalite fans
Perma Cool remote oil cooler
ATI convertor--700R4 transmission reworked/manual valve body
B+M Megashifter, Perma Cool external tranny cooler, alum. pan
Auto Meter Sport Comp 5" Monster Tach w/shift light
Auto Meter triple piller pod--water, oil, tranny temp. gauges
TPIS Aluminum drive shaft
10 bolt rear end/4.10 posi
4 wheel disc brakes--Drilled/Slotted rotors--Hawk brake pads
Earl's stainless steel brake lines
Kenny Brown Sub Frame Connecter's
Edelbrock 4 point strut tower brace
Eibach Pro springs/1" drop--F+R
KYB AGX adj. Shocks and Struts with Spohn upper strut mounts
Jeff Valez custom T6 billet aluminum adj. panhard bar
Jeff Valez custom T6 billet aluminum adj. lower control arms
Spohn LCA relocation brackets
Spohn 4140 chrome molly solid sway bars--1 5/16" Front/1" Rear
Spohn #301 adj. torque arm with front driveshaft loop
Alpine stereo w/remote
Budnik 17" polished aluminum wheels
Goodyear F1 GS-D3‘s--255/40ZR/17 F--275/40ZR/17 R
Nittos DOT's for strip--P245/50R16 96V
‘91/’92 OEM type Aero rear spoiler
Glasstek 4”cowl induction fiberglass hood
Old May 20, 2005 | 02:51 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
heres my take on the situation... 700r4 with 4.10s is alot of gear. first will flash by very quickly. although miniram loves high rpms, that cam and i assume your heads wont provide the flow needed to support the mini up to the needed rpms. i would think a bigger cam and better flowing heads would provide a higher powerband suitable for those gears.
either way the car should be making enough power to go mid 13's to low 13's if you have the suspension. trap speeds probly in the 100-104mph range. those gears might actually be hurting your performance tho. i think 3.73's is all higher i would run but i am not 100% sure.
edit... i dont see a torque converter. a good 2600-2800 stall would really open things up on launch.
Old May 20, 2005 | 03:21 PM
TexasLT1's Avatar
Car: '92 RS
its slow
Old May 20, 2005 | 04:56 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Well I am running best (before I got new chip last weekend) time of 8.56 and several 8.59's in the 1/8th--using the 1.56 multiplication factor for a 1/4 that shows 13.3's/13.4's.
Yes, I agree that heads and more cam (coming--probably AFR 195's ???--raw casting and let my machine shop set them up!) would be better.
Right now I'm trapping at about 5200/5300 in a 1/4 (shifting at 5800 to 6000 for 1-2 and about 5700/5800 for 2/3
The TC is not listed (my mistake sorry) it's a TCI, that was in the car from previous owner--it is a very mild one--TCI said about 2000/2200.
Mainly I was interested in, if what I have now, was doing it's job or if I was leaving anything on the table. It sounds like your estimates are based on experiance (which I have more faith in since i am old school OR like some people say--JUST OLD--53), but I was just wondering what one of the computer programs like I described says I should be running.
Thanks for your response/input!
Craig
Old May 20, 2005 | 05:03 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Originally posted by TexasLT1
its slow
Let me get the heads--1.6RR's--long tube headers--and i'll spank U like I did........ well U know!!!
Old May 21, 2005 | 12:17 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
8.56's arent too bad at all for that. thats low 13's like you said. Whats your trap speed mph in the 1/8? that could tell alittle on how much power you got and if your using it all. also, whats your 60 foot times? get them as low as you can get them and it will ring out the quickest ET's possible from your combo.
i am not too familar with 1/8 mile times and trap speeds, but i am doing 8.80s at 77mph and finishing the 1/4 in the 13.8's at 96.6mph so far. only ran her 4 times so i got more to get out of it for sure. my 60 foots are in the high 1.8's on street tires so thats why i am in the 13's but trapping only 96mph.
Old May 21, 2005 | 08:03 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Best times at beginning of sig.--see below!
InfernalVortex
Apr 20, 2021 11:31 AM
grngryoutmyway
Oct 18, 2016 05:48 PM
sreZ28
Oct 22, 2015 08:21 AM
Nervous2
Oct 8, 2015 10:53 PM
customblackbird
Oct 1, 2015 04:30 PM
