Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
new race: 96 impala ss vs. 87 IROC Z
Old Jul 28, 2005 | 03:19 AM
wariat87's Avatar
Car: 1987 IROC Z
Hello again,
Friend just landed himself a big fish. He bought a very low miles (34000 miles) and very clean 96 impala ss with a bone stock LT1 in it. He wants to race me in my 87 IROC Z.
For those of you that don't know: I'm running a pretty much stock 305 TPI but I do have 3" cat back flowmaster and an airfoil. No other mods to the car. My motor is very healthy (78000 miles on it).
I am curious about this. His motor is supposed to turn 260 hp but that car is huuuuuge (and heavy).
Any thoughts?
Wariat
Old Jul 28, 2005 | 04:34 AM
TBI92Camaro's Avatar
Car: 92 Mustang Coupe/89 Camaro RS
Engine: 5.0 carb'd/305
Transmission: T5/T5
Axle/Gears: 3.73 and stock TrakLok/stock GM
You should beat him...they run around mid 15's stock....ive seen a low 15 out of one before buts according to conditions. You will win but not by much. tell him congrats on the ride.
Old Jul 28, 2005 | 08:39 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
It should be a close race. You should have the edge but if your car isn't running 100% or your driving skills are margonal he could beat you.
Old Jul 28, 2005 | 09:52 AM
jagevileye21's Avatar
Car: 1991 Z28 Vert
Engine: LT1 350
Transmission: T56 6 Speed
Axle/Gears: 3.42 LSD
you should win
I raced my friends impala SS once and I won by less than a foot or two, but I think he would have won if he was a better driver. I thought that I would just smoke him because the impala is so big but I was wrong. Those things move especially ones with some mods.
Good Luck
Old Jul 28, 2005 | 02:59 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
they have about 260 hp at the crank.. nothing to write home about, and it's an honest 40 hp less than the Fbody version.
Plus they weigh a SH*TLOAD.
Although with the mods you have, I'd have to give the race to him. About 45-50 MPH he'll start to pull.
Old Jul 29, 2005 | 08:11 PM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
I think he'll take a basically stock peanut cammed 305 TPI car pretty easily unless he really blows it with the launch. I'd bet on him anyway...
Old Jul 29, 2005 | 08:43 PM
Transmission: T5/T5
Actually the Impala SS's came with a cast iron LT1 that made like 285 at the crank I believe...their weight is their hold back...they have a good head design too. (vortec)
Old Jul 29, 2005 | 10:00 PM
Ray87Z's Avatar
Car: 94 Z28
Axle/Gears: 3.23s
No they were definitely rated at 260hp, now whether their output was actually that low I'm not sure. (Going off memory but I believe I recall seeing some 210-220 rwhp stock dynos for them which would roughly coincide with 260, don't quote me though). The iron heads (basis of the Vortec heads) supposedly flowed slightly better than the AL LT1s but I believe the cam was a decent bit smaller and accounted for the lesser hp vs the Fbody LT1...
Old Jul 29, 2005 | 10:07 PM
Mcdamit's Avatar
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
Axle/Gears: Limited 9 bolt, 3.45
if you were an 88 five speed i would say you but its the friggin peanut cam, it will be a tight race though
Old Jul 29, 2005 | 10:18 PM
phoenix305's Avatar
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
Yeah i'm gonna have to go with the impala on this one. If you had the 5 speed i would say you. but with the auto and peanut cam i think you're going to loose.
Old Jul 30, 2005 | 03:39 AM
wariat87's Avatar
Car: 1987 IROC Z
well guys,
I ran him.....
and I lost... by almost 2 car lengths (bad launch on my part). It should be noted that neither of us manual shifted. Good learning experience though. I had a feeling that he might have me. We ran up to about 80 and shut down. I was hoping that I would have launched a little better... then maybe my loss wouldn't have be so big. I am gonna cam the car and do some port work... I want to keep the 305 for a little while, at least until my budget will let me get started on my real project.
Thanks again for all the input guys... I hope to do better next time, and bring back honor to the third gens.
Till then... see ya.
Wariat
Old Jul 30, 2005 | 11:11 AM
lilbowilson's Avatar
Car: 87 IROC
Engine: 406 sbc with Trick Flow heads, Hook
Transmission: Pro built 700R4
Axle/Gears: waiting on a new rear!!!!
For the record I was cheering for you to win, I though the Impalas weight would hender it. But you might also look at your tranny, gears, and suspension. If those are still stock no wonder you lost. The impalas are geared at 3.23 and yours about 2.73 and the stock 700r4s don't shift as good as newer ones so get a shift kit.
Before you spend money on a new cam you might want to consider a 350 short block brand new they range from $750 to $950 on ebay. Even though they are earlier stlye blocks those hyd flat tappet cams work fine with your computer and cost pennies. Do the port work on your 305 heads they will raise your compression up to 10 or so. With your stock TPI this combo will give you some amazing torque down low and you should be able to hang with just about any LT1 in the 1/8 mile.
The engine swap is easy and it will be fun to do it yourself.
Old Aug 14, 2005 | 01:13 AM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
SS impys and 9C1 caprices came with 3.08's...the other gears were a 2.50 gear in the L99 caprice...ALL imps had 3.08s
also if you would of run a car like mine..even though its still the same car, the 9C1 caprices weigh about 150-200 pounds less then an Impala, and a 9C1 caprice with the LT1 and 3.08 gears would of walked you bad...ive beaten a few SS's..by a good margin
Old Aug 14, 2005 | 05:29 AM
Nitrous Al's Avatar
Car: '90 Mercury Grand Marquis GS
Engine: 5.0L Ford V8
Transmission: AOD
Axle/Gears: 8.8" Ford, 3.08:1
Work on your launch and race him again. Tell him best two out of three.
Old Aug 14, 2005 | 09:10 AM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
I'd certainly hope he didn't. He'd gain no benefit from shifting that auto himself.
BAMiller
Sep 14, 2015 06:38 PM
angel2794
Sep 8, 2015 06:22 PM
g.l.mos
Aug 22, 2015 12:02 AM
mustangdmurder
Aug 21, 2015 07:17 PM
mustangman65_79
Aug 11, 2015 03:17 PM
