Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
385 stroker theroies?
Old Apr 7, 2006 | 09:36 PM
TheLastRebelZ28's Avatar
Car: 1984 Trans Am
Engine: just a little 305 ; )
Transmission: the original t700r4 ; )
Axle/Gears: stock 10 bolt w/4.10 or 4.56 richmond gears
ok here we go, i got a 385 stroker im building(385c.i.=350 w/ .040 over bore and 3.75 stroke) specs in sig.So what do you guys think my mph and e.t. will be and how much horsepower and torque do you think ill make with and without nitrous?
ALSO
race weight=3200 running on 13.5" slicks
Old Apr 8, 2006 | 03:14 PM
Car: 1984 Trans Am
ttt
Old Apr 9, 2006 | 07:55 PM
Car: 1984 Trans Am
come on guys anybody got some ideas
Old Apr 9, 2006 | 11:00 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
I can't ever guess this **** - but it sounds like a quick combo
Old Apr 10, 2006 | 07:23 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I take it this car will be 95% drag ready . Your combo sounds like a pure monster and could be deep 11's if not more.
Old Apr 11, 2006 | 04:43 PM
niceroc's Avatar
Car: 87 iroc
Engine: 454 .030 over
Transmission: th-350
Axle/Gears: 9 bolt
im goign to say ull run... into a broken 10 bolt
Old Apr 13, 2006 | 01:43 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
this is more of a drag racing board question...
yeah stock rear or light modded 10 bolt wont like that combo too much.
what converter are you going with?
that combo does sound like a monster..
385c.i. sbc,bored .40 over,complete forged rotating assembly icluding Scat 4340 3.875" Forged
from your sig, that stroke and bore is more of a 395 or 401 small block.. but in your post you say you have 3.75 in stroke...
at 3200lbs race weight i'd say your in the mid 10s off the juice. thats a big cam assuming the 280/288 is advertised duration which would make 248/256 at .050" lift...and good flowing heads. thats probly 600hp on motor if not abit more .. with a nice single plane manifold with a big carb. LOL big numbers will come outta this.
on the spray.. 250 shot, i'd say your mid 9s
Old Apr 13, 2006 | 10:21 PM
superGMman's Avatar
Car: '92 Toyota Pickup
Engine: 22R-E
Transmission: 5sp Manual
Axle/Gears: 4:??
Stroker Motors can always turn out much differently then expected, but one things for sure, you will have a monster. Are those cam specs correct. With that big *** carb on a single plane on those 220cc heads you should be able to get into the single digits with spray.
BTW your 10 bolt's probably going to blow up with your car in gear
Old Apr 20, 2006 | 12:43 AM
Car: 1984 Trans Am
keep the comments coming ......and i fixed the sig sorry bought that also this T/A is basically a drag car but im going to drive on the street a couple times a week to school and then to the local car show they have every weekend. its not exactly "street legal" but i can my inspection sticker under the table and the only reason im running the 10 bolt is lack of funds but as soon as i get enough dough i was going to go with a stought 12 bolt
Old Apr 20, 2006 | 08:14 AM
stu's Avatar
stu
If you can afford to build a 9 second car, can't you save up to buy a Ford 9" or something?
RedLeader289
May 28, 2019 01:47 PM
Nervous2
Oct 8, 2015 10:53 PM
Chevykid810
Sep 28, 2015 12:57 PM
JSDaddy189
Sep 26, 2015 03:50 PM
RedLeader289
Sep 23, 2015 06:50 AM
