1/4 mile esimate??
Car: 1991 GTA trans am
Engine: 305 tpi
1/4 mile esimate??
The car is a 1991 gta
ok here is the list of stuff.
305 TPI
Auto
trans go shift kit
3.73 gears
aluminum driveshaft
ram air intake
ported intake
ported plenium
t/b bypass
air foil
pullies
afpr
6al ignition
blaster coil
8.8 wires, e3 plugs
stage 2 super chip
1.6 rockers (roller tip)
slp runners
lowered 2"
Drag radials
edlebrock tes headers
3" exhaust
flowmaster 80 series
and last is a n2o kit.
But that will be a 75-100 shot.
But i want esimates without the spray and with if you want.
These are all the parts that are sitting in my garage. (or in the process of putting them on)
I just want to know what kinda times I could expect.
Any #'s would be great!
And if you have any other good Idea to make my car fast plz give me some info.
305 TPI
Auto
trans go shift kit
3.73 gears
aluminum driveshaft
ram air intake
ported intake
ported plenium
t/b bypass
air foil
pullies
afpr
6al ignition
blaster coil
8.8 wires, e3 plugs
stage 2 super chip
slp runners
lowered 2"
Drag radials
3" exhaust
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
That TPI will poop out real fast with those 3.73's. I'd go with 3.42's with an auto.Toss those edelbrock headers in the trash for some hooker 2055's or some long tube 2010's.Replace the flowmaster with a better flowing muffler of your choice i.e. Hooker,spintech,Magnaflow etc.After all is said and done I that with the NOS you could easily see a Mid to low 13 second or if your lucky a high 12 second run.I don't mean to pick apart what you already have just trying to help.
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
You prob going to run the same as stock with those parts. MAYBE a high 13.
I say just pop in a 150 shot and go play with some ls1's.
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Do us a favor set the car up to shift into 4th at WOT see if you can pull a wicked trap speed out of it. I'de guess mid 14's off spray high 12's on but there's some things that aren't going to agree like the Hypertech chip, lowering kit, nitrous. Good luck with it either way.
Car: 2000 Trans Am and a 85 Iroc-Z
Engine: The Mighty LS1& 305 just beat meTPI
Transmission: 4L60E and 700R4
He has more mods that I do and I am hitting low 14's corrected. High 14's in town. I say high 13's and high 12's. All corrected at sealevel of course. Not sure of the elevation where you live.
Car: 87 Camaro LS
Engine: LG4
Transmission: T-5 World Class
Axle/Gears: 3.08 Open baby!!
I would say Low 14's with a good launch antd tires..
you have some decent parts there.. a good budget setup
With the NOS you will be in the high 12 range hopefully
alot will depend on your launch get some BFG drag radials..and a stall
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
86CamaroDan
Sep 29, 2015 10:08 PM
