v8 vs. vtech
Car: 91 rs
Engine: 305tbi
Axle/Gears: 3.27 9bolt
v8 vs. vtech
i have a 91 camaro rs with a lo3(305tbi) mated to a 700r4 tranny. my bro's friend has a early 90 honda civic(ugly station wagon style) with a vtech engine do u think my car can take it? i do.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
I had the same setup as you in my old 90RS, my friends honda like your buddys would allways pull me, not by much, but he would get me by a smidge, till i got hedders and cat back, then i got him by 2 cars, he did not have VTEC so he will prolly kill you till you get a gear, stall and some other major boltons, the lighter ones with VTEC only move the way they do because of the lack of weight if they dont have any mods, nitrous is a ****...
Car: 1983 G20 Chevy
Transmission: 4L60
Adequately sized full exhaust from the head ports back (not TBI replacement stuff), 1.6:1 self aligning roller rockers, and computer tuning will put the VTec many car lengths behind you. There is 30-50 hp hiding in the L03 with just those things.
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
sounds like a d18 sohc vtec car.
...vtec advances timing at higher rpm, nitrous needs a timing retard to prevent detonation, how does that make it good for spray..?
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Vtec refers to variable valve timing and electronic lift control...
You're thinking of ignition timing...
alright, i believe i mis-understood what vtec means, it's higher lift at higher rpm?
Just confused on how something mechanically controlled can be electronically controlled aswell?
http://en.wikipedia.org/wiki/VTEC
Car: 87 Camaro LS
Engine: LG4
Transmission: T-5 World Class
Axle/Gears: 3.08 Open baby!!
I would say if you are stock he will catch up to you..
you will kill him off the line, but he will gain..
Especially if he has ANYTHING done to it..
Put on some headers, and a catback and you'll run with him a ton better
Car: '92 Camaro RS
Engine: LO3
Axle/Gears: 2.73 open diff
I don't know what kind of Civic you're referring to, but I raced my buddy's '94 Civic Si hatch (D16 VTEC) with my LO3/700R4 RS, and I beat him by a few car lengths. All I really have is a 3'' exhaust, other than that it's mostly stock.
What happened to that Stu guy that used to be on here? He had all the import knowledge
Car: 1989 iroc Z Hardtop
Engine: 350 tpi
Either way an l03 vs civic would certainly be a slow race. So no matter what happens you both lose
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
vtec also isn't for timing of the ignition but more for cam timing. it would be like running two cams in your car that at a specific rpm. you know one cam maybe something like 194*/194* .465/.465 and then another one at 230*/240* .490/.500 or something like that. more or less just allows for more lift and duration of the cam at higher rpms which with nitrous would decent enough I would think.
there are many ways that electronic pieces can control something physical. selenoids, speakers, fuel injectors, electric motors and many many more take electronic input and convert it into mechanical action or even the other way around as in a alternator which takes mechanical motion and then turns it into electricity
Car: 2005 BMW 545i
Engine: 4.4L N62B44
which vtec engine? that's like saying what would win my rx7 vs a car that has a small block chevy in it? this vtec motor could be anything from an anemic pile of crap up to around I believe 190-200hp or so on a stock motor. which for that car would make it do fairly well as they weigh only around 1900-2100lbs depending on trim and options
Car: 91 camaro T-Tops
Transmission: Borg T5
If I remember correctly Honda didn't put VTEC in their cars until '95 unless is a Del Sol or a Prelude(93 i believe). Did he swap the engine? anyway, I don't know what you run in 1/4 w/ an auto but my L03 runs 15.9, nothing to brag about, but it should beat a 90 civic. is the honda an auto also? bone stock i think a 90 civic runs in the 17's but i may be wrong.
Car: 1982' camaro Z/28
Engine: lt-1 out of a 95' impala ss
Transmission: viper spec t-56
Axle/Gears: Ford 9in 3.90 gears
what kind of v tec motor does the guy have in his car and is it a wagovan youre talking about it being in? if he has a b series youll most likely lose if its a single cam youll get them.
Car: 1989 TRANS AM GTA
Engine: 355 L98
Transmission: Built 700r4
Axle/Gears: BW 3.27
V-tec started in 1989.It doesnt advance timing it just has another cam lobe that it switches to at a cetain rpm that is controlled by oil pressure,the newer style i-Vtec does advance and retard the timing but not the older type
Car: 2005 BMW 545i
Engine: 4.4L N62B44
just to further clarify it will advance or retard the valve timing not ignition timing. ignition timing is controlled by the ECU and has nothing to do with vtec
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
The first gen Vtec will control valve lift only. The newer IVtec controls not only cam timing and ignition timing but will also control duration of the camshafts as well.
Engine: 355 L98
Axle/Gears: BW 3.27
Car: 1983 Buick Regal
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
Those things aren't that fast, I used to take my buddy Joel's '99 Civic Si in my LO3 Formula all the time, until he put nitros on it!
