Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
looking for 12's is it provable
Old Mar 24, 2007 | 11:28 AM
z28z34man's Avatar
Car: 1984 z28 camaro / 2019 accord sport
mods in sig
i also have a set of single grove irocs awaiting a set of bfg drag radials
Old Mar 24, 2007 | 11:36 AM
1badrocZ's Avatar
Car: 1985 IrocZ
Engine: Carbed 383
Transmission: Tremec T-56
Re: looking for 12's is it provable
should be no problem
Old Mar 24, 2007 | 01:32 PM
z28z34man's Avatar
about how much more would i need to get my 12.0x
i would like to get there on motor and put a 100-150 shot on top of that just in case i bit off more than i can chew.
Old Mar 25, 2007 | 12:07 PM
89Nighthawk's Avatar
Car: 89 GTA Nighthawk
Engine: 389 CID Vortec TPI
Transmission: TCI 700R4 w/Vigilante
What are the specs on your cam?
Old Mar 25, 2007 | 12:26 PM
z28z34man's Avatar
Duration at 050 inch Lift:_________________230 int./236 exh.
Valve Lift with Factory Rocker Arm Ratio:____0.487 int./0.490 exh. lift
Lobe Separation (degrees):________________110
Old Mar 25, 2007 | 09:29 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
Wouldn't a little more gear help out with that cam of yours?
Old Mar 25, 2007 | 10:36 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
3.73's with 26" tires or 4.10's with 28" tires
more stall
more cam
less weight
12.0's are about 360rwhp
Old Mar 26, 2007 | 01:17 PM
87LS's Avatar
Car: 87 Camaro LS
Engine: LG4
Transmission: T-5 World Class
Axle/Gears: 3.08 Open baby!!
I would say a bigger stall for sure...
That will help alot, you may bog when you launch that thing...
I would say a 3300 stall would be better.
Get 3.73 gears if I were you...I say its a good setup...
Abit more duration in the cam as well, it will be a rougher, but will sound NICE
Old Mar 27, 2007 | 06:35 PM
z28z34man's Avatar
the stall i plan on getting next season when i take out my motor to paint the engine bay
if i had more gear i probably would need a b4c up shift valve because it tops out at 120 now.
would a set of ceramic coated long tubers help
Old Mar 30, 2007 | 11:36 AM
z28z34man's Avatar
about what do 12.0x normally trap at maybe i could put in more gear. all tho i don't want to waist the money on a 10 bolt.
Old Mar 30, 2007 | 01:17 PM
5678TA's Avatar
Car: 1984 Trans Am
112-115 depending on 60ft and motor.. more torque, faster 60ft, less trap.. more hp, slightly lower 60ft, more trap..
calgutie
Dec 15, 2013 06:43 PM
calgutie
Jan 28, 2013 02:58 PM
88camaro
May 16, 2012 10:40 AM
88camaro
Sep 8, 2001 10:43 PM
