Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
GTP vs IROC-Z
Old May 27, 2007 | 02:10 PM
slicknick's Avatar
GTP vs IROC-Z
Theres this guy above me at work who owns a 97 grand prix GTP. I don't know anything about them except he has a custom exhaust and CAI. I've got an 89 IROC thats basically stock. Will I win?
Old May 27, 2007 | 02:16 PM
18inchboyds's Avatar
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
Axle/Gears: 4.10 gears
Re: GTP vs IROC-Z
nope , they run a 14.7 stock and with that i bet prolly a 14.4-14.5 so .
Old May 27, 2007 | 04:04 PM
intex1982's Avatar
Car: 89 formula/00 z28
Engine: carbed 350/ls1
Transmission: 700r4/ a4
Axle/Gears: 3.23 posi/ 3.73 posi
Re: GTP vs IROC-Z
it will be close they aint that fast not no mid 14 anyway a low 15
Old May 27, 2007 | 05:17 PM
slicknick's Avatar
Re: GTP vs IROC-Z
I thought they ran high 14's even low 15's stock? Plus its 330 lbs of tq to 280? Looking online we both weigh the same, why shouldn't I smoke that bitch?
Old May 27, 2007 | 09:51 PM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
Re: GTP vs IROC-Z
most 3800 cars can run low 15's stock. I've seen stock GTP's run mid to high 14's. It will be close but I think the GTP will pull you on the topend
Old May 29, 2007 | 10:02 AM
8T9 BANDIT's Avatar
Car: 1989 T/A
Engine: PROCHARGED LB9
Transmission: FB BUILT 700r4 2200 stall
Axle/Gears: 10 BOLT EATON 3:73 POSI
Re: GTP vs IROC-Z
what year iroc do u have? do some exhaust, bump up the fuel. and some free mods. and it will be a GOOD race.
Old Jun 4, 2007 | 02:51 PM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Re: GTP vs IROC-Z
Several years back, I worked with a guy who had a GTP, he'd added a smaller pulley, & probably some other stuff to it. I had my headers & most of the free mods, I think that was about it. We went from around 30 to 60 or so, & he walked me good...
Old Jun 4, 2007 | 11:16 PM
bigjay89gta's Avatar
Car: 89 GTA
Re: GTP vs IROC-Z
there was one at the dragstrip last weekend. It ran a 9.9 in the 1/8th. Had CAI only. You should take it I ran a 9.4 in my 89 GTA with only a cat-back exhaust. but I also have ran a 9.9 even a 10 in my GTA so it might be close depending on traction and the tune of your car but you SHOULD get him
Old Jun 5, 2007 | 01:40 AM
iroc22's Avatar
Re: GTP vs IROC-Z
89 IROC with what motor?
Old Jun 5, 2007 | 03:11 PM
atc3434's Avatar
Car: 1986 Camaro SC
Engine: Bolt-on/cam 305
Transmission: 700R4 w/ 2500stall
Axle/Gears: 3.73 10bolt Posi
Re: GTP vs IROC-Z
That is the key question! L98 should be no problem, the G92 305 should be a good race, the peanut cam 305 better only try from a dig, and get a good holeshot. My mild LG4 will just beat the newest GTPs for a dig, those are the 260hp version of the 3800v6, I've seen those run 14.9 on down to 14.7 w/ 93mph trap speeds. From a roll we just neck and neck. The older GTPs, such as the 97 you mention, are a bit slower. A pulley is all it takes to change all that...
Old Jun 6, 2007 | 05:09 AM
F-Body Demon's Avatar
Re: GTP vs IROC-Z
I have had a 97 GTP and it ran 15.75 up here. My 91 GTA runs a 15.61. It will be close.
Old Jun 6, 2007 | 09:14 AM
hgffrank's Avatar
Car: 83 Trans Am
Engine: LT1 350
Transmission: 5 Speed manual
Axle/Gears: 3.73 10bolt till it breaks
Re: GTP vs IROC-Z
I raced one in my 90 305 Bird from a dig and the way that GTP just left me was very shameful. I was absolutely killed by the GTP, but it was a newer than 2000 GTP, I think around an 03 model. I had just killed a 5.0 mustang when the chick in the GTP put me in my place. It was a day that was looking up and then turned into a bad day. I'm not sure about the older GTP's but I know with the newer ones you would be having a bad day too.
Old Jun 6, 2007 | 12:02 PM
savagevulcan's Avatar
Car: 82 Trans Am
Engine: Pro Flo Injected 355
Transmission: BW Super T10 4 speed
Axle/Gears: Ford 9"/3.50
Re: GTP vs IROC-Z
I ran one at the track and it ran a 14.7.
It was a stock GTP but it was a newer one.
Old Jul 10, 2007 | 06:04 PM
sach712003's Avatar
Re: GTP vs IROC-Z
I have a 99 Regal GS which has the same motor as the GTP. They should run around 15 stock but closer to 15.5. They are not that fast it will probably depend on how good of shape each is in since they both probably have a lot of miles. I would not worry about his mods they wont help him much, 5-10 hp maybe.
Galaxie500XL
Feb 1, 2020 04:53 AM
88CamZ
Oct 8, 2015 10:29 AM
86z89iroc
Oct 5, 2015 01:04 PM
Linson
Oct 1, 2015 05:33 PM
TexasMaro
Sep 15, 2015 06:50 PM
