Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
do yall hook on the street?
Old Nov 1, 2007 | 10:12 PM
intex1982's Avatar
Car: 89 formula/00 z28
Engine: carbed 350/ls1
Transmission: 700r4/ a4
Axle/Gears: 3.23 posi/ 3.73 posi
what it says?
Old Nov 1, 2007 | 10:14 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
Re: do yall hook on the street?
no i'm not a prostitute.
Old Nov 1, 2007 | 10:31 PM
intex1982's Avatar
lol hook like no spinning
Old Nov 1, 2007 | 10:47 PM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
With my L98 short block, ZZ3 cam, Edelbrock TES,Edelbrock base, SLP runners + miscellaneous, NO. Thus the name Burnout91
Bill
Old Nov 1, 2007 | 11:13 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
on my old street tires, i'll break loose at 25-30mph rolls once the trans downshifts and goes. no chance in hell in first gear. new street tires hooks somewhat better but still pretty poor
et streets and skinnies, its not too bad, it hooks ok but definately no where near like a full launch at the track
Old Nov 1, 2007 | 11:20 PM
loneroad's Avatar
Car: 90RS Conv.
Engine: 383 w/ small shot
Transmission: th400
Axle/Gears: moser 9in
mine havent stopped spinning yet. slicks on the track are the only way i can hook.
Old Nov 2, 2007 | 12:06 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Well, what do you cinsider "hook"? I spin and feather it out and i get going ok, it is not horrible, i am running a 2,73 in the rear, so i think when i install my dana 44 with a 3.55 gear i might start spinning worse.
Old Nov 2, 2007 | 12:39 AM
4playta's Avatar
Car: 1984 Trans Am
Engine: Built chevy 350
Transmission: TCI Built 700r4
Axle/Gears: 3.73 posi 10 bolt
I smokem all through first and second, on the street I usually launch at 1/2 to 3/4 throttle depending on what kind of pavement it is. That rough pavement that has like stones in it I can get pretty good traction but that realy smooth type of black top forget it.
Old Nov 2, 2007 | 02:19 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Damn, if i launched 1/2 throttle or higher i wouls just sit still.
Old Nov 2, 2007 | 02:56 AM
4playta's Avatar
Car: 1984 Trans Am
I got a real big cam and my power band is way up there...plus I got a posi with some pretty good rubber out back.
Old Nov 2, 2007 | 03:13 AM
Sonicbluecamaro's Avatar
Car: 84 camaro z28
Engine: 350 Carb
Transmission: Built 700 R4
not on street tires, drag radials sometimes
Old Nov 2, 2007 | 11:11 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
What do you consider "big" in the cam department? I have 295/50/15s inj the back, they are ok, wat better than any other radial that is available size wise without goung out of the way to find it.
Old Nov 2, 2007 | 11:23 AM
25thmustang's Avatar
Car: Mustang
Engine: Bolt Ons
Transmission: Stock
285 tires out back = pedal first and second or I'm sitting still.
26x11 Slicks out back = pedal first and second or I'm dpinning just as bad.
Cold weather with either sets of tires spin bad from anything less than 3rd gear. More fun to drive it around the spin in my eyes!
Old Nov 2, 2007 | 01:33 PM
335_GTA's Avatar
Car: 1991 GTA trans am
Engine: 305 tpi
I hook really good on the street. It seems like I hook better on the street than I do on the track,
but that could also explain my 2.1-2.4 60 times
Im running Federal 595 ss
and my 305 runs 13.3's
I have no prob on the street but on the track is where it kills me.
Old Nov 2, 2007 | 02:40 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
Hell my 305 burns them up till about 40, one wheel peel power!
Old Nov 2, 2007 | 08:20 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
I hook just fine on the street with the ET streets; street tires, it's an art getting that thing out of the hole! Add the nitrous on top of that and you have one ***** of a vehicle to get a good run out of. It'll make a heck of a driver out of you learning to get a good L98 car to go fast on street tires.
Old Nov 3, 2007 | 05:51 PM
327???'s Avatar
Car: '82 Sport Coupe/'89 bird/'77 280z
Engine: 355/2.8/L28E(t)
Transmission: TH350/T5/4 spd
Axle/Gears: 3.73/3.42/3.54
On my et street radials it hooks kinda ok from a WOT launch, with the street tires I can spin both until ~45mph.
Old Nov 6, 2007 | 10:54 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
I don't even hook on the street
Old Nov 7, 2007 | 12:45 AM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
on 275-50-15 mt drag radials, set at 20psi.. i spin them throught first and to do a nice chirp in second.. on normal 235/55-16 street tires, i burn straight through second and do a healthy chirp in third..
Old Nov 7, 2007 | 02:32 AM
JesasaurusRex's Avatar
God i hate it when people say that
http://videos.streetfire.net/player....4-03CA7C2648FC
end of story
Last edited by JesasaurusRex; Nov 7, 2007 at 02:37 AM. Reason: Automerged Doublepost
Old Nov 7, 2007 | 06:21 AM
Car: Mustang
Engine: Bolt Ons
Transmission: Stock
Seeing as your truck is about as fast as my car, and probably very light in the back, I can only imagine...
Also at the track I found out when my traction loc fails it is a BEAR to hook. Pedalling and riding the clutch and crappy 2.1-2.3 60's and blowing the tires away through second and into 3rd. Awful times (13.3s @ 107+) but time to upgrade .
Old Nov 7, 2007 | 06:39 AM
EvilCartman's Avatar
Car: '82 Z28
What's this hooking you speak of? My tires hate me.
Old Nov 7, 2007 | 06:57 AM
Go to Edgewater or ORP a couple times and you'll realize why some people say this.
Old Nov 7, 2007 | 11:01 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
end of story
Holy crap....reminds me of rankin road.
Old Nov 7, 2007 | 01:33 PM
It just so happens he could (wrecked now i believe) have plowed snow with that car, but that's still besides the point. Hooking better on the street than the track is complete bs unless theres TONS of prep work done on the road and none on the track. And even then
Old Nov 7, 2007 | 03:33 PM
Exactly, bad track prep will KILL the track quick. I've see water drawn up 100 feet past the staging beams, seen cars puke oil down the track and they put kitty litter down, dredge it with the tire bar a few times and LEAVE IT ON THE TRACK, seen piles of rubber so deep they had 2 little channels they put cones up to force you to keep your tires in them, saw them place cones COMPLETELY out of the groove, so far in fact that my passenger tire was on bare concrete. Yeah it all really depends on the track; a crappy prepared track is worse than clean pavement.
Old Nov 8, 2007 | 12:46 PM
zacharyhorn's Avatar
Car: 91 Firebird
Engine: Turbo 355
Axle/Gears: 3.73:1 7.625" 10 Bolt
I haven't floored my car in first gear yet. I don't know. I'm willing to bet it doesn't hook at all with my BFG radials.
Old Nov 8, 2007 | 01:20 PM
alpine247's Avatar
Car: 1988 IROC-Z
Axle/Gears: 2.77 posi stock
i cant hook worth a sh*t on my stock l98 even im at 30 i can still loose traction
Old Nov 11, 2007 | 03:25 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
street tires are uselss, but with the jegster torque arm, aftermarket lca's/panhard rod, lca relocation brackets, and the 275/60/15 MT ET Street Radials set at 18psi, i can roll into the throttle and be fine. but launching on the transbrake or just straight up stabbing the throttle, it blitz's them pretty hard...but what do you expect with 4.56's out back, lol! i had some guys at an O'Reilly Autoparts watch me in the parking lot and they said the first time i launched the car, it nearly picked up the front tires, but i was going easy. the second time i really leaned on it and it just smoked em up...little 305 is ready to dangle them at the track i think!!!
Old Nov 12, 2007 | 09:04 PM
DIGGLER's Avatar
a buddies mid 10 sec. 4th gen hooked like a **** on cold 325/50/15 mt radials. he could dang near just floor it from a stop and it hooked.
Old Nov 12, 2007 | 11:04 PM
spina74's Avatar
Car: 01 Trans Am Ws6, 92 Camaro Rs
Engine: 6.0, 305
Transmission: T56,700R4
Axle/Gears: 3.90 9", 2.73 10 bolt
My little ol 305 if i smash it in first i light em up, and when i shift into 2nd it chirps so hard it kicks the a** end of my car to the right and i chirp 3rd, so im not sure which one of those 3 count as a hook
Old Nov 13, 2007 | 03:09 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
I have 295/50s on my car, Their just cheap tires but if i roll into the throttle they spin for about 15 ft, not spinning to much but still spinning. If i floor it is just a smoke show. All i have is a high 13 sec 305 that needs alot of tuneing, has a bad bog down low.
Old Nov 14, 2007 | 01:29 PM
91350rs's Avatar
Car: 91 camaro RS
Engine: superchargered 350
Transmission: t56
Axle/Gears: 4.10
i can be cruiseing in third gear at 2500 rpms and spin the tires. at a stop i just sit there and smoke the tires. i have rubber down my rear fender.
Old Nov 17, 2007 | 10:24 PM
Iroc Adio's Avatar
Car: 1987 IROC
Engine: Destroked 377
Transmission: TH-400
Axle/Gears: 9inch with 3.70's
my car hooks awesome. its all about suspension. i also run slicks on the street. i come out on motor then spray. no problem
Old Nov 17, 2007 | 10:43 PM
Iroc Adio's Avatar
Car: 1987 IROC
what tire are you guys running
Old Nov 18, 2007 | 05:26 PM
rideon1200's Avatar
On Probation
Car: 2002 Formula
Engine: 5.7 LS1
WOW, things have changed, we used to brag about how far you could spin, now it bragging about not spinning........Ok, I had a Pinto that hooked like a SOB>
Old Nov 18, 2007 | 07:28 PM
yevgenievich's Avatar
Car: numerous
Engine: ls1, others
Transmission: t56, others
Axle/Gears: 3.23 7.6"
isn't trying not to spin is the reason everybody is buying slicks?
my stealth will burn some rubber in first taking off, that doesn't mean it's an amazingly fast car
Old Nov 18, 2007 | 07:30 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
I can hook in the rain, I'm all setup with drag radials or ET streets on the street.
Old Nov 18, 2007 | 07:53 PM
imma have to raise the BS flag on that one
Old Nov 18, 2007 | 08:05 PM
RandyZ's Avatar
Car: 1983 & 1993 camaro z28
Engine: 5.0 carbed/ LT1 injected
Transmission: T5/auto
Axle/Gears: 373/posi
well i can hook up ok if coming out of the hole with out killing the gas padel ,But i have a 305 .Any i an't really looking to hook up going side ways is my thing drift it like a mother f*****
Old Nov 19, 2007 | 06:36 AM
Car: '82 Z28
pffff made some changes since my last post and now I can hook on the ice with Goodyear F1 tires.
Old Nov 19, 2007 | 10:12 AM
  #42
Newsflash, spinning isn't really a good thing. I went to the track the other night and got pissed off cuz I was slightly spinning right off the line.
Z28/ZR1
Oct 23, 2015 01:04 PM
Cole Curtis
Oct 3, 2015 12:26 AM
mcfastestZ28
Oct 1, 2015 11:23 AM
Derrick86
Oct 1, 2015 05:12 AM
Gordonr1973
Sep 29, 2015 11:59 AM
