Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
1997 T/A M6 VS. 1992 Z28
Old Jan 21, 2008 | 08:35 PM
david068513's Avatar
Car: 1992 z28/1992 RS heritage edition
Engine: 350 tpi, 305 tbi
Transmission: 700R4,T5
Axle/Gears: G92
ok so my friend has a 1997 T/A M6. I know it has headers. I don't believe it has anything else. ok I have a 1992 z28 with a vortec 350. G92 rearend. all power. so its kinda heavy. I think I will take the two sub's and the box out for the race. ok so basically what will it take to beat him? his clutch is bad. it needs a new one really bad. He can drive pretty good. he sometimes power shifts. what do I need to beat him or how close will it be?
Old Jan 21, 2008 | 09:30 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
Re: 1997 T/A M6 VS. 1992 Z28
IF all you have is the crate motor you're done. Hope that he fries his clutch.
Old Jan 21, 2008 | 09:32 PM
Axle/Gears: G92
well what do I need to beat him?
Old Jan 21, 2008 | 10:47 PM
TTA 1387's Avatar
Car: 89 20th Ann. TA
Engine: Turbo 3.8 V6
Transmission: 200 4R
More power
Old Jan 22, 2008 | 07:00 PM
Axle/Gears: G92
I just called him and aparetly I was wrong and it was his old T/a with headers. this one is stock besides a K&N filter. do I have a chance?
Originally Posted by TTA 1387
More power
I figured that
Last edited by david068513; Jan 22, 2008 at 07:02 PM. Reason: Automerged Doublepost
Old Jan 22, 2008 | 07:15 PM
eschevyrda's Avatar
Car: 89camaro rs
Engine: 350tbi (needs carb!)
Axle/Gears: 32x in process
i think it might be a close race just take out the subs .
Old Jan 22, 2008 | 07:22 PM
Axle/Gears: G92
anybody else with a idea?
Old Jan 22, 2008 | 08:28 PM
86firebird350's Avatar
Car: 91 GTA
Axle/Gears: stock
advance the timing a bit, a really good tune up with some 8mm+ wires would be good. might wanna look into a lower temp thermostat. i noticed my car was a bit perkier after installing my 160* stat. same thing with the advanced timing. the car seemed to have a little quicker throttle response.
Old Jan 22, 2008 | 09:25 PM
Axle/Gears: G92
thank you. can it cause problems if I advance the timming?
Old Jan 22, 2008 | 10:49 PM
Car: 91 GTA
Axle/Gears: stock
of course it can, if you advance it too far(in the 12-15 and up range). im not sure what the recommended timing is for TPI but i know for TBI it is 4-8* advanced base timing.
Old Jan 22, 2008 | 10:57 PM
Axle/Gears: G92
yea I figured I was just wondering if like 2 or 3* would screw it up. this is gonna happen probley this fri or sat. any other ideas? should I start from a stop or a roll race? I think I could get him off the linewith TPI and all that lower torque but he would catch me at the top end easy.
Old Jan 23, 2008 | 01:00 AM
Gr89RS's Avatar
Car: '02 Z06
Go from a stop for sure. Practice launching your car and play with tire pressure. This will be the only part of the race that you will be ahead with what you have, you're gonna need full exhaust, upgrade/replace the stock tpi, and a stall to think about maybe beating him.
Just have fun with it and at least it will let you know where you are as far as a baseline for improvement!
Frozer!!!
Jan 19, 2024 04:55 PM
ShaneBuss
Sep 26, 2001 10:00 AM
Blown_n_Injected
Jul 30, 2001 02:29 PM
[-sLaYeR-]
Mar 7, 2001 12:13 AM
