Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
89' vs. 04' Stang
Old Aug 26, 2008 | 01:26 AM
v10viper04's Avatar
Car: 84' Corvette, 96' Caprice
Engine: LT1, L99
Transmission: T-56, 4L60e
Axle/Gears: 3.07 POSI, 2.93 Open
89' vs. 04' Stang
How do you think i would fare with all the mods in my sig (+ 3.73's) against a 04' GT 5 spd with exhaust and intake only?
Old Aug 26, 2008 | 09:49 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
Re: 89' vs. 04' Stang
i can't tell for sure... but it looks like you have a LO5 350 TBI with a cam in there. am i reading that right?, or is it carbed?
Old Aug 26, 2008 | 11:47 AM
Travis odell's Avatar
Car: 89 chevy camaro rs
Engine: Tbi 305
Axle/Gears: 3:73s
I have 3:73s and the Lo3 and i coulnt stand a chance, but then again it all depends on the driver.
Old Aug 26, 2008 | 05:27 PM
abyliks's Avatar
Car: 02 Mustang
Engine: 3.8 about to be punched out to 4.3
Transmission: 4R70W
Axle/Gears: 3.73 Detroit true trac
the GT on average is a low to mid 14 second car.... you should be able to et it
Old Aug 30, 2008 | 03:03 PM
v10viper04's Avatar
Engine: LT1, L99
yea cause i should be making around 300+hp and have 3.73s. Which is more hp than an 04' GT already.
Old Aug 30, 2008 | 03:14 PM
intex1982's Avatar
Car: 89 formula/00 z28
Engine: carbed 350/ls1
Transmission: 700r4/ a4
Axle/Gears: 3.23 posi/ 3.73 posi
u dont have a chance.they run high 13 stock
Old Aug 30, 2008 | 04:14 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
If you ran a 15.0 before the gears I don't see you winning if the guy can drive, I don't see gears taking a full second off of your ET.
Old Aug 30, 2008 | 10:42 PM
v10viper04's Avatar
Engine: LT1, L99
so your saying they are as fast as an LS1 with about 50 less hp and maybe 200lbs lighter?...? whats the deal with that?
the 15 was on the stock L05, it has the mods in my sig now....
Last edited by v10viper04; Aug 30, 2008 at 10:43 PM. Reason: Automerged Doublepost
Old Aug 30, 2008 | 11:05 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Most LS1's are mid to low 13's. A typical '04 'stang should run low 14's.
Ok, I didn't realize that your times were on the stock LO5. You should probably beat him.
Old Aug 31, 2008 | 01:08 AM
v10viper04's Avatar
Engine: LT1, L99
o ok but i've always heard LS1's are high 13 cars... and from what i've been told by ppl on here i should see 300-350hp on my setup....
Old Aug 31, 2008 | 08:04 AM
fly89gta's Avatar
Car: 2018 Camaro SS
Some are high 13 second cars, depends on the driver, the car and the area. Typically though they're faster.
You should beat the Mustang
Old Sep 1, 2008 | 09:30 PM
ROCHEAD!'s Avatar
89 Iroc l98, chip, pulleys, built tranny with 2800 stall. Rear aftermarket suspension. Raced the same car with the 5 speed. We both hooked well. I jumped out about two cars and stayed there to about 90. Did this three times and the same happened everytime. You gotem for sure if you hook.
Old Sep 3, 2008 | 10:33 PM
abyliks's Avatar
Car: 02 Mustang
Transmission: 4R70W
actually unless someone cant drive, and ls1 is a low 13 second/high 12 second car, a 99-04 stang is a low 14-mid 14 second car
3.8TransAM
Sep 17, 2015 02:16 PM
TexasLT1
Nov 14, 2001 06:14 PM
Jester
Carburetors
Oct 23, 2001 01:40 PM
TexasLT1
Aug 27, 2001 09:25 PM
92camaroRSV6
Feb 11, 2001 08:53 PM
