why do honda/import "tuner" people think their stuff is fast
Car: 1983 G20 Chevy
Transmission: 4L60
Re: why do honda/import "tuner" people think their stuff is fast
Drive your car in direct drive at lower RPM and I can assure you it will. GM used a restrictor plate on the early vortecs to kill off the throttle response of a large single tb.
Car: 1983 G20 Chevy
Transmission: 4L60
I have no problem with that. That's a significant difference in torque, a higher RPM peak, AND more compression.
It's not the direct injection that improves the torque, it's the compression. Compression which the OP lacks, so your point is invalid.
Low RPM torque is overwhelmingly a function of engine displacement. While the peak numbers can be improved, it needs additional RPM and cylinder pressure to do so. This is true of ALL engines, which means no in-depth knowledge is necessary of the VK.
3,000 rpm is the MID-range of a VK56 with stock cams.
With a locked torque converter it would probably lose 15-20 ft/lbs and gain 10-15 hp.
Car: 1983 G20 Chevy
Transmission: 4L60
Think you need to try another dyno. Numbers seem way high for the combo.
No doubt modern motors are doing great things. Ford 5.0 coyote is a great example of improved tech. All those years the 4.6 ohc motors sucked without a blower, even build strokers werent making numbers. Now you have mod motors dominating engine master challenges, where power matters from 2500-7000 rpm.
Just think some claims are taken with grain of salt that is all
The combo falls right where it should looking at other results with the edelbrock etec/performer LT1 heads.
Car: 1983 G20 Chevy
Transmission: 4L60
Also have the dyno charts of not one, not two, but 3 different Titans on the Mustang dyno...The owner of said Mustamg dyno also put his truck on a different Dynojet and saw the same 10% gain in numbers that I saw on the dynojet I tested on. I have charts from an 04 before and after headers, a 2006 before and after headers and after a merge Y based exhaust and an 05 with headers using 3" collectors.
Steve @ PRT is building an improved version of the Nismo headers built for the Titan. Here is his blog and dyno numbers further improving my point. His truck is a 2004 that has smaller diameter intake runners, fixed intake cam on a relatively wide lsa, and cams smaller in both lift and duration.
http://prtperformance.com/blog/?p=111
Car: 1983 G20 Chevy
Transmission: 4L60
Here is another chart from a friend of mines 2006. Run 1 was before headers, Run 2 after original nismo headers and Run 3 after a 2.5 to 3" merge Y based exhaust was fitted.
Me racing this 2006, I always had a horrible time getting off the line on street tires in that truck. Even spinning and him jumping the gun and redlighting, the finish margin was less than .1s.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Mine will not stay direct drive so that will not happen. I dont see how that trans does if electronically controlled
Car: 1983 G20 Chevy
Transmission: 4L60
Its the most reluctant transmission to downshift at part-throttle I have ever been around. On the highway at 65 mph you can push the throttle over 1/2 way open before it ever even unlocks the converter. In most vehicles this would not work too well, but it accelerates just fine. Going uphill at 40-45 mph with light throttle has it at ~1,000 rpm and it holds speed despite the low rpm. I often shift into 4th around town because I like the added response and don't mind the slight fuel economy hit.
Car: 1983 G20 Chevy
Transmission: 4L60
Yet another run starting at 2,500 rpm with peak at 3,000ish. I will say I have I have never seen an engine as sensitive to header design and collector/exhaust diameter as this one. Two trucks, 2.5" vs 3" and the 3" MURDERD torque.
Car: 89 Iroc-z
Transmission: TH400
Car: 1983 G20 Chevy
Transmission: 4L60
Its actually kinda nice that it doesn't downshift until you really get on it. Really does not need to. Even the Tow/Haul mode really doesnt change the 3-4 and 4-3 shifts much if any.
Car: 1983 G20 Chevy
Transmission: 4L60
You have 80mm throttle bore in which air enters. If bore is only open 30-40% of total 80mm, guess what that is a restriction. Hp and trq is made from given airflow and volume of fuel burnt. 365wtq of air mass has to enter that engine thru 30-40% opening. Only way that could happen is if velocity is thru the roof which can have problems in its own right, and doesnt seem possible.
I could believe wot but its hard to buy that airflow is coming thru a 30-40% opening
Idle
Off-idle to WOT
2.08 throttle volts is right at 40% opening comparing idle to WOT
Car: 1983 Z28
Engine: 385 Fastburn
I have spent the last week and a half reading this thread in all of it's 42 pages. Since some people may not be as dedicated to doing that, I thought I'd give a little recap.....
It all began in 2008...one man with his rant....
It continued on, by post 506 (page 11) we had "gems of knowledge" such as this...
Then came post 693 (page 14), one of my personal favorites:
By post 1185 (page 24) disbelief was running rampant...
Then in post 1305 (page 27) a random post about lawncare appeared, TO WHICH there was never an explanation.......
Post 1524 (page 31) had an interesting thought on mobile homes:
FINALLY post 1803 (page 37) broke out one of the most classic disses of all time:
And now, after 6 years, over 2000 posts, and 42 pages this thread is now talking about something to do with hp numbers and stuff for a nissan pickup truck.
There is much MUCH more to be found in this thread if one dares to venture, name calling, flaming, member measurements, pink tuxedos, oh the list goes on...
BUT, I will just leave those for some curious and no doubt determined member to seek out.
Happy hunting fellow thirdgenners.
Since when where motors smaller than a bottle of pop with a turbocharger on it running mid 13s ever fast? I'm sorry i don't care how much boost or that 50hp shot of "noss" and 6 foot wing are going to make your car fast. American v8/rearwheel drive platform is a much better platform. I just don't get it someone clue me in.. i mean is it a disease? are people just retarded? Fast n furious makes me wanna puke. All these kids at work think they can smoke my iroc, i seen the kid run his "prelude" at the 1/8th mile and ran 11.66. I literally saw a go kart run that fast that night (run what u brung). I'm running 8-8.10s. Stock irocs are running high 9s. Someone fill me in here cos i see a lot of these kids at skool got these turbo civics and stuff and while the turbo is interesting, and 4cyl is so simple, its just laughable i mean a 4 cyl, I'll drop a 454 on that 4 and itll crush it like a tin can. bigger is better. civics are economy cars nothing more. If you like turbos turbo a smallblock and make 500hp.
Stages in turbo charging are referring to the different parts/power levels of a turbo car. Parts will vary between different types of vehicles and applications. Stage 4 is often when bigger turbo chargers are used, not just increased boost, all of the other supporting mods are done or upgraded as needed.
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
RedLeader289 yo daddy so red neck his son owns a thirdgen Camaro from the early 80's
Take that Foo!
Take that Foo!
Car: '87 S/C Camaro
Engine: 5.0 LG4
Transmission: TH700R4
Redleader, the only reason I mentioned anything in regards to a nissan was in response to fast355's comment... I could care less about a "Datsun"... The ONLY reason I registered to this site is because I own a third gen. The only reason I posted on this thread at all was because of the palpable idiocy for members of a site to bash the very cars in which the site even exists to begin with.
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
I can be good at this game too; I'm now the proud owner of an R34 skyline however I can't show anyone anything concrete about it, but I have it, so don't question me on it because I'll pull some of the most repetitive stuff out of nowhere and try to beat you down in an argument using 99% exaggerated "facts"
Seriously man excellent thread to read, I give it a 10.
Car: 1983 Z28
Car: 1983 Z28
Fast355 has zero credibility on every forum. Everything he spews is pure crap. This is his life making up stories. Other screen names you can find him
06hemiram,fast355,fast305,carguychris. etc
Car: '87 S/C Camaro
Engine: 5.0 LG4
Wikdvk I know (now), and I wasn't trying to give you $#!+ redleader, you mentioned ppl talking about nissan pickup #'s and I was just letting you know that I was only replying to fast355' comment. The other stuff was about the fact that I didn't join the forum to discuss nissan pickups. Which fast355 brought up in the first place...
Car: 1983 Z28
Told you the torque was BS.
Fast355: "But but but, it's a VK with NOS!!!"
Car: 1992 camaro rs
Engine: 92 350ci carbed
Transmission: 700r
Axle/Gears: Stock 10 bolt 2:73 gears 😭
I bought a 92 rs for 400$, put in a 350 I got for free, then put in a cam that cost about 120$ and it ran a 14.3 quarter mile. Lol I'd say that's cheap power
Car: '87 S/C Camaro
Engine: 5.0 LG4
Car: 1992 camaro rs
Transmission: 700r
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
Car: 1992 camaro rs
Transmission: 700r
Car: 1983 G20 Chevy
Transmission: 4L60
Good cheap combo there. L31 vortecs are generally cheap and easy to pickup and you can still find F/Y-car LT1 cams cheap. Cheap easy way to 330+ hp.
Oh look king lies is back. Do you think any of these guys take you serious after you got exposed AGIAN. Didn't think you would get caught again?? your a joke
I don't like liars and people that come on forum taking credit from other people. DO YOU? read this
http://api.viglink.com/api/click?for...s.net%20Forums
Car: 1983 G20 Chevy
Transmission: 4L60
I do alot of my own work Mike, get a life! You couldn't even put cams in your own truck or tune it!
Oh and look what the Titan is getting next!!! Picked them up friday. Already have the heatshields off and the nuts soaking with penetrating oil. Even at only 5550 miles I am not taking chances with the studs. Oh and my fresh LT4 heads for the 383 LT1.
Car: 1983 G20 Chevy
Transmission: 4L60
Your going to be exposed on every forum your on ........Hows that fake dyno you posted again going for ya? or the fake dodge truck you pretended was yours? or the fake times you claim you ran?
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 1992 Camaro Z28
Holy God, enough with the damned Titan. It's a TRUCK. No more about it, please. A thread about a truck is mind numbing in the extreme.
Car: 1989 Trans Am GTA
Transmission: M28 T56
How about a bone stock Fiesta ST clicking off a high 14 second pass at 95mph? I expect the ET's will drop as owners learn to drive them better. If it wasn't wrong wheel drive that ET would be a lower. I wouldn't mind one, but for daily driving purposes I needed a bit more room, so the Focus ST was what I got. I really wanted the RS, its just 2 years ago there was no word on the Mk3 Focus RS. Now we know its going to have 330hp, ~330lb/ft torque, and come in about 3300lbs. It is very tempting.
Cars are going places faster and faster. Dodge and their 204mph Charger Hellcat, then you have the tiny hatches that perform almost as well as the 3rd gen F-bodies did.
What was once king of the streets is now sub-par performance. But thats progress, and progress is good.
Car: 1983 G20 Chevy
Transmission: 4L60
You're the one that brought a dead thread back up. Speaking of which might be a truck but it would still kick the hell out of any stock L98 F-car in a drag race.
Car: 1982 Pontiac Trans-AM
Engine: 283
Transmission: Saginaw 4 Speed
Stock for a third gen isn't anything to brag about.
It's a small block chevy, there is almost no excuse as to why you couldn't make it faster if you wanted to.
Car: 1983 G20 Chevy
Transmission: 4L60
Same thing applies to anything. I have a SBC 350 Vortec in a 99 C1500 Suburban that runs 9.20-9.30s in the 1/8 with a very simple and inexpensive parts list. LT1 cam, hooker long tubes, hooker dual exhaust, K&B CAI, S10 torque converter, transgo hd2 shift kit, stock 3.73 posi, and PCM tune
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 89 Firebird
Engine: 355 TBI
I'll run any stock l98 against my stock focus St.
I enjoy both immensely. I love my thirdgen.
But if you were to pit two factory stock examples against each other the thirdgen would lose in every objective category.
Hot hatches have come a long way.
Car: 1983 G20 Chevy
Transmission: 4L60
People who actually have nice modern vehicles. As soon as you put the pedal down next to a pickup truck and get left behind you might care too!!
You may love your 5.0L, but it was a 15 second car when it was new and most 4 bangers on the road today can run with it if not outrun it.
You may love your 5.0L, but it was a 15 second car when it was new and most 4 bangers on the road today can run with it if not outrun it. Last edited by Fast355; Aug 15, 2014 at 03:16 PM.
Car: 89 Firebird
Engine: 355 TBI
You may love your 5.0L, but it was a 15 second car when it was new and most 4 bangers on the road today can run with it if not outrun it.Joined: Mar 2014
Car: 89 Firebird
Engine: 355 TBI
I wouldnt race work vans and suburbans thats just so #$%*
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by dmccain
Ive have nice modern vehicles the last 20yrs mr fast355. Yea so what if my wifes altima can outrun my firebird. It doesnt mean much to me...
My car outran 4bangers in its day...
I outran a 69 Chevelle SS with a 87 GTA...
If i wanted to race i would build a RACE car...
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
The only jap company making performance cars in the USA at that time was mazda. The supra put out a modest 205HP in 89 but did not bump up to "276" until 1990
If a stock L98 thirdgen ran 18's from the factory, it would still be preferable and cooler than any truck, bar none.
