305 thirdgen vs v6 fourth gen
Car: 86' Z28
Axle/Gears: 2.73 (for now)
it may be vague but in stock form how would a race between a thirdgen with a 305 and a v6 fourthgen go? who and by how many lengths?
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Re: 305 thirdgen vs v6 fourth gen
It's hard to say. What kind of 305? TPI? TBI? Also, what v6 is in the 4th gen? I know I didn't help much, but there are a ton of factors. If it's a LG4 vs a 2002 V6 for example, the v6 is going to take it. If its a 305 TPI vs a 1994 v6, then I would go 305.
Car: 86' Z28
thats were the vague part came in lol i should probably just research the hp ratings it was just something i was wondering. thanks for the reply
Car: 84' Corvette, 96' Caprice
Engine: LT1, L99
Transmission: T-56, 4L60e
Axle/Gears: 3.07 POSI, 2.93 Open
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
I think you have him off the line with the amount of torque you have, but top end I think he will get you.
Engine: LT1, L99
Car: '89 Formula WS6 N10 No T-Tops
Engine: LB9 225HP
Axle/Gears: 3:45BW
Some 305s (mine for example) put out more HP (225 hp) than the 3.8 liter fourth gen motors (200 hp). I believe my car (@ 3434 lbs. I weighed it) wieghs less than a fourth gen 3.8 car as well, so it all depends on what years we're speaking of...
Car: 1983 Trans Am
Engine: 305 4bbl
Axle/Gears: 10 Bolt 3.27 posi
i agree that we need to know what specs are of each car.
If the 4th gen is 93-95.5 you will most likely win regardless of what kind of 305 you have. those 4th gens came with the 3.4L and they were crap stock. 95.5+ recieved the 3.8L. They are strong motors. I had 3 4th gen v6s and they all used to beat 305s carbed and TBI all the time. TPI gave me a run for my money but i still managed to get those in the long run too.
Basically if you are stock, at best you will have a tight race that 8 out of 10 times the win will go the that v6...unless it has the 3.4L
Engine: LT1, L99
Engine: LB9 225HP
Axle/Gears: 3:45BW
7.4 0-60 and a 15.7 second (@88.5 mph) Q-M
http://www.motortrend.com/roadtests/.../features.html
Typical TPI 305 cars were a bit quicker than that:
HPP magazine tested an '89 model Firebird Formula w/ 225 hp. TPI 305 5 speed:
0-60 in 6.5 seconds and a 15.02 Q-M time (@92 mph).
Car: 89 20th Ann. TA
Engine: Turbo 3.8 V6
Transmission: 200 4R
If equipped right, a V6(3800) 5spd and excellent driving, could sneak into the high 14's. Most were mid 15's. A4 cars were mid to high 15's.
So it would be a good match up to a 305, even a TPI.
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
I've raced a few 3.4's and 3.8's in the past and the 3.8's definately gave me a run for my money but I still came out on top. I had a friend who had one back in 2000 (3.8) with a few mods and that thing would dip. I wouldn't mind having one as a DD.
Car: 92 Z28
Transmission: M5
I own a 1998 3.8 with an aftermarket airlid, SLP under the airbox ram air scoop, K+N filter, and B+B Triflow mandrel stainless steel exhaust, 5-speed, 3.23 rearend as my daily driver. I figure this puts me at about 225 HP and 250 ft/ibs at the flywheel. Pretty stout for a V6 of that year.
I also own a 1992 Z28 305 TPI G92 5-speed, 3.42 limited slip rearend, with a gutted airbox, K+N filters, Borla Catback and a Hypertech chip. The 305 TPI is likely in the range of 245 HP and 320 ft/lbs at the flywheel. Both cars are in excellent mechanical condition.
I give the edge to the 1992 305 TPI. Off the line the torque advantage is markedly felt and the 1992 just pulls stronger throughout the RPM range until 4500 rpm. On a side note I get up to 34 mpg on the highway in the 1998.
Car: 89 Formy
Engine: carbed 355ci
Transmission: A4
Axle/Gears: 3.73 10 Bolt
my 305 tpi pulled hard all the way to 5000...then it shifted
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
LG4 - low 16s
L03 - high 15s
LB9 auto - low 15s
LB9 stick - high 14s
3.4L 4thgen - low 16s
3.8L 4thgen - low 15s
L03 - high 15s
LB9 auto - low 15s
Car: 1991 Trans Am
Engine: 305tbi to 350 carb'd
Axle/Gears: Stock
i have a 305 tbi pretty much bolt ons and smoked a 93-97 3.8L firebird(catback)
Car: 86' Z28
Car: 1991 Trans Am
Axle/Gears: Stock
Car: 86' Z28
i have a 350 not a 305 (i just wanted to see how it stacked up) but yeah i was playing around with one once when i first got the car, he pulled up at the next light and the guy goes "woah dude whatcha got in there?"
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
Car: 1990 Camaro RS
Engine: 3.1 MPFI V6
Axle/Gears: 3.23 open diff
Car: 1991 Trans Am
Axle/Gears: Stock
Car: 1991 Trans Am
Axle/Gears: Stock
Car: 86' Z28
stupid rIcE bag Senior Member
Car: 1987 Z28
Engine: LG4
last year.....i had only one defeat....an LS1 camaro m6 packing No2
a lot of cars around here are running high 18's to low 14's on the street
Car: 1990 Camaro RS
Engine: 3.1 MPFI V6
h8r, you're lucky. most of the guys here in South Dakota are running low 13's all the way down to basement 7's the Honda's even are getting down there in times too
Car: 1987 Z28
Engine: LG4
most of the cars local are riced out pos's.....and we also got v8 s10's and rangers that give a bad name to themselves for running 15's LOL
this year should be better for me.....a 327 TPI while having a 10 lb bottle in rear hatch
Car: 86' Z28
Yeah i usually mind my own business until someone starts messing around, or i catch an attempted flyby from a 18 second shopping cart with a coffee can hanging off lol
Car: 1991 Trans Am
Axle/Gears: Stock
lol same here xbox07 but with that one idiot i was just listening to my music low then i heard him rev behind me thats when i was like "are you serious"
Car: 1992 Camaro RS
Engine: 350 Carb'd
Transmission: 5 Speed
Well I had the pleasure to run with a 3.4 v6 fourth gen the other night, I am in a 305 TBI with mild mods and it wasnt really close. Granted we were on wet roads so it was a matter of who had traction first but if he hooked up before I did I was passing him in third gear once I got rolling. My car is a stick his was automatic not sure if that played into it too much but 1st gear was literally useless for me...
Car: 86' Z28
i've got another thought for a race, stock 77 trans am vs a stock 2001 v6 camaro (3.8). My friends cars, the camaro has like 200hp as far as i know, and the trans am has somewhere around 200 i think and i know hes gonna have more torque than the camaro but being 32 years old the t/a has to have lost a little bit. It wasn't neglected or anything but its not show quality and ya gotta figure in a little wear ect. So who do you guys think would have it?
Car: 1991 Trans Am
Axle/Gears: Stock
older doesnt always mean slower ill go with the older one but idk for sure lol
Car: 86' Z28
. i ran high 15-16.0 and like i said i beat that one kids
