Would this be a good setup?
For my camaro project this is what I have so far...all given to me..Im trying to figure out if this will all work together.
The block is a 3970010 number. It is a 4 bolt main. I came up with it was used between 69-79.
The heads I have are supose to be vortec heads 1023906.
I have a edelbrock performer rpm intake part number 7116.
Forged pistons that are .30 over. and rods.
I just need a crank and carb.
the cam has these numbers on them.
3434
11 48 99
119306
?90112
which it supose to be a lunati with 490 lift.
Bracket Master II; Camshaft; Hyd.Flat Tappet; RPM 1800-5800; Adv.Dur. 292 Int./Exh.; Valve Lift .490 Int./Exh.; Lobe Angle 110 Deg.;
I think I will need a better set of heads.
3434
11 48 99
119306
?90112
Terrell351
Jun 13, 2021 01:13 PM
Street Lethal
Aug 13, 2015 08:28 PM
