Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
Slowpoke
Old Sep 29, 2011 | 10:03 PM
84beaut's Avatar
Car: 1984 Pontiac Firebird
Engine: 4th Gen 3.4 V6
Axle/Gears: Stock
Slowpoke
No, not the pokemon.
I'm usually out in town with my girl every other day. Her dad owns the local shop she works at, and usually we take my car and leave hers there and pick it up on the way home. We joke around and have our windows down and race each other light to light, since highway 27 here is a straight highway through town with a million stop lights. Then we turn on to another highway, and it's a perfectly straight stretch of freshly paved road and a 1 mile stretch before the turn to our house, and we race the whole way. In a few weeks, i'm doing a 3.4 swap out of a white 90 something camaro. Can't even chirp or squeal anything even at WOT from a stop, so i'm hoping it will be an improvement. Haha. She walks me like nothing everytime, and I figured I would see what it would take to at least stay with her. Lol
Her car:
2008 Saturn Aura XR
3.6L "LY7" 252 hp (188 kW) @ 6300 rpm; 251 lb·ft (340 N·m) @ 3200 rpm
Completely stock car.
Mine of course:
84 Firebird
Completely stock Carbed 2.8L V6
With freshly flushed newer-used 700R4 replacement.
No weight reduced except for the spare tire and jack.
215/65/15's on front and the back Im stuck with used 215/70/15's because the cheap used tire place didn't have any matches.
Is there any way I could get this 3.4 to hold up with her? What mods, etc. will I be looking at? I'm not really looking for a V8 right now, as gas is killing me on money at the moment.
PS: Yeah, I know, V6..
Old Sep 30, 2011 | 08:03 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Slowpoke
With the 3.4 I think she will still wreck you. You will probably have to rebuild it get some heads from a newer v6 cam ect and do it up. Then I think you could keep up.
Old Sep 30, 2011 | 08:09 AM
84beaut's Avatar
Axle/Gears: Stock
Re: Slowpoke
What heads would work?
Old Sep 30, 2011 | 08:15 AM
midias's Avatar
Re: Slowpoke
Here is a sticky from the V6 section
http://www.domesticcrew.com/hybrid.html
https://www.thirdgen.org/forums/v6/4...eads-info.html
https://www.thirdgen.org/forums/v6/5...ost-power.html
Old Sep 30, 2011 | 08:24 AM
84beaut's Avatar
Axle/Gears: Stock
Re: Slowpoke
Didn't even see that second one. Thanks. Also, I was told they were going to swap my intake with carb and bolt it onto the 3.4. Would this be any performance loss with my current intake? I might as well do headers, etc. while it's out.
Old Sep 30, 2011 | 08:30 AM
midias's Avatar
Re: Slowpoke
If I were going to keep the intake and carb I would at least get one of these
http://www.summitracing.com/parts/EDL-3785/
http://www.summitracing.com/parts/EDL-3787/
Also probably swap the cam but I am not sure what carb would be best. I dont think you will make the 160 hp that the 3.4 puts out stock with a carb and 2.8 manifold.
https://www.thirdgen.org/forums/v6/3...arts-60-a.html
Old Sep 30, 2011 | 08:33 AM
midias's Avatar
Re: Slowpoke
Then I used the search function and found this
https://www.thirdgen.org/forums/v6/5...-camshaft.html
https://www.thirdgen.org/forums/v6/6...ance-carb.html
http://www.summitracing.com/parts/EDL-3789/
here is the trop parts for a 4bbl carb
Originally Posted by ex-x-fire
Edelbrock makes an intake, it has a base & 2 tops. ! is for the stock carb. the other is for a holley 390cfm 4 barrel. You'll need to find a vacuum advance distibutor, I think it was from a 82 s-10 truck 2.8L.
I had that on my 84, along w/ their cam kit & 373 gears, really woke up the car. Doing that swap gets rid of alot of emissions crap.
I think a holley 4bbl with the edelbrock manifold and a mild cam will really wake up the engine.
Old Sep 30, 2011 | 08:51 AM
midias's Avatar
Re: Slowpoke
ok one bit more info
http://www.edelbrock.com/automotive_...ormer-v6.shtml
chevrolet 2.8L V6
PERFORMER 4V 60° V6 (idle-6000 rpm)
Designed for 1982-85 2.8L 60° V6 Chevy longitudinal-mount engines used in light duty pick-ups and cars. Design features one manifold base and two interchangeable tops. The Performer 4V 60° V6 #3789 accepts std. flange 4-bbl. carbs. Edelbrock Signature Series chrome valve covers #4488 are available for this engine.
Code:
Applications 	                                            Part #
Performer 4V 60° V6 Base 	                            #3785
Performer 4V 60° V6 Top (non-EGR) 	                    #3789*
Top Gasket (included with top) 	                            #6942
Carburetor Recommendations: Holley #0-8007 (390 cfm)
Installation Notes: Manifold height: A-4.90", B-5.95" see A/B Measurements. Port exit dimensions: 1.00" x 1.28"/1.00" x 1.71". Recommended intake gasket: Fel-Pro #1270 or #MS91022. Linkage and bracketry come with top. With 4-bbl. carb #0-8007 and auto trans, a GM transmission cable #25515598 is required.
Old Sep 30, 2011 | 03:21 PM
84beaut's Avatar
Axle/Gears: Stock
Re: Slowpoke
chevrolet 2.8L V6
Code:
Applications 	                                            Part #
Haha, wow, you're just on the ball here. Thanks so much. If I just did the intake and carb, with headers, and decent cat-back exhaust, what performance standpoint would I be looking at compared to a stock FI 3.4 without getting heads or a cam? Around the same, or a noticeable improvement in HP?
Old Oct 3, 2011 | 08:43 AM
midias's Avatar
Re: Slowpoke
Not really sure I dont know how well the v6 responds to mods. But I would probably not worry about the heads and get a cam even a mild one.
I bet with a decent holley carb and edelbrock manifold cam exhaust and cam you can get 180 to 200
I would ask around the V6 section
Animus
May 13, 2006 08:35 PM
slowpoke
Sep 2, 2001 04:47 PM
Tom Keliher
Oct 13, 2000 10:40 PM
