Estimated 0-60 and 1/4 mile
Car: White 84 z28
Engine: Chevy 350
Axle/Gears: Posi and?
What estimate 0-60 times and 1/4 times do you think id get with a semi fresh mild 300hp 350 carburated 700r 3.42 gears stock otherwise. Remember an estimate is all im looking for. Thanks
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
Re: Estimated 0-60 and 1/4 mile
need weight.. beat that same combo... it ran 14.6... I ran 14.3 when I had my 305 T5 3.73 suppertrapp catback sleeved cat 58mm TB 30# inj and my tune
Car: 82 Z28
Engine: Gen I 355" Solid roller cam/rockers
Transmission: Built TH350 w/Shift Kit
Axle/Gears: 7.5" 4.56 gears for now
well, i took a guess on the weight (3400 with the driver and 300hp) comes to a 13.91 on one of those calculators. but depending on sea level, track conditions, tires id say low 14's. maybe break a 13's on a perfect day and perfect run.
Engine: 231 / 383
Uh car with driver... Unlike the guesstimate above making the driver 100# most women weigh more.. A LT1 vette has 300 less weight and only pulls a average 14.1
Car: 1992 pontiac firebird
Engine: 305 v8 lo3 201.5hp and 268.2 tq
Transmission: 4speed 700r4 corvette servo
Axle/Gears: 3.42 disk posi 4th gen rear swap
i am wodnering the same thing i have 92 firebird t-tops my car dyno ats 202 hp at 4417 rpm and 268 tq at 3673 rpm to the tires out of a 305 tbi what do you think my 0 to 60 is and 1/4 mile i did a rear swap to went fro ma 2.73 to a 4th gen 3.42 posi i was running a 9.7 to 9.8 1/.8 mile with the old rear end
Car: 82 Z28
you need the weight. even a rough guess? then use this.
http://robrobinette.com/et.htm
Car: White 84 z28
Engine: Chevy 350
Hey thanks thats a really good site, and i can play with hp and weight to see best combo
Car: 1989 Trans Am GTA
Transmission: M28 T56
The ET calculators are horrible. You are better off doing a calc for the trap speed.
300hp and about 3500lbs (race weight includes driver, so I'm estimating), would be low 13's around 100-103mph.
My car traps ~103mph with a race weight of 3750lbs, that calculates out at ~320hp flywheel.
Get that thing to the track and report back with your trap speed and weight and you'll either be proven right or wrong.
Your in florida, there should still be a track open.
Car: 1992 Camaro RS
Engine: 5.0 TBI L03 V8
Transmission: Rebuilt 700R4 W/ Corvette shift kit
Axle/Gears: 2:73 open
Is the rear end a 3:42 posi? And what size/brand/type are your rear tires? Width in particular. Traction matters!
Driver Reaction
Driver Skill
Torque Multiplication through the torque converter
Tire traction
Track Temp
Gear ratios
it goes on and on.
Unless you have a degree in physics its not worth the effort.
Car: 2002 ws6, 2011 sierra 6.2L 6 speed
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
roughly 13.9 with 300hp
13 flat with 300 rwhp
*all times based off perfect conditions and good driver*
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Using a sim a 5500 redline 300hp at 5000rpm 360tq @ 4000 rpm and a race weight with driver of 3670 stock gearing and a 3.42 rear.
I get with redline shifts and a good launch
0-60 5.4 1/4 @ 14.2 @100.2mph
I also used aerodynamics for a 1990 TA because that is the only one I have.
I do 13.35 @ 102.8 on street tires. My car weighs 3750lbs with me and the laptop bag in it + 3/4 tank of fuel. Using the HP from Trap speed formula below thats about 320hp. HP = 3750 * (102.8 / 234)^3. Answer is 317.9HP estimated.
Here's how I know. And a few examples of stock cars.
Formula is HP = Weight * (Speed / 234)^3 This estimates flywheel HP, not Wheel HP.
Lets take a car that we know. A Chevrolet C6 Z06 weighs about 3150lbs, and traps about 125mph. But since only KITT can drive by itself we need to add in driver weight. Lets put that at 200lbs for an estimate, so 3350lbs race weight.
HP = 3350lbs * ( 125mph / 234)^3
HP = 3350lbs * .53419^3
HP = 3350lbs * .152434
HP = 510.65hp.
A Chevrolet Z06 is proposed to make 505hp. The estimation is pretty close. That formula estimates HP from trap speed. What if you want to go the other direction? There's a formula for that too. This also uses crank HP. Lets use the Z06 again for comparison between the two.
MPH = 230*(HP/Weight)^1/3
MPH = 230*(505/3350)1/3
MPH = 230*(.15075)^1/3
MPH = 230*.53221
MPH = 122.4mph
Again, we are pretty close here, its very possible to run a 122mph trap speed as there are variables we simply can't account for with such a simple formula.
So how about the OP's question then? 300hp? 3300lbs curb weight? Add in a 200lbs driver too.
MPH = 230*(300/3500)^1/3
MPH = 230*.085714^1/3
MPH = 230*.44091111
MPH = 101.4mph
There is an alternate trap speed estimator formula that was published in the 50's, its only slightly different being MPH = 224*(HP/Weight/^1/3.
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
300rwhp is better than a 13 flat with a good driver and conditions, closer to mid 12s.
HP = 510.65hp.
MPH = 230*.53221
MPH = 122.4mph
MPH = 230*.44091111
MPH = 101.4mph
HP = 510.65hp.
MPH = 230*.53221
MPH = 122.4mph
MPH = 230*.44091111
MPH = 101.4mph
