Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
cost to add some power to a 305
Old Sep 2, 2001 | 03:22 AM
unknown_host's Avatar
Car: 1989 Iroc Z L98
my friend has a daily driven nova we are gonna spice up. i just am wondering what the cost of machining a block (cheaply), and reworking his heads and porting them would cost. just rough guesses on the cheap side. thanks.
Old Sep 2, 2001 | 02:57 PM
also how does this setup sound:
No smog
305 with a summit rebuild kit, 8.5:1 comp.
machined, bored block
Heads ported, reworked
full length headers
a performer intake with a 500 cfm carb (daily driver)
true dual turbo mufflers
just a rough estimate on horsepower.
and a streetable cam that is a little lopey
thanks
[This message has been edited by unknown_host (edited September 02, 2001).]
Old Sep 2, 2001 | 06:48 PM
90Iroc-Zee's Avatar
Uh, why not toss in a 350 sb? My friend has a 350 sbc that runs constant 10s. If your gonna pull the motor get a block of a 350 and just build it yourself. Then you have a brand new motor and have the option to do whatever you want with it.
1990 G92 5spd LB9 - 3.42 80,000 miles
Accel Ignition/Wires (8.8mm), Advanced Timing, TB Bypass, Ported and Gasket Matched Plenum, Synthetic Motor Oil, 160 Thermo, TPIS Airfoil, K&N Air Filters, Centerforce I Pressure Plate and Clutch, Edelbrock TES Headers, Dual Cats, Edelbrock RPM Series Catback, Homemade Ram Air, Bosch +4 Platinum Plugs
14.4 @ 94mph w/2.0622 60ft (w/o headers and catback)
14.426 @ 96.19mph w/2.167 60ft(w/headers and catback)
Also newly modded w/o track times:
Holley AFPR, Underdrive Pulleys, KYB Shocks and Struts, Crane Ignition
Old Sep 2, 2001 | 08:11 PM
we have two 305 long blocks and more want a car that runs nicely, sounds good, and knocks down gas mileage. he doesnt have a lot of money so i want to save him the hassle and expense of getting a long block 350. we are set on a 305, i know 350's are better, but we are more gonna do a "which heads are better" "which block is better" swap in. anybody else?
Old Sep 2, 2001 | 09:24 PM
iroc22's Avatar
you gotta go with vortec heads on a 305 if not, porting the stock pieces should provide ok air flow. With the combo you listed there in your post, you should have maybe 250-280 horse or so, which is plenty streetable and should haul nicely in a nove. What year is this nova? I'm assuming '73 up because of the smog junk. Oh and don't bother with a different engine, use what you have. A small block is a small block.
Old Sep 2, 2001 | 10:28 PM
thanks for the reply. actually, we want a block to build up so we can just do a swap one weekend, that was the purpose. also, i just meant whatever block tested better, wasnt cracked or whatever lol. thanks
Old Sep 3, 2001 | 09:22 PM
Nitrous Al's Avatar
Car: '90 Mercury Grand Marquis GS
Engine: 5.0L Ford V8
Transmission: AOD
Axle/Gears: 8.8" Ford, 3.08:1
Skip the 305 and get a 350. You can thank me later.
Old Sep 4, 2001 | 09:58 AM
this is a daily driver that will have to drive to college in another city everyday. like i said above, i am a 350 guy, but this guy needs a car he can drive and knock down good gas mileage. this car's priorities go gas mileage, performance. thanks tho
Old Sep 4, 2001 | 11:57 AM
firebird305's Avatar
I'm about to start helping my wife's 16-year old cousin mod the 305 in his 78 camaro,you should be able to get decent h.p. out of it,and get great gas mileage too.
82 firebird with 305H.O.,Block bored .30 over,Keith black hyperutectic flat top pistons for 10 to 1 compression,Turned crank,Magnafluxed connecting rods,Melling H.V. oil pump,and double roller timeing chain,Ported and shaved heads w/3angle valve job,Z-28springs,Summit push rods and comp cams magnum roller rockers,Ported Edelbrock performer r.p.m.intake,Carter 625 afbcarb,Accell spark plugs,wires,and H.E.I.super coil,Heavy duty cap and rotor,Clevite performance cam with 450-460 inches of lift,Comp cams lifters,700r-4 tranny rebuilt with trans-go rebuild kit,corvette servo,New torQue converter,Flowtech headers,Flowmaster muffler,3.73limited slip rear end,Energy suspension bushings from front to rear,Energy suspension tranny mount,New center link,ball joints,trans-am steering box,ASP power pully.
Old Sep 5, 2001 | 04:13 PM
ChillPhatCat's Avatar
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
Personally, if I were going to get a car for fuel efficiency, I wouldn't get a small block chevy... My car and has a 305 and I get at best 21 MPG... I would bet you get maybe 18 MPG with a well built moderately modified 350 with an easy 300 Hp (new 5.7's get 28 mind you). Of course, my ambition is to make my car into a "sleeper" using my 305... I am sure on my own convictions that it's not that hard... I mean look at the 4.6L Ford (that word makes me shiver).
Go with the 305 if it's cheaper, otherwise I wouldn't concern myself with the difference in mileage and I would get a 350.
1984 Firebird - Daily driver, 305 LG4, T5 - Hurst short shifter, Edelbrock 600 CFM Performer Carb - Edelbrock Pro-Flow air filter, gutted cat, IROC 16x8 Wheels, Goodyear P215/60/R16, AIWA bargain basement (from Sears of course) CD player, Fuzzy dice, Eight-ball shift ****
Check out my ride here $1600!! Bye Bye on board computer!
[This message has been edited by ChillPhatCat (edited September 05, 2001).]
Old Sep 5, 2001 | 11:47 PM
i know in the long run a 350 is better, this is just one of those things where we have 2 nice 305 blocks, not to mention long blocks, and it is just overall cheaper and makes more sense to use a 305 for the buildup. there is literally no guess work for this, we know the blocks havent been raced, and he has driven a 2 barrel 305 with 140 horsepower before this engine. this engine is plenty powerful for the application, the only reason we want a 305 is for a nice rumbly exhaust. thanks for your help all.
Old Sep 8, 2001 | 12:03 AM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
hey what year Nova is it...cuz my bro has a 73 and it came with a straight six...so ya know if ya want really good gas mileage i got the hook up.. .....but anyway....he dropped a cheaply built 355 bout $1200 and put on new manifold and a nice holley and it can beat his friends 97 SS camaro.....and he said he got like 20mpg.....but he was only doin 55mph..lol
84TA T-tops L-69 305HO TH-700R4 stock 190hp and 240 ft-lbs.
new best E.T. (dont laugh) 15.986 @84.93mph
old best E.T 15.997@86.04
http://www.geocities.com/K_towngangsta
Mods-
K&N Air filter
Old Sep 8, 2001 | 03:31 PM
lineb's Avatar
The new 350 get no gas milage. I got a lt1 adn i get like 12mpg. I dont know if its a problem or they really arent very effiecient.
jhawkeye
May 25, 2022 06:33 PM
midge54
Dec 27, 2019 04:14 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
gta90
Sep 15, 2015 04:00 PM
sreZ28
Aug 14, 2015 07:48 PM
