Don't you hate it when...
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
Your cruzin on the highway and you come up to a souped up rice rocket doin way under the speed limit, and when you pass him he then speeds up and wants to race, like give me a break.
What would you do: Give him a smile, drop down a gear and blow the doors off him, or sit back and know that Japanese piece of **** ain't worth wastin your gas on.
87 IROC Z
70' 350(400HP)
5 Speed
Flowmaster Exhaust
87 IROC Z
70' 350(400HP)
5 Speed
Flowmaster Exhaust
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
<font face="Verdana, Arial" size="2">Originally posted by Cruz'N Bruz'R:
</font>
</font>
Check out MyGTA Nicknamed:The Big Red Machine
***AOL IM ClarkeMustGoNow***
Moderator at www.transamgta.com
"What does not kill us only makes us stronger"
Tony
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
How about those ricers that are just lookin' to **** you off just to impress thier friends? I was at a light last night and there's this Honda Accord (mid 80's) behind me... the light turns green and I accelerate at a reasonable pace, this moron floors it and almost rear-ends me... he follows for a short distance and since we both attend the same university, he jerks into the exit lane as I'm pulling into the same lane (I actually used turn signal) He floors it while I'm half way into the lane and so I follow suit, totally leaving him behind as expected... Isn't this a little dangerous? I had little other option than to do the same with all the other traffic around... WTF is going through these dip****s minds?
Edit: What you described doesn't happen that often to me, but I would assume they're just cruzin' lazily just looking for someone to race if the opportunity arises... Well thats the only reason I'd drive so damned slow... but I usually exceed the speed limit so I can't really explain it...
1984 Firebird - Daily driver, 305 LG4, T5 - Hurst short shifter, Edelbrock 600 CFM Performer Carb - Edelbrock Pro-Flow air filter, gutted cat, IROC 16x8 Wheels, Goodyear P215/60/R16, AIWA bargain basement (from Sears of course) CD player, Fuzzy dice, Eight-ball shift ****
Check out my ride here $1600!! Bye Bye on board computer!
Kills:
2002 Subaru Impreza WRX Wagon, Dodge Neon sport unknown year
[This message has been edited by ChillPhatCat (edited September 23, 2001).]
Kills:
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
I was behind a ***** goin like 40 in a 45.. switched lanes to pass, passed him at maybe 60, and he didn't do anything. Silly ricers.
1992 Camaro RS
5.0L TBI
Custom white-faced gauges
K&N Airfilter and ready to take on the world!
My 1992 RS
Down with bin Laden
1992 Camaro RS
5.0L TBI
My 1992 RS
Down with bin Laden
I'd smoke him bad. It really makes my day complete to know that I've beaten the crap out of some ***** pos that thinks his car is so fast because of the coffeecan and stickers and the japanese lettering all over it. Even though he's got 4 less cylinders and 100 less horsepower, it's still satisfying....
I dont ever race ricers. I will run side by side with them and maybe give it a little throttle before 2nd and bark em just to let them knows whos boss. I dont like to waste my gas.
1990 G92 5spd LB9 - 3.42 80,000 miles
Accel Ignition/Wires (8.8mm), Advanced Timing, TB Bypass, Ported and Gasket Matched Plenum, Synthetic Motor Oil, 160 Thermo, TPIS Airfoil, K&N Air Filters, Centerforce I Pressure Plate and Clutch, Edelbrock TES Headers, Dual Cats, Edelbrock RPM Series Catback, Homemade Ram Air, Bosch +4 Platinum Plugs
14.4 @ 94mph w/2.0622 60ft (w/o headers and catback)
14.426 @ 96.19mph w/2.167 60ft(w/headers and catback)
Also newly modded w/o track times:
Holley AFPR, Underdrive Pulleys, KYB Shocks and Struts, Crane Ignition
I would say it depends on how persistant he is with me.. If he wont give up ill blow his doors off.
87' Camaro Z28
305 TPI
Stage 2 hypertech chip
160 degree thermostat
Custom ram air w/K&N's
air foil
shift kit
aluminum driveshaft
posi
VST gas ryder gas shocks
3" flowmasters
Vortex cherry bomb high flow muffler
87' Camaro Z28
305 TPI
air foil
shift kit
aluminum driveshaft
posi
3" flowmasters
I sure am glad I'm not the only bully here! Before I got my 3" cowl hood, stripes and hi rise spoiler, I wouldn't even be looked at to race...EVER. So, if no one would race for a while, and I saw a vtec honda at a light, I'd line up at the light, and when it turns green, give him a good dose of what IROC taillights look like from 12 seconds away.
Car: 99 Formula
Axle/Gears: 342
I was on my way up to college in the mountains, and this was when I had 2:73s gears and minus the 3" exhaust. Well I was doing about 85-90 up a steep part and flew by this Eagle Talon (had fart tip and interior neon lights.) I wasn't trying to prove anything to him, he was going like 65, I was just in a hurry. Well not long after I see him speed up and pass me. I was like ok, like I wouldn't try and race going up a mountain against a Talon. So he slows down next to me and speeds up slows down. So I just downshift and floor it and pull away, eventually I slow down and he catches. And then he finally gets behind me on my tail like way too fu(kin close. So what I always do in that situation is press my brakes enough so the lights come on but the brakes don't. I guess he finally got the picture that I was in no mood to have him on my a$$ and I just let him pass me.
"Rice burners are like tampons...Every pu$$y has to have one"
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
'86 IROC
GM GOODWRENCH 350
KN AIRFILTER
160* Stat
3:73 Posi
Rebuilt 700R4
