06 stang vs. 89 formy
Car: Firechicken
Engine: 350 + 30 over, 400 crank
Transmission: autotragic, stalled
Axle/Gears: not a one tire fire, thank god!
Think open airport parking lot, not at the track.
06 stang, V6, cold air and full exhaust with a tune.
06 stang: its stick, and no suspension mods to bring power to pavement but the car is light and revs to no end.
89 formy, 355 top with ported base, ASM runners, ported plenum, 58mm tb, hooker super comps, full 3 inch exhaust, no cats, AFPR, MSD ignition, etc.
89 formy: AFR 195cc heads, LT4 hot cam, 30lbs injectors, and the suspension to hook, grab, and go with a 700r4 and a 9 bolt. Unfortunately, the car is heavy and holds alot of chrome moly underneath and only revs to 6K-ish.
What the chances that I would win assuming the I'm off the bottle and probably can only muster a 12.8 quarter mile at the track? Just curious before I lose two hundred bucks.
Car: Firechicken
Re: 06 stang vs. 89 formy
I have heard that the mustangs are light as hell and the V6 has over 300 horses stock. I don't know about the hp rating, my GTP has a supercharged 3800 and only makes 260 horses but if the rating on the mustang is close to true, and that is wheel horse, and not crank, I could see how it could be a threat especially with a good stick shift driver and a powerband that never sees any dips.
I understand that it looks to be like I should have him but technology works against me and I'm not familiar with the newer ford engines. Is 300 hp in those V6's right? Is it wheel or crank? Anyone know what they will run with intake, headers, full exhaust and a decent tune? That might give me an idea if I can take him down.
P.S. I forgot to mention that even though the trans in my car is built with Art Carr internals and a corvette servo with trans go shift kit, I'm on a 2200 stall..... Its a long, long story.
Car: 1994 Z28
Engine: 355 LT1
Where are you getting 300 horses from?
They don't do that stock at the wheels or crank. With everything he has he might make 300 crank horse... he'd be lucky to push 250 wheel horse.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 94 camaro z28
Engine: lt1
Transmission: 4l60e
I dont see how it would even be close. You would stop all over a v8 06 mustang with those heads. Hell id say you would have a good run with a stock 5.0 with your list of mods.
Car: 88 Iroc Z, 00 SS
Engine: 5.7 HSR, 5.7 LS1
Transmission: 700r4, T56
Axle/Gears: 3.23, 3.42
210 hp stock for a v6 mustang, I doubt an exhaust, cai and a tune will even put up a fight against your formula, I say go for it.
1 Post
Car: 84 Camaro
Engine: 357
Transmission: TH350
Axle/Gears: 4.10's / Strange LSD
The 2011 on up V6 Mustangs have over 300hp(at the crank) but not the older ones, Either way you should stomp a V6 Mustang unless your tune is way off.....
Mark.
Mark.
Car: 1992 Camaro Z28
Transmission: 86' 700R4
Axle/Gears: 10 Bolt, 3.42's
Dude, my wife has an auto 2006 Stang Vert, CAI, that's it. My 92' Z28 is stock with 3.42's and it whips her all day.
But the fact is that my car is stock. And they make about 254 HP at the crank.
Car: 1989 Camaro Iroc Z
Axle/Gears: 9 Bolt Borg Warner/ 2.77 gear
Car: 1992 Chevrolet Camaro Z28
Engine: 5.7 TPI
Transmission: 700R4 Overdrive Automatic
Axle/Gears: 3.23:1 Positraction
The Mustangs Had 300hp & 320lbs of torque & I had 245hp & 345lbs torque, all 3 GTs were stock, mine has Flowmaster 80's Series 3" Catback, And I Pulled out the Win by at least 15ft Everytime.
1 Post
Car: 1991 Trans Am GTA
Engine: 355
Transmission: 4L60
Axle/Gears: 4th gen 10 bolt 3.42 posi
Lol, why does google or bing not seem to exist to some people?? The mustang has 210 HP and a 4.0 boat anchor for an engine from '05-'10. In 2011, they got the new 3.7 V6 with 305 HP and can put up a better fight, but you'd probably still win from the sounds of what you have. You would beat him with a stock 305 TPI, not to mention a modded 355 lol. Even the new 305 HP mustang can only do high 13's at best, the older ones are in 15's.
92camaroRSV6
02-11-2001 08:53 PM
