Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
l98 vs sleeper
Old Nov 28, 2012 | 05:38 PM
  #51
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: l98 vs sleeper
Lt1's dont run 13's from the factory and yes ,they do have about 230-240rwhp. That you are right about.They run a flat to low 14 second time stock.
Old Nov 28, 2012 | 05:44 PM
  #52
budfreak1's Avatar
Car: 1991 Trans Am GTA
Engine: 355
Transmission: 4L60
Axle/Gears: 4th gen 10 bolt 3.42 posi
Re: l98 vs sleeper
  #53
tpivette89's Avatar
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
Re: l98 vs sleeper
Originally Posted by ninetyone
No,no and no. Your talking about a light Corvette vs an F-body
Corvettes are not light... just cause their bodies are made of fiberglass doesnt mean they're lightweight. C4 Corvettes weigh just as much as a thirdgen, so my examples certainly do apply.
Also, my C5 weighs around 3200, thats 300lbs (at most) lighter than a thirdgen. So take 3 tenths off my C5's times to make up for a thirdgen's weight and you have a 300rwhp fbody in the mid 12s, not mid 13s
Old Nov 28, 2012 | 05:46 PM
  #54
tpivette89's Avatar
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
Re: l98 vs sleeper
Quickest 100% bone stock LT1 fbody has gone 13.4 at 104mph
Quickest 100% bone stock LT1 Corvette has gone 13.0 at 108mph
My 100% stock LT1 6speed '93 Corvette with 80k miles dynoed 266rwhp, the 230-240 range is for an automatic LT1
Old Nov 28, 2012 | 05:57 PM
  #55
zraffz's Avatar
Car: 1987 Camaro
Engine: LQ9
Axle/Gears: 4.10
Re: l98 vs sleeper
Originally Posted by PhoenixFirebird
How did we get so far off topic? I thought we were talking about the Mustang with the Inline12 in it...
I burst out laughing when I read it but get your story straight bro. It was a V12 with 12 turbos and a train blower.
Old Nov 28, 2012 | 06:00 PM
  #56
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Re: l98 vs sleeper
thats turbo
Power is power. 270rwhp is still 270rwhp no matter how its attained. If the gearing matches the car it'll move out nearly the same.
235 Wheel hp in a 3500lb car should pull a lower 14.
There are many examples of L98's in the 230rwhp range making 13 second passes. LT1s do it all the time.
Old Nov 28, 2012 | 06:04 PM
  #57
Re: l98 vs sleeper
Any thread in which Ninetyone posts in will invariably devolve into the smart people vs his stupidity.
You can bash him over the head with the truth, crack his skull open and shove it directly into his brain but he just rejects anything that doesn't fit with his dream view of the world.
Somehow I don't know why I try.
Old Nov 28, 2012 | 06:07 PM
  #58
budfreak1's Avatar
Engine: 355
Transmission: 4L60
Re: l98 vs sleeper
Old Nov 28, 2012 | 07:04 PM
  #59
CashMunson's Avatar
Car: 87 Trans Am GTA
Engine: 408 LS
Transmission: LS 4L60E
Axle/Gears: 9 Bolt/3.70 Gears/TAP Girdle
Re: l98 vs sleeper
post of the day right there!
Old Nov 28, 2012 | 07:14 PM
  #60
CashMunson's Avatar
Engine: 408 LS
Re: l98 vs sleeper
So what you're saying is that only weight and hp make a car run what it runs? Nothing else in there factors in? Not the torque converter, tranny, gears, suspension, tires, track, or the driver? All those things make a huge difference in what a car will run. Hell even the aerodynamics of a car makes a slight difference. Even the damn wind at the track that day makes a difference!
And think about this for one minute there genius... how does torque factor in? Is a car with 230 rwhp and 230 rwtq going to run the same as a car with 230 rwhp and 300 rwtq? It's not all about hp, torque is what gets the car moving. Torque is that little friend that puts a smile on everybodys face when they nail the gas, not hp.
Old Nov 28, 2012 | 07:28 PM
  #61
project89's Avatar
Re: l98 vs sleeper
thats turbo
so what hp is hp anyway u make it, just because it has a turbo doesnt mean it has more power then an n/a 270rwhp car
and to the op if it was one of the 3.8v6 cars with a turbo added ive seen them run 10's.we had a girl that used to race at our local track who had a 3.8 stand with a 70mm turbo that would run mid 10's all day long
Old Nov 28, 2012 | 07:38 PM
  #62
budfreak1's Avatar
Engine: 355
Transmission: 4L60
Re: l98 vs sleeper
Finally found a pic of 91's BMW, just as I suspected.
Old Nov 28, 2012 | 08:03 PM
  #63
budfreak1's Avatar
Engine: 355
Transmission: 4L60
Re: l98 vs sleeper
LMAO!
Old Nov 28, 2012 | 09:29 PM
  #64
zraffz's Avatar
Car: 1987 Camaro
Engine: LQ9
Axle/Gears: 4.10
Re: l98 vs sleeper
But a small turbo motor that achieves 270RWHP will generally achieve more torque than an N/A 270RWHP
Old Nov 29, 2012 | 07:13 AM
  #65
88FormulaF_Bomb's Avatar
Car: 1988 firebird formula 350
Axle/Gears: 2.77
yep like i said turbo lol
Posted from Thirdgen.org App for Android
Old Nov 29, 2012 | 07:28 AM
  #66
Axle/Gears: 2.77
im not tryin to argue that. but if its true why do i have 230 hp & 330lb but my friends 2.5t makes 276hp and 270lb. if two engines one, a small turbo engine. and the other a large naturally aspirated engine if they both have exactly 300hp shouldnt the bigger engine make more torque?
Old Nov 29, 2012 | 07:30 AM
  #67
Axle/Gears: 2.77
honest question not trolling
Old Nov 29, 2012 | 07:53 AM
  #68
Re: l98 vs sleeper
Greater displacement. Its well known that the buick 3.8L Turbo motors made more torque than TPI motors did, and in the same power band too.
The TTA 3.8 was rated at 250hp @ 4400rpm, and and 340lb/ft torque @ 2800rpm. That TQ comes in even sooner than it does on a TPI 350 car under boost. And we all know that the TTA motors were under-rated since they pushed the TA to mid 13's @ 101mph officially.
Old Nov 29, 2012 | 08:10 AM
  #69
Axle/Gears: 2.77
ooo i thought it was because factory gm heads have small intake ports resulting in torque early in the rpm range. *palm to forehead*
Old Nov 29, 2012 | 02:15 PM
  #70
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
Re: l98 vs sleeper
You keep changing how much hp your car makes with every post.
Old Nov 29, 2012 | 02:42 PM
  #71
Axle/Gears: 2.77
dude STFU with your bitch as$ knitpicking you sound like the grouchy old man on the block that narcs on kids for smoking.
230 hp is what my car left the factory with.
200 hp is how much i assume i have left after 24 years of abuse.
150 hp is how much i assume i currently put to the ground.
each number i put is relative to my power output .so please if u have any other comments feel free to bottle them up inside because i have no respect for your opinion and have no intent on ever replying to you again. good day sir
Old Nov 29, 2012 | 04:28 PM
  #72
Guest
Guest
Posts: n/a
Re: l98 vs sleeper
Wow. Children, children....
Old Nov 29, 2012 | 05:44 PM
  #73
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: l98 vs sleeper
im not tryin to argue that. but if its true why do i have 230 hp & 330lb...
It depends on where your getting those readings from. If your getting those two readings at the same exact RPM range down low then that is normal, but if your getting 330 pound feet of torque down low, and 230 horsepower up top, then what this should be telling you is that your engine, potentially, should be making more horsepower than that, but the reason why it isn't is because it can't breath. Remember, horsepower is calculated torque, but both rely on a certain amount of air and fuel to make their numbers, and as RPM increases, the demand for more air and fuel increases. Otherwise it becomes stagnant...
Old Nov 30, 2012 | 07:56 AM
  #74
Axle/Gears: 2.77
yes sensai. understood
Old Nov 30, 2012 | 03:40 PM
  #75
Dakota W.'s Avatar
Re: l98 vs sleeper
It doesn't bother me, I understand he is working with some mental issues right now, as well as some family issues. It's unfortunate, but he has to show his emuscles because that's all he's got. Plus, it's funny to see a troll get angry .
91chevyz28
Feb 10, 2022 07:58 PM
Prodigious
35
Apr 13, 2021 02:37 PM
FormulasOnly
Jul 23, 2018 08:47 AM
Nervous2
Oct 8, 2015 10:53 PM
Tarizza
Sep 24, 2015 12:57 PM
