Looks like you are ever so slightly out gunned on some of that video. Talk about making you push ever so much further.
All that bumping into each other business would have me ready for a fist fight.
Any reason you chose a LT1?
Cool!! I love seeing a T/A on a road course!
good video, and good driving
Was that footage from the Nationals or just a regular weekend?
I struggled with power issues all year. Just not up to par. Did a midseason engine rebuild which helped but I still have an issue with being too rich. The Lt1 came in the car when I bought it. Plus the rules of CMC only allow certain engines.Originally Posted by ZONES89RS
Looks like you are ever so slightly out gunned on some of that video. Talk about making you push ever so much further.All that bumping into each other business would have me ready for a fist fight.
Quote:
This was footage from different weekends. I couldn't make nationals as my engine was in pieces at that point.Originally Posted by RS Chris
Was that footage from the Nationals or just a regular weekend? Supreme Member
Well, there any cam limitations? Help make a bit more power.
Thirdgen89GTA
close
Spotted one of the Car Club guy's 4th gens in several shots in that video. Orange/Blue 4th gen bird CMC car.
Good Music choices.
Good Music choices.
Quote:
Not allowed. The motor should make the power it needs to but I need to figure out what is still wrong with it. It is off the charts rich over 4700rpm.Originally Posted by ZONES89RS
Well, there any cam limitations? Help make a bit more power. Thirdgen89GTA
close
Quote:
Doesn't happen to be a B-body lt1 running an fbody tune is it?Originally Posted by wastntim
Not allowed. The motor should make the power it needs to but I need to figure out what is still wrong with it. It is off the charts rich over 4700rpm. Cam and heads are different between the two. Cam is much smaller in the bbody.
So, ported heads and a stealth cam are a nono?
Quote:
CMC is REALLY strict. You have to have dyno sheets every season to prove you're not making too much power. The idea is to keep costs down by keeping the engines mostly stock.Originally Posted by ZONES89RS
So, ported heads and a stealth cam are a nono? Supreme Member
I understand, but pulling timing to lower the reading on the dyno is not big feat. I want an edge, even if it is a small one.
TTOP350
close
- Join DateOct 2001
- LocationIl
- iTrader Positive Feedback100
- iTrader Feedback Score(9)
- Car1989-92 FORMULA350 305 92 Hawkclone
- Engine4++,350 & 305 CIs
- Transmission700R4 4800 vig 18th700R4 t56 ZF6 T5
- Axle/Gears3.70 9"ford alum chunk,dana44,9bolt
- Liked:1,148 Times in 749 Posts
I have run on the Autobahn in a few cars. Good times! I have also helped dyno a few CMC cars at a old job I had.
