My 1988 gta vs 97 cobra
Car: 1988 Trans am GTA
Engine: 5.7 tpi
Transmission: auto
Axle/Gears: 3.27 posi
Hey guys how will I do my mods are 383 bored.40 over mild rv cam flat top aluminum 11.5-1 compression stock tpi set up manifold back no cat into a cherry bomb pro series msd cap and rotor
Car: 1985 Camaro SC F41
Engine: ZZ4
Axle/Gears: 3.42 Posi
Re: My 1988 gta vs 97 cobra
The 1997 Ford Cobra was a (281) 4.6L 4v DOHC hand assembled engine producing 300hp/305 tq with a t56 transmission and I think 3.73 rear end. So assuming your competitor is running a high mileage stock engine thats 100 cu in. smaller than yours, you should beat him; but often it can come down to the driver. Did you beef up your trannie when you went to the bigger motor? Are you running the stock 305 intake runners expecting to adequately feed air to the 383?
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
Car: 1989 IROC-Z28
Engine: L98 - 350 TPI
Transmission: MD8 - 700R4
Axle/Gears: GH3/G80 - 2.77 POSI
Car: 1989 IROC-Z28
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
