Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
Accuracy of "1/4 Mile E.T. Calculators" ?
Old Oct 18, 2020 | 06:18 PM
ez2cdave's Avatar
Car: 1989 Camaro IROC Z
Engine: 383, soon to be an LS Stroker
Transmission: 700R4 - Switching to 4L80E
Axle/Gears: 10-Bolt/3.42 will be Moser 12-Bolt
You know . . . The ones where you enter your car's weight ( with or without driver ? ) and either your Torque or HP, either at the Flywheel or Rear-Wheel numbers.
QUESTIONS :
(1) Do they only rely on Peak Torque or Peak HP ?
(2 ) How accurate are they ?
(3) Are there any "online calculators" that would let you enter data from a Dyno Chart, all throughout the RPM range ? ( It would be really cool if you could also enter transmission gear ratio's and ring & pinion ratio and run it through all of the gear changes, too ! )
Old Oct 18, 2020 | 07:23 PM
NoEmissions84TA's Avatar
Re: Accuracy of "1/4 Mile E.T. Calculators" ?
Desktop Dyno 2003 has #3 built in.
Old Oct 18, 2020 | 08:12 PM
ez2cdave's Avatar
Will it allow for a simulated combination to be "run through the gears", all through the RPM range, by inputting Torque & HP numbers at various RPM levels ?
In other words, will it allow you to "virtually drag race" the entire combination ?
Old Oct 18, 2020 | 09:09 PM
Well, yes and no. DD 2003.
It's an old program, so how detailed do you expect it to be?
But it's free, so download it and have fun.
You input your engine parameters into DD2003 and then they transfer to Drag2003 where you can do that simulation.
I have the program, the head flow files, and the engine files. But you can no longer email them because email now blocks those type of files.
Of course there are now newer and more detailed and accurate programs, but you will pay $$$ for them.
Old Oct 18, 2020 | 09:24 PM
ez2cdave's Avatar
There is another way . . .
https://wetransfer.com
Old Oct 19, 2020 | 06:44 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Some are pretty accurate, usually et is alittle quicker than actual since most cars are not set up perfectly to use its power. A well optimized drag car might get closer.
its good enough for an estimate if you know your hp and weight
Old Oct 19, 2020 | 09:53 AM
ez2cdave's Avatar
I was thinking of using it to optimize cam event choices and gear ratios ( transmission & rear end gears ), by being able to "virtually drag race" the vehicle, up through all gears, using Torque & HP data throughout the RPM range.
Old Oct 19, 2020 | 11:20 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
None that i know of do that. They seem to work off a peak hp value.
you could try to take average hp across the curve that is used for a track pull and use that as the estimate. Higher average hp should run the fastest. Then again it depends on rpm too, two motors that have same average power but one makes that power at a higher rpm will have a slight advantage at the track.
this would assume you have a very good engine simulator to get power curves based on small changes in cam events. Desktop dyno is not it lol. Think engine analyzer pro or better
Use peak power to determine what mph to expect in the 1/4 and then use your power curve rpm range and tire sizes to get gear ratio and optimal shifts based on trans gearing and dyno chart average power. It can be done i guess but seems like a lot of work for marginal accuracy at prediction
Old Oct 19, 2020 | 11:27 AM
ez2cdave's Avatar
Thanks . . . Not the answer I was hoping for, but it was the one I expected, based on comments here and searching the internet.
Old Jan 4, 2021 | 06:14 AM
86Lucille's Avatar
http://www.gearcal.com/
Old Jan 4, 2021 | 11:49 AM
ez2cdave's Avatar
Originally Posted by 86Lucille
Thank you for the link . . . Very Interesting !
Old Jan 6, 2021 | 04:43 PM
86Lucille's Avatar
You’re welcome
Old Jan 6, 2021 | 11:37 PM
IROCZman15's Avatar
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
cool. I just played around with that gearcal.com site a bit, swapping from a 3.55 gear to a 3.91 in the next few weeks.
thanks for posting it
Old Jan 7, 2021 | 08:27 AM
427seven's Avatar
Car: 1989 Firebird GTA
Engine: Motown Aluminum 427
Transmission: TH400/GVO
neat graphic. fer all the arm chair hotshoes remember that the desktops always make assumptions about traction, -- which is the key to obtaining time.....
Old Jan 7, 2021 | 08:03 PM
86Lucille's Avatar
No ones arm chair racing.
Old Jan 9, 2021 | 10:55 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
I put my Hp and time into the 1/4 mile calculator and it said I suck and should let somebody else drive.
Well, nobody is talkin' time slips either, so.....
skinny z
31
Nov 8, 2009 07:15 AM
seaaldo
39
Mar 4, 2008 06:50 PM
bluegrassz
Oct 28, 2006 10:05 AM
Kevs87TA
42
Jun 23, 2002 01:27 PM
johnyIROC
May 4, 2001 11:50 AM
