Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
400hp+ Firebird formula
Old Mar 2, 2002 | 02:43 PM
1992_25t_1letpi's Avatar
One of my dads co-workers has an 80-81 firebird formula. It has a 350 c.i. with many mods including a cam and bored out. He says he got about 400hp, and its an auto. what do you think his 1/4mile time should be around if he is telling the truth. I know it should be faster than my car but by how much would you say???
Old Mar 2, 2002 | 04:04 PM
RB's84camaroF-41's Avatar
too many variables to deal with. rear end gearing, convertor stall speed etc....... there is no doubt its faster than you but i would guesstimate with the right gearing that car could go 13.3-5
Old Mar 2, 2002 | 06:45 PM
matt87's Avatar
400 flywheel hp or 400 rear wheel hp? thats a big big difference. either way hes gonna be in the 11-13 sec range depending on other supporting parts. if hes not fibbing.
Old Mar 2, 2002 | 07:13 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I gotta agree here, with the right setup he into the 12s.
Old Mar 2, 2002 | 07:50 PM
SoCo80p's Avatar
damn i thought i was the only one, he must have ripped off my idea
Old Mar 2, 2002 | 09:55 PM
His car isn't half as good/cool as your man, his is like a sleeper or something. His body is not the best and when you pop the hood everything is rust except his shiny motor
Old Mar 2, 2002 | 10:46 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Considering how much more the 2nd gen cars weigh and the fact that the typical pine cone with one thinks adding a cam will give 400hp in an otherwise stock 350, you should hand him his posterior.
But if he has half a brain (or a tad more) and is running a motor with something on the order of AFR or Brodix heads and the associated supporting parts, he could have 400hp. Then again 400hp in a 3800lb car is the same as having 360hp in a 3400lb car, so the extra weight is his problem. The car would only run in the mid 12's or so if that is the case. If it has 300hp or less, it may not even break into the 13's.
Oh yeah, since its an auto, ask him to race from about 100mph on up, he wouldn't have OD with a stock TH350.
Old Mar 2, 2002 | 11:40 PM
Yeah, his car has had some head work to i beleive that is what he said. I will get somemore specs on the car in the next few days like his gear ratios and stuff
xkingcodex
Feb 12, 2020 07:43 PM
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
theshackle
Mar 5, 2017 06:37 PM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
1989formula5.7l
Aug 17, 2015 02:56 PM
