Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
whinning in the rear??
Old May 3, 2002 | 09:40 PM
92zeddar's Avatar
I had a little bit of whinning in the rear for as long as I have had my car.. i put a new Auburn in it last year and that did nothing... now just today I put a Hotchkis LCA's and Panhard rod and it has got worst.... It only happens when I let off the gas.. If anyone could shed some light on this they will solve a huge annoying problem...
Old May 3, 2002 | 09:56 PM
Snowdog 91 Formula's Avatar
Have you had your wheels balanced recently?
Old May 3, 2002 | 09:59 PM
92zeddar's Avatar
No I haven't... my tires are bald..hehehe but it did it even when I put new tires on it...hmmm...
I will be buying new tires soon though..
Old May 3, 2002 | 10:05 PM
Snowracer's Avatar
Have you ever checked the runout on your rear Disc/Drums? ......Just a thought if they are a not quite true they will hum a little (all the time,but your most likely to hear it under deceleration)......SR
Old May 3, 2002 | 10:06 PM
New tires yes, but did you have them balanced properly? If they are out of balance it is the most aggravating thing in the world!
I'm pretty sure that's it.
If not, it could be your wheel bearings too. Those things make annoying noise when they are out of whack too.
Old May 3, 2002 | 10:10 PM
92zeddar's Avatar
but why would it get worst if I put LCA's on?
and what is the proper way of balancing?? weights on the outside of the rim.. not inside..
Old May 3, 2002 | 10:11 PM
92zeddar's Avatar
the runout? I put new disc's on it last year..and they spoun really freely with the new pads... maybe I am not sure what you mean by it?
Old May 3, 2002 | 10:40 PM
Snowracer's Avatar
Even with "new" disc's there could be excessive runout (wobble) if it's really bad you will get a shudder under braking, but if it's not excessive it could just be lightly dragging on the pad's....
I make it a habit now (after not checking and putting defective"new" disc's on my wife's old cavalier)to install the disc's and then set up my dial indicator and check to make sure that the disc's are"true"it takes 5 minutes and saves time later. Even if the disc's are straight when installed all it take's is one hero with an air gun to warp them.
But your right LCA's shouldn't make that or tires worse how bad were your old bushing's in your LCA's? by installing these part's does it change your pinion angle?Ie.. is your U-joint at a slightly different angle then before?Even if it feel's tight it could have some bad roller's in it...This also will cause a hum under deceleration (at least till it go's clunk ).........SR
Old May 3, 2002 | 10:44 PM
92zeddar's Avatar
I think it does change the angle a little bit.. hmm.. I wil have to look into all of it..
Old May 4, 2002 | 12:53 AM
ROCHEAD's Avatar
when your gears are not perfectly installed correctly, the back lash and so on, you will hear a whinning noise. The same when your rear is about to go boooom. Get it out and inspect it or have someone inspect it . Has nothing to do with your brakes or bearings, if it was your bearings, they would have failed by now for sure. Ive done some rears with a friend, and two out of the three, there was a whinning noise, and the rear 's were shot to shiet.
Old May 4, 2002 | 01:02 AM
nblanchard's Avatar
My buddy has a bent axle housing on his 1995 Camaro, makes a hefty noise.... do you recall hitting something hard enough to bend it?
Old May 4, 2002 | 06:38 AM
92zeddar's Avatar
No i don't remember hitting anything super hard.. hmmm.. I have had that whine since I bought the car in 95..
Old May 4, 2002 | 08:16 AM
trigger GTA's Avatar
Car: 92 TA vert
i have to go with Rochead on this one. gears for sure. The reason they sound even worse now is becasue you have changed the geomitery of how they mesh together with your new Hotchkis LCA's and Panhard rod. you only hear them when you foot is off the gas because they are not under load and tend to float a bit causing them to wine.
other causes could also be
Worng lubricant in rear axle
worn bushings
or pinion bearing noise
but most likly what you are hearing is just gear noise. any one that has had a new set of gears can tell there is an increase in noise. usally lowdest at about 80km
Old May 7, 2002 | 09:15 AM
92zeddar's Avatar
well everything is tight and it looks good so it must be that the gear have some slight where on them that is making them whine.
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
