Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Here we go again....
Old Aug 12, 2002 | 09:09 AM
Cruz'N Bruz'R's Avatar
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
Snapped an exhaust rocker in half last night.
Here it sits in the garage for G.od knows how long now.
Old Aug 12, 2002 | 03:19 PM
Stroked-Z's Avatar
Well i told you it didnt sound right at all.
Tonight we'll be fixing it so no worries.
Old Aug 12, 2002 | 05:07 PM
johnyIROC's Avatar
Holy CRAP! How do you guys manage to do this to new engines? It's like De Ja Vu with Paul's pushrod incident.
I'm sure you'll get it all back together... If I were you I'd rebuild it yourself. Don't let this "engine builder" near your car again.
Good luck, and make sure you check all the valves, pushrods and lifters... if you snapped a rocker, chances are there was some good stress on the whole valve train.
Old Aug 12, 2002 | 11:08 PM
Stroked-Z's Avatar
Well.....1 bent pushrod & some other probs.
Going to have to do a compression test & make sure there's no broken rings or bent valves....
After that if it checks OK we pull the intake and check out those cam lobes/lifters....
If that check out we pull the timing cover & make sure the cam isnt off a tooth.
There is defietly something wrong other than timing & carb....IMO.
He'll be OK though, just gonna have to work out his moron builders ****-ups
Old Aug 13, 2002 | 09:29 AM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
Amen. His neck is somewhat red.
Old Aug 13, 2002 | 09:43 AM
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
Called the old man today and told him what went down...
I also told him not to let that cracker touch his car EVER.
He was somewhat defensive, then i told him what was going on.
Carm, he said that it's always sounded like there was a bad lifter in that back passenger area, but Craig.aka. Cracker, said it just need to get pumped up with oil. So I'm wondering if that noise we're hearing is the bad lifter, in which case i have some extra's a dad's place from the 350.
I hope to G.od it's JUST a bad lifter, if compression test fails.... oh ****!
Old Aug 13, 2002 | 10:22 AM
Kevin Vandevenne's Avatar
Car: 87 IROC
Sorry to hear about the bad luck dude. Sounds like you have the right folks helping you out now though, and hopefully you guys can get that motor sorted out.
The engine builder, does he run his own shop? Is he a family friend? Did he provide any warrantee with the motor? With all the screw ups this guy has caused, I'd seriously consider trying to get some form of compensation. Keep a good record of everything that has gone wrong with the motor, it may be useful in the future.
Old Aug 13, 2002 | 10:39 AM
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
This guy is just a friend of my dad's that he met when he painted my car. He came over and did all the work assembling the motor in my Dads garage. I can't really do to much other than let my Dad know how I feel cause he's still friends with him, and plus dad paid for the motor till i can get a job.
Which by the way guys, I have a 4th interview tomorrow in which they're making me a salary offer!!!!!!!!
Old Aug 13, 2002 | 11:55 AM
Stroked-Z's Avatar
DAVE.....if that has always sounded like that the intake must come off.
You might not like what it looks like uder there. When you overtighten a rocker that much, usually it really screws up the lifter (flat-tappet style, as rollers are more forgiving).
If you have a concaved lifter, there is a very likely chance the cam lobe is ****ed as well.
We'll have to take it one step at a time. Although it would be nice to know whats going on uderneath the intake, we'll start to see if the valves are all holding first.
I hate rednecks. And i hate when people get screwed from builders. It's happened to me, and it definetly wont anymore.
Also, you cant re-use a lifter (flat-tappet be it hydraulic or solid) on any other cam other than the one it came from. And it is lobe specific as well, so you cant just put it on any lobe. This is why you have to keep the lifters in order if you plan on re-using them.
We'll see how it goes. My intake is coming off tonight, it will be back on tommorrow. And Thurs we may rip yours off & see whats going on under there.
Old Aug 13, 2002 | 01:06 PM
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
Sounds good. Don't forget about that compression tester from your buddy. If I can get it, me and paul will test the cylinders tonight or tomorrow. Then, maybe we'll pull off the intake just incase to see what it's like.
The cam better not be screwed, cause I certainly don't have the cash for a cam.
Old Aug 13, 2002 | 04:22 PM
Buddy's Avatar
Car: '87 FIREGOOSE!!!!
He may be your Dad's friend, that doesn't make him an expert, when, from the sounds of things, he is clearly NOT. Friendships and constant f**k-ups don't mix, you can go somewhere else for help and still have your father and him be friends, if he's any kind of guy, he'll feel bad, but want you to have a reliable car, he shouldn't be offended. Your the one suffering now. Take it elsewhere.
Old Aug 13, 2002 | 04:52 PM
Slade1's Avatar
If anything breaks on my car I have no one to blame but myself...
The good and bad aspects of rebuilding yourself.
As much as friendships go, I'd pay the extra cash if it meant I'd have a 100% reliable car... for me I have no choice, my car is way to meshed into my lifestyle that any f-up no matter minor can hurt me badly...
Do it once, do it right...
Old Aug 13, 2002 | 08:54 PM
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
I have the right guy helping me now for sure.
If any of you ever get to hear/see Stroked Z car, you'll know what i mean. And he does all his own work. I'm sure he can definately teach me alot of stuff in the process.
Old Aug 14, 2002 | 01:16 PM
Stroked-Z's Avatar
The only thing i ask in return is for you to BRING THE BRAWDZ
Old Aug 14, 2002 | 03:06 PM
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
What BRAWDZ? You've seen where I live. They hide there daughters out in the barns for a reason out here...
Old Aug 14, 2002 | 04:10 PM
Buddy's Avatar
Yeah, cause in most cases their also their sisters and brothers as well. LOL
Old Aug 14, 2002 | 06:48 PM
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
There are some crazy sweet girls around here, but touching them will land you in the penn doing 10-20
Old Aug 14, 2002 | 07:41 PM
Slade1's Avatar
It's now official... you're a dirty old man!
Old Aug 14, 2002 | 08:08 PM
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
I'm not THAT old, but sometimes I feel it. Wanna hear terrible luck...
Sunday night Camaro breaks, Tuesday afternoon, wife calls Sunfire crapped out( it was nothing big)
TODAY!!! My Tempo catches fire!!!
My wiring harness rubbed through and grounded itself out at the alternator side and literally caught on fire(the wires).
I ripped off the rad support, and ripped the wiring harness out.
Ordered a new one from the wreckers, what a week.
Old Aug 14, 2002 | 09:50 PM
Slade1's Avatar
Correction: dirty, old and has really bad luck...
my mistake...
mwa ha ha ha ha ha
just kidding!
Sorry to hear all that.. man must be a curse week or something...
Last curse week you guys gave me a code 32 egr at the end of the week... I swear if anything goes wrong I'm haunting you from the grave!!!
Manic Z
Sep 20, 2012 04:25 PM
2camaros1kid
May 17, 2012 11:05 PM
travisgold
May 3, 2012 10:39 PM
Street Lethal
Theoretical and Street Racing
Jul 26, 2009 03:14 PM
Brian92RS
May 17, 2001 08:09 PM
