Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Got Traction?
Old Aug 24, 2002 | 04:03 PM
johnyIROC's Avatar
Got Traction?
Thanx for the hookup darbleinad!!!!
Old Aug 24, 2002 | 04:47 PM
darbleinad's Avatar
Car: 84 Trans Am
sweet....those slicks look killer.....i love the white lettering......man i cant wait till i get mine..plus they look like they fit okay too
Old Aug 24, 2002 | 04:51 PM
ninety1TAgta's Avatar
Wheelstands in no time...
Old Aug 24, 2002 | 06:36 PM
trigger GTA's Avatar
Car: 92 TA vert
oh boy
Old Aug 24, 2002 | 06:46 PM
Car: 92 TA vert
i guess you did not like being smoked at the line
Old Aug 24, 2002 | 08:18 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
any good prices for a 16" rim?
Daz
Old Aug 24, 2002 | 08:22 PM
darbleinad's Avatar
Car: 84 Trans Am
i dont know if my cousin can score slicks to fit a 16" rim or not. the jason and i have are used cascar slicks. they are 27" tall, 9" wide and fit on a 15" rim. they were 40 bucks, no tax, mounted and balanced. if you want some 16s..i can ask if he can get them.
Old Aug 24, 2002 | 09:59 PM
cascar slicks
hey if you could hook me up with a set of those cascar slicks for 40 bucks that would be amazing! Where would I have to pick them up?
Old Aug 24, 2002 | 10:03 PM
errr they would have to be 16 inch though. 15 inch rims rub my calipers.
Old Aug 24, 2002 | 10:37 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
i want i want i want..on 16"ers
Daz
Old Aug 24, 2002 | 11:52 PM
Kevin Vandevenne's Avatar
Car: 87 IROC
I've got 3 sets of those out back in my shed right now. Cost $0
A friend of mine used them on his 81 Camaro. They hooked up very well, and are well worth the $$. They may not work as well as a 'drag' slick, but they'll be pretty close. With those tires he was able to cut a 1.5 60ft on with stock suspension in his 81. He had 4.56 gears though
Old Aug 25, 2002 | 03:17 AM
johnyIROC's Avatar
[F&F]It doesn't matter wether you win by an inch or a mile....[/F&F]
Looks like your gunna have to get back in that shop and do some more work!
HEY SLADE1! Run the numbers and find out how what I need to carry the front end!
My car weighs 3,250 in race trim.
Old Aug 25, 2002 | 09:04 AM
Car: 92 TA vert
cat back is now on and the headers will be on order Mon
i dont think i will need any more than that.
Old Aug 25, 2002 | 10:33 PM
johnyIROC's Avatar
You think your going to break into the 13s with headers... This will be a good race!
Old Aug 25, 2002 | 10:58 PM
Car: 92 TA vert
no i never said that.
you think you can break into the 13s with worn out cascar tires
Old Aug 25, 2002 | 11:08 PM
johnyIROC's Avatar
Provided nothing explodes.... it could be close. I'm trapping at 99.x MPH.
Old Aug 26, 2002 | 05:34 PM
Car: 92 TA vert
so you dont think i can hit 13s with headers and a cat back?
Old Aug 26, 2002 | 05:52 PM
johnyIROC's Avatar
It's possible... but I was trapping higher than you before I put my headers on.
I think you've got another potato stuck in there somewhere... I think it's you need a chip. A chip, an aftermarket TPI rig... and headers will see you into the mid 13.xxs no prob.
Old Aug 26, 2002 | 05:56 PM
Car: 92 TA vert
my time slip when we race show you at 99.71mph and that is with your headers!
unless your headers did not help your trap speed at all
Old Aug 26, 2002 | 07:28 PM
Slade1's Avatar
Trigger, without a chip, the ecm defaults to the regular air fuel rpm tables for the stock setup, bypasses O2 sensor completely for fuel delivery... by my accounts you are running very very lean on that setup at WOT...
to be sure hook up your o2 sensor to a multimeter and read the voltages.. should be 0.875 - 0.950 V is good for WOT..
Old Aug 26, 2002 | 07:53 PM
Car: 92 TA vert
slade if that was true then i would see a better time at the track and more HP on the dyno when i bumbed the fuel psi up. But i did not
Old Aug 26, 2002 | 07:57 PM
Car: 92 TA vert
but i will check it out never the less and let you know what i find
Old Aug 26, 2002 | 09:18 PM
Slade1's Avatar
Part throttle will give erratic readings, just it's way of showing you its doing its job. The only way to test is to go on wot runs on the open road. 3rd gear load test is the key one, or for stick 1:1 ratio ie fourth gear. I'll be in Waterloo tomorrow afternoon, if ya want I can swing by with my multimeter, it has a record mode perfect for checking min/max/avg readings... wish we had some dyno of our own to test these things, makes it a lot easier no cop worries...
Old Aug 26, 2002 | 10:29 PM
johnyIROC's Avatar
What is your highest trap speed thus far? I am trying to dig out some old slips before I put the headers on. I think the headers will get you very close to a 13...
Old Aug 26, 2002 | 11:03 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
Trigger, you can have my Ed Wright chip after Gerrit makes me a new one. It was burned for a setup identical to yours.........355, medium size cam, long runner, 10.5:1 compression. That's if you want it.
Old Aug 27, 2002 | 04:52 AM
Car: 92 TA vert
95.5mph seems to be what i run most of the time
Paul. yes yes yes i will try it
Old Aug 27, 2002 | 04:33 PM
johnyIROC's Avatar
I hit 95 MPH before my headers... so I am guessing that you will be running somewhere in the low 14s with your headers installed. I think the chip is the key to unlocking your power.
Old Aug 27, 2002 | 04:36 PM
Car: 92 TA vert
Best time 14.47 at 95.89 MPH with present set up.
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
Numbah-1
Sep 12, 2015 08:57 PM
dbrochard
Sep 7, 2015 09:41 AM
IROC Z Z28
Aftermarket Product Review
Sep 9, 2001 11:06 PM
