Burnout questions
Car: 1984 Z/28
Engine: 383 stroker
Burnout questions
I have done a few runs with my '84 Z and I thought I'd throw it out to you guys about the best way to do a burnout. I don't have a tranny brake or anything like that. I can smoke the tires, but not without moving forward...which kinda presents a problem at the track. I have the stock T5 (I believe it is) 5-spd tranny (for now). I would love to hear your recommendations as far as how to do a better burnout with the equipment I presently have. I know I could have great improvment with better equipment, but I have to wait until I have some bills (OSAP) paid off.
Thanks guys!
Tracey
Thanks guys!
Tracey
Car: 84 Trans Am
with the times you are running and the fact you are using street tires, you dont need to heat them at the track...it might even be worse for you, plus it will waste your tires. street tires arent designed to stick better after being melted in a big smoking burnout. i never do burnouts at the track with my street tires. occasionally i will give them a quick spin to get rid of any dirt/stuff that may be on them...thats it. my new cascar slicks however.....you really have to heat those pieces up to get them to stick.
Car: 1984 Z/28
Engine: 383 stroker
OK, sounds like I was on the right track. I wasn't doing them either. The tires bite pretty good. I just didn't see anyone else not burning out and I kept getting directed into the burnout box by track officials. I guess they were just figuring I'd want to cuz everyone else did. Thanks again...
Car: 84 Trans Am
well you can do a burnout if you want...i just think you will be wasting rubber. i always just drive around the burnout box.....dont drive throw it and not do a burnout...you will have wet tires and that is much worse
Certain brands of street tires respond to a little heating, but there is no need to smoke them through 5 gears like a pro mod. I'm not sayin it's not fun.... just isn't necessary.
I can verify that the CASCAR units definitely need to be heated.
I did a somewhat burnout just for a burnout picture at the track... and i was surprised I managed a 2.069sec 60'
If you ever want to do a smokey burnout for fun, I was told to just get the tires going and get on the brakes right away.
Car: 85 iroc z
Engine: LG4 :(
Transmission: 5 speed
However if you want to do a burnout for fun the way i've done it in the past is I heel the brake and use the toes on the gas. It's kinda tricky and may need a little practice but it is the best way to do a burnout with a manual trans and no linelock.
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
2.069 ???
RP.
Car: 1984 Z/28
Engine: 383 stroker
Cool. Thanks peoples! It looks like I was pretty much on the right track. I just wanted to hear from you guys and see what you had to say. I'm looking forward to Friday at Cayuga! Cheers!
Tracey
Tracey
I would have to say it does help but its not needed by any means unless you got slicks. I definately know my street tires like being heated up for traction. At normal temps I can just nail the gas and spin em till 2nd before they hook up at all. however after a burnout If I nail it my tires let out a big screech but more or less dont sit there spinning. BF goodrich 275s if it matters... Thats just me so I have no idea what it does for others.
If I was doing one with a manual though I would just go with heel and toe idea like corbi mentioned.
Line lock would make it alot easier on the car, basically locking your fronts and leaving no pressure on your backs. The electro solenoid and in the car switch line locks range from 100-200 canadian funds. If you dont mind getting out to activate it you can do it for about 20 bucks hardware.
GVMV
Aug 16, 2015 08:01 PM
novaderrik
Aug 10, 2015 12:44 PM
