Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Setting valves
Old Oct 26, 2002 | 02:42 PM
Sostar18's Avatar
Setting valves
Hey guys ..This is Stiffler! Over at Sostar18's house trying to set the valves.. 2 weeks ago he busted a rocker arm. So we replaced it and set the valve's... We hand cranked it over and checked the valves and they were lose again.. So we thought it was the nuts..bought some new nuts and the same thing happens. Also we had the engine running with the valve covers off and we are noticing no oil spurting up.. whats up.. need some advice men...
Old Oct 26, 2002 | 04:17 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
If they're new pushrods, it may take some time for the oil to build up and pump thru, I know this happened when I installed new ones.
Old Oct 26, 2002 | 06:21 PM
Slade1's Avatar
Are they self aligning rocker arms?
If so, you'll never get it right because the pushrods will just drop down on the plunger everytime you tighten it giving you a false impression. You end up overtightening it.
If so you can set them while the car is on, put on like 3-4 threads worth prior to starting then back it off till it clacks then give her a nice 1/2 turn to tighten.
As for why oil's not gushing, that's kinda odd. Take out each pushrod and run them through some varnish to see if you can clear up and build up of gunk that may have formed in them. While they are out, do the glass roll test to see if they are straight.
Mine sprayed oil as far as 2 feet...
Old Oct 26, 2002 | 06:52 PM
johnyIROC's Avatar
Set them with the engine running.
Do them one at a time with this procedure:
1. Loosen until you hear "ticking"
2. Tighten until ticking stops
3. Tighten 1/4 turn more
Old Oct 26, 2002 | 08:13 PM
STIFFLER's Avatar
Sweet guys.. I set them hot with the engine running just gotta close it up now... Thanks Guys!
lakeffect2
Aug 23, 2015 08:44 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
89mulletbird
Aug 12, 2015 07:08 PM
