Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Heads.....
Old Dec 29, 2002 | 07:24 PM
rattlesnake_dm's Avatar
Car: 1992 RS (25 th Anniversary)
Engine: 350 Miniram XFI
Transmission: Pro-Built 4L60
Heads.....
I've been trying to figure out a way around this. I have a 68 327 that I rebuilt, cost me $4000++ CDN. I am going to fuel inject it ( to be different ) I will be putting it my 92 RS. I am going to do this for sure, whether I use the TBI setup or go to a Miniram or Stealthram setup. The heads on the engine are double hump 291 casting number heads, they have no accessory bolt holes in the ends. This is my problem, I have put $1600 in to these heads and cause they have no holes I now need new heads. Is it possible to have a machine shop tap the holes into the heads for the accessories or am I just S.O.L
Old Dec 29, 2002 | 08:30 PM
palric's Avatar
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
The way I see it... get a shop to tap new holes and use the heads.
I'd install the engine with your TBI and iron out the bugs created by the swap. After you figure these out/get experience then swap to stealth or mini ram.
my .02 cents worth,
RP.
Old Dec 29, 2002 | 09:31 PM
I hope so
Now I hope that the shop will tap the holes for me. Thanks for the input.
Old Dec 30, 2002 | 02:26 PM
Kevin Vandevenne's Avatar
Car: 87 IROC
You can buy brackets to mount the alt to one of the exhaust/header bolts, instead of the head like stock. Look up Brant Performance in Brantford and they can sell you one.
As for the TBI, why would you put a half-a$$ed induction system on a motor you spent that much coin on. The stock TBI is ok for stock motors, but doesn't cut the mustard for performance applications. Don't waste your time with it. Either swap to carb or spend the extra to get a decent FI setup on there.
Old Dec 30, 2002 | 06:28 PM
In the future
In the future I will be changing over to a Miniram or Stealthram, just need to save the money. But for now like Palric said I'll just use TBI on the 327, I'll figure out what combination works best for me and learn as I go along.
Old Dec 30, 2002 | 06:47 PM
88AstroMan's Avatar
Apparently, A TBI unit will flow enough CFM for 400HP. The nice thing is they're real easy to work with. My $.02.
Old Dec 30, 2002 | 08:46 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
yup on perfect air/fuel ratio across the RPM range
Daz
Dyno Don
Southern California Area
Dec 7, 2013 11:18 AM
88fastgta
Mar 19, 2012 01:18 PM
dredre08
Mar 4, 2012 06:21 PM
killacamaro
Jul 25, 2011 10:41 AM
88fastgta
Jul 21, 2011 07:40 AM
