Set of 081 heads
Car: 1986 Trans Am/1988 Camaro Iroc-Z
Engine: 305 TPI/350 TPI
Set of 081 heads
I have a good set of 081 heads that came off a perfectly running 305, my friend just dropped a 350 in his iroc and was just going to scrap the motor so I decided to take the heads off the engine before he did so.... There was absolutely nothing wrong with the motor or anything he was just wanting a 350 and decided to swap. Im asking 100 plus shipping for the heads..... Thanks
Car: 1991 Firebird
Engine: 305 TBI
Re: Set of 081 heads
These would fit my 91 305 TBI and be an improvement to the stock heads I have correct? If so I might be interested if they are still available.
The 081 heads them self are a better head then the tbi heads that are probably on your motor (187 Heads) as far as performance I really don't know because I have never done the swap but it is a better flowing head then the tbi heads so it would be an improvement!
Car: 1991 Firebird
Engine: 305 TBI
How much would the shipping be to Vancouver, WA 98661?
Also, do you know if they are a direct fit or if I'd have to mess with/buy other stuff to make them work?
Car: 1984 TA
Engine: 355 Carb
Transmission: 700r4 Built 2200 stall
If these heads are still availible would i be able to put z28 springs and retainers and run these on my 350. or would you say they need rebuilt. compression shouldn't be an issue i run a 282 cam and indiana has 93 octane at almost every gas station. I really just need to know the condition of the guides.
ambainb
Apr 25, 2016 09:21 PM
evilstuie
Feb 28, 2016 03:33 PM
Dialed_In
Aug 20, 2015 01:45 PM
