Ford 9 inch bolt in.
Subscribe
Feb 20, 2012 | 09:34 AM
I have for sale today a complete Ford 9 inch rear end minus brakes. New moser 31 spline axles, bearings, seals, posi 4.10s. All put together at a local reputable shop. the housing is an origional out of a late 60 ford that was remanufactured. ready to bolt in. If i dont get low-balled to bad ill through in new sub frame connectors and ladder bar suspension. All made for third gens. I have about $3100 ivested but looking to get $2000.
will consider trades for 72 chevelle parts
thanks rich
Reply 0
Feb 20, 2012 | 05:44 PM
Re: Ford 9 inch bolt in.
Um what kind of torque arm do you use with this? I don't understand how it's a bolt in with no torque arm.
Maybe post pics of the ladder bar setup?
Reply 0
Feb 22, 2012 | 12:27 PM
Sorry I ment lift bars, the torque arms are eliminated. There are brackets but I couldn't foresee installing them when the rear is out if the car.
Reply 0
Feb 24, 2012 | 03:55 PM
TTT
Reply 0
Feb 26, 2012 | 02:04 PM
360 views and no ones interested, Is it unreasonably priced?
Reply 0
Feb 27, 2012 | 08:40 AM
I think it's over priced seeing how it's not a "bolt in" technically. There is no mount/bracket for the torque arm. These go for cheaper that are a "true bolt in".
Pics of the ladder/lift bar setup might help to. If its the south side setup then maybe with the lift bars included plus shipped.
I think that 2000 shipped would be fair but still maybe over priced since you can only use the lift bar setup on it.
You asked for someone's opinion so I gave you mine do don't take my opinion negative if it wasn't the one you wanted.
Reply 0
Feb 27, 2012 | 04:20 PM
Thanks for your input, I will consider offers. I do have brackets for the torque arms. I can install them I just don't no the exact position. I wanted to mock up the rear in the car to do so. I also have a new set of 50/50 shocks to through in
Reply 0
Feb 27, 2012 | 04:48 PM
What brands are the gears and the unit... Is it a trac-loc or a true-trac? Would you be willing to sell the third member and axles seperate
Reply 0
Mar 5, 2012 | 12:42 AM
pm sent
Reply 0
Subscribe
