Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Front Lower Control Arm...
Old Feb 11, 2003 | 09:43 AM
Idlehands's Avatar
Car: 1985 Trans Am
Transmission: 5 Speed
anyone ever replaced their front lower control arm bushings?....looks pretty simple just wondering if there is something i should be aware of?
thanks in advance
Old Feb 11, 2003 | 10:00 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
make sure you shim correctly it depending on your alignment..(toe)..
Daz
Old Feb 11, 2003 | 02:11 PM
IROCKER's Avatar
It can vary. Some people put them in no problem at all. But for mine my mechanic had to do a bit of negotiating to get them in.
Old Feb 18, 2003 | 06:24 PM
Ratchet's Avatar
Correct me if I'm Wrong but there are no shims to worry about on The Lower Control arms of a Third Gen. As I recall even second gens only had shims on the uppercontrol arms to adjust caster and camber. Caster and camber on a thirdgen is adjusted using the strut tower mount.
The only thing I can think of that might be a problem is pressing the bushings in and out. If you do not support the inner and outer flanges of the Control arm where the bushing goes through you could bend it.
Ric
Old Feb 18, 2003 | 09:10 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
Ric
doh youre right..
Daz
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Dialed_In
Aug 20, 2015 01:45 PM
