Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Wonder Bar installed......
Old Mar 23, 2003 | 07:17 PM
Idlehands's Avatar
Car: 1985 Trans Am
Transmission: 5 Speed
and wtf does it do?.......now i know why they call it wonder bar....(you wonder what is does)
Old Mar 23, 2003 | 07:27 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Didn't you wonder what it did before you bought it. Well it just adds support to the front steering & steering box.
Old Mar 23, 2003 | 07:37 PM
Idlehands's Avatar
Car: 1985 Trans Am
i knew exactly what its suppose to do, i just found no difference.
Old Mar 23, 2003 | 07:39 PM
Slade1's Avatar
Wanna sell it to me then lol?
Old Mar 24, 2003 | 12:54 AM
Hawk92z-TDZ's Avatar
Car: 92Z28, 99SS, 83Z28 & 86GTA
Engine: 421, LS1, 327Turbo & 383
Transmission: T-56, 4L60E, T5 & 4L60
Axle/Gears: 4:10, 3:42, 2:73 & 3:27
U tried any really hard cornering yet?
Old Mar 24, 2003 | 06:46 AM
DJP87Z28's Avatar
The Wonder bar is for steering support and not necessarally for handling.
Old Mar 24, 2003 | 09:17 AM
formul8!!'s Avatar
Car: 2004 GTO
I think it is called "wonder bar" because we all wonder why the hell didn't GM put this thing on all f-bods?
It stiffens the area under the powersteering box to keep it from ripping itself from the frame. It also gives the PS pump more turning power because of this. You should get a little bit faster turning.
Old Mar 24, 2003 | 09:20 AM
Steve89GTA's Avatar
Where'd you buy it?
Did they have any more?
Old Mar 24, 2003 | 09:31 AM
formul8!!'s Avatar
Car: 2004 GTO
I got mine from Global West. Spohn makes one now too.
Skip the factory one and get aftermarket. The factory one is pretty flimsy compared to the GW bar. I got mine for $46/US shipped.
Old Mar 24, 2003 | 10:13 AM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
The GW version has to be modified slightly to fit an 82 or 83 - don't know for sure about 84
Old Mar 24, 2003 | 01:29 PM
Idlehands's Avatar
Car: 1985 Trans Am
i don't see any difference what so ever
Old Mar 24, 2003 | 01:49 PM
I have never even herd of one untill now.
Old Mar 24, 2003 | 02:00 PM
Slade1's Avatar
Here's an example of how the wonderbar would help...
You're coming down hill a bit fast and need to make say a right turn. You hit the brakes and start the turn but the road is a bit wet from the rain, your passenger side tire locks up and slides while the drivers side doesn't and you are forced to take the turn wide due to the slide of your passenger side.
With the wonderbar in place the steereing is reinforced a bit more preventing excess flex, causing the passenger side tire to plant itself more preventing the lockup and allow you to take that turn without a second thought to it.
Now if your suspension is old and struts and springs weak, a wonderbar won't make that much difference as its part of the big picture.
Old Mar 24, 2003 | 03:02 PM
DJP87Z28's Avatar
Why make a BIG issue of a item that GM installed on one car the IROC as a basic performace item to support the steering box and
steering, nothing else. Why it was only a cost saving by GM not to install it on other models. GM called it ( front steering support) and not AKA Wonder Bar.
Old Mar 24, 2003 | 04:50 PM
formul8!!'s Avatar
Car: 2004 GTO
A better example on why this part is needed:
Your thirdgen has big 245/16/50 or bigger sticky tires and a stiff suspension. Low speed turning, like in a parking lot and turning slowly at full lock will cause the steering pump to make the steering box try to rip itself from the frame. If this happens, it needs to be welded back in place. The faster the car is going, the less the box tries to do this.
Old Mar 26, 2003 | 05:58 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
formul8!!:
Where did you get the GW bar from? GW's website shows no distributors in my area (NC) and I can't find them at the usual online places (Jegs, Summit, etc.)
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
