Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
HEI Distributor Accel Super Coil on a non HEI???
Old May 13, 2003 | 10:45 PM
Idlehands's Avatar
Car: 1985 Trans Am
Transmission: 5 Speed
Can i put this HEI Distributor Accel Super Coil on my LG4 non HEI ???.....
Attached Thumbnails HEI Distributor Accel Super Coil on a non HEI???-i-4.jpg
Old May 13, 2003 | 10:50 PM
darbleinad's Avatar
Car: 84 Trans Am
first of all, all chevys have been HEI since like 1975, and 3rd gens were all used HEIs , then GM moved on to more advanced electronic type ignitions and such.
there are 2 types of HEIs, coil in cap and remote mount coil. you cant you use a coil-in-cap coil on a remote coil HEI system. the coil-in-cap coil contacts the rotor through a small "button" type thing mount under the coil.
so the answer to your question is no
Old May 13, 2003 | 11:03 PM
johnyIROC's Avatar
Originally posted by darbleinad
first of all, all chevys have been HEI since like 1975, and until they moved to the more electronic type ignitions and such.
Actually I think you can use the super coil on an LG4 distributor... because that's exactly what I did. I rebuilt my LG4 distributor and used it in my 355.
I'm not sure what he's talking about... being non HEI... but as long as no one did something really weird like put an ancient points rig in or something, it should work.
BTW, is your car out yet?
Old May 13, 2003 | 11:07 PM
darbleinad's Avatar
Car: 84 Trans Am
yeah you can use the super coil in an HEI as long as it is a coil in cap style. the other HEIs, found on TPIs, have a remote coil that uses a short length of spark plug wire to connect it to the distributor. you cant use a coil-in-cap style coil, like the one pictured above, on the remote coil HEIs.
my car is out, but i need to chnage the oil and do a few things before i drive it. hopefully the gears can go in on thursday.
Old May 13, 2003 | 11:19 PM
johnyIROC's Avatar
I assumed that it was in fact an HEI LG4 he had... I didn't think they made a TPI version... my bad.
Old May 13, 2003 | 11:23 PM
darbleinad's Avatar
Car: 84 Trans Am
he should have a a regular coil-in-cap HEI in there. for some reason he does not, apparently.
Old May 13, 2003 | 11:44 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
I jsut want to clarify..There are two kinds electronic and non-electronic.The in -cap are usually the non-electronic HEI's (up to 87)The electronic HEI's uses remote mount coil.Reason I mentioned this is because there are afermarket HEI distributors that have a remote mount HEI but not electronic and vice versa.BTW Im selling a distrib with an Accel HEI module(35362) and Accel electronic coil (or trade for an aftermarket non electronic)coil
Daz
Old May 13, 2003 | 11:48 PM
darbleinad's Avatar
Car: 84 Trans Am
good point there Daz. yeah the older HEIs, such as the one on my 84 have a vacuum advance on them still ...
Old May 14, 2003 | 12:38 AM
Kevs87TA's Avatar
Car: 1990 GTA
Engine: L98 5.7 L
Transmission: 700R
Axle/Gears: 3.45 9 Bolt
That coil is the Accel Super Coil PN# 140003. It's the same one that is gracing my distributor as we speak. The pic is before I installed the coil.
Attached Thumbnails HEI Distributor Accel Super Coil on a non HEI???-dsc00013.jpg
Old May 14, 2003 | 11:46 AM
Idlehands's Avatar
Car: 1985 Trans Am
sorry guys i was at work when i posted this, i have the original GM coil in cap setup, as for i know nothing about this, i was told that installing the above coil would give me more voltage is this true and can i put it in without damaging anything?
Old May 14, 2003 | 11:48 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
true,although I didnt notice any difference...
Daz
Old May 14, 2003 | 11:49 AM
Idlehands's Avatar
Car: 1985 Trans Am
when i went to pick it up i notice that there is no indication on the box for mounting it on a 305 so i didn't bother with it, i'll wait to see what you guys say first.
Old May 14, 2003 | 12:08 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
You can use it ,I used it on my 82 LG4
Daz
Old May 14, 2003 | 02:29 PM
Eric2ndGen's Avatar
Yowsa! Talk about confusion!
Just to clarify:
Pre-1975- Points-type distributors w/external coil
1975-1979/80 (1979 for California, 1980 for rest of US states)- HEI w/coil in cap, vacuum controlled advance
1980-1988 US- CCC, computer controlled advance, external coil
1980-1988 Canada- varied by model- but most GM V8s still in production with a carburetor still used the older HEI w/coil in cap, vacuum controlled advance
1987-up Canada (all), HEI w/electronic controlled advance, external coil- same as was used on TBI engines- but I cannot speak for TPI at this point.
The point is that unless you have an external coil (factory- not an aftermarket external coil conversion)- you can use the Accel Supercoil on your HEI.
Will it do anything for you? Not likely- yes it raises the peak voltage but unless you're running a much higher compression ratio (i.e. 12:1 or such), or trying to gap your plugs at .060" or something (that's a different discussion) you won't see any benefit. The only people that see a benefit are those that had a defective stock coil to start with.
Old May 14, 2003 | 02:45 PM
Corbi_85-IROC's Avatar
Car: 85 iroc z
Engine: LG4 :(
Transmission: 5 speed
i also have it on my 85 LG4 and have not noticed a difference either, but it hasnt hurt so I kept it, has been about 10 years now.
It wont hurt your car so go ahead and install it as it is supposed to give you a better spark.
Old May 14, 2003 | 02:57 PM
johnyIROC's Avatar
Just to clarify:
GOOD ANSWER!
Old May 14, 2003 | 03:26 PM
darbleinad's Avatar
Car: 84 Trans Am
i second that. it makes things alot easier to explain when you know dates for the change over and what not.
Old May 15, 2003 | 07:37 AM
Idlehands's Avatar
Car: 1985 Trans Am
Very good guys, this is why i come here.
Sorry for any confusion
Attached Thumbnails HEI Distributor Accel Super Coil on a non HEI???-_car3_web.jpg
Hotrodboba400
Dec 10, 2019 07:07 PM
MM2Robinson
Oct 1, 2017 09:16 AM
86CamaroDan
Sep 29, 2015 10:08 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
Jlanz55
Sep 6, 2015 03:05 PM
