Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Runner " hogging out" Q
Old Aug 16, 2003 | 06:26 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
What I am wondering is ............. anyone ever come across somebody who has ...... figured out the difference in keeping the plenum stock ..... vs siameseing it ....and the runners ..... then going into the base .....so many inches?
just curious .......... I am about to siamese the plenum now ..... and go from there ......... see I know doing this changes your powerband .......moves it up if anything by slowing the velocity. But ........ what I am REALLLY curious is would a near stock intake setup or hogged out setup compliment the operating area of a ZZ4 camshaft ?
Old Aug 18, 2003 | 12:39 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
come on .. anyone?
Old Aug 19, 2003 | 02:56 PM
Hawk92z-TDZ's Avatar
Car: 92Z28, 99SS, 83Z28 & 86GTA
Engine: 421, LS1, 327Turbo & 383
Transmission: T-56, 4L60E, T5 & 4L60
Axle/Gears: 4:10, 3:42, 2:73 & 3:27
Ask this in the TPI or the General Tech section and u might get an answer. I cant help ya, sorry
Old Aug 19, 2003 | 04:54 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
madmax saw better power at higer RPM .Not much higher than stock though.The problem with the ZZ4 cam is that its designed for a very short runnered intake manifold and carb..The TPI plenum will still peak at 5000 (as opposed to 4500 w/ the non siamesed plenum/runner)when the cam likes to peak at 5500 on a 350 or bigger..No chip is gonna *** this.IMO get an FI grind instead
Daz
Old Aug 20, 2003 | 03:08 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
....so what makes it a FI grind .....duration ? LSA ? Definately not the lift . The cam swap is out ...... just had it put in . But What I wanted to do was shorten the runner area by grinding out the Edlebrock base I got ...... shortening the runner size there ...I am assumeing this would be makeing a " short" runner setup ..............no?
thanx for the info Daz .....I am going to bug Madmax
Old Aug 20, 2003 | 04:48 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
IMO it would still be way too long..You can gain a few by doing the runner mod but not worth to the wheels.But with an FI grind youre talking a few tenths.The usual TPI grinds are low duration and high lift.The duration relates closer to the RPM range hence the intake.Lower LS number also results in lower vacuum signals which also has a limit when it comes to TPI.Most of all there's more to a cam than the numbers that you see.Two cams can have the same specs but work differently.
Daz
Old Aug 21, 2003 | 05:20 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
:hail: thanx a bunch ....wlll I am stuck with the ZZ4 ..... see what I can make of it anyways . I think I might just leave the intake the way it is ......then sell it for a stealth ram ....later
peace
Old Aug 21, 2003 | 08:17 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
peace
Now youre talking!!!..Install the cam straight up and fly!!!!Dont forget the injectors!!
Daz
Linson
Oct 24, 2025 02:00 PM
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Chas91Z28
Oct 22, 2015 10:12 AM
Royal_Z
Sep 30, 2015 08:45 PM
