Motor Mounts
Car: 87 irocz
Engine: 5.7
Motor Mounts
I bought a set of poly urathane motor mounts and i realized that the control arm is in the way is there any other way that u can change them without taking that out. thanks
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
Hey Robcan. Welcome. The control arms do not have to be removed at all.. There are access holes under the cross member, adn you go through wiht a good extension, adn a swivel socket. It is a bit of a pain to say the least sometimes. Try a search on "changing motor mounts"
Car: 87 irocz
Engine: 5.7
Thanks thats what i figured just wondering if there is a way around it or not. looks like ill be buying all new polyurathne bushings and konis and springs might as well go all out
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
I'm also in the process of changing the motor mounts. I can't see any other way of getting them without dropping the A pillars, and i've double and triple checked for access holes. There are none.
It'll take some time to swap that's for sure.
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
f you're going to be doing the front LCA bushings maybe have a look at Global West. They have lca bushings made from a different material - delalum or something. I don't know if they're over-rated crap or not but as the fronts are a pain to do you might as well put the best stuff you can in there - if indeed these things are actually any better than poly bushings.
Finishing up a 2.8-5.0 engine swap. I had to take the a-pillars down, the hole is useless... and btw, just undo the lower ball joint nut and use a pickle fork and a floor jack.... dont waste your time trying to undo the strut (Like it says in the tech article for changing springs) you'll just end up breaking parts or tools.
It was easiest lying under with feet coming out nose, one arm reaching into the crossmember holding a wrench (i ended up using a jonson bar, it was alot easier on the hands) inside, other arm reaching over and rachetting.
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
About 1 1/2 hours each side, motor mounts are done. No a pillars or anything else was removed. Couple knuckle skinners but other than that it went well.
Car: 83WS6TA
Engine: ZZ4
Axle/Gears: 3:23
hey i decided to take the control arms off and replace everything i bout new kyb agx fully agustable and eibach springs
You probably know this but you might need an adjustable panhard and rear LCA relo brackets once the car is lowered.
ambainb
Apr 25, 2016 09:21 PM
NBrehm
Aug 5, 2015 07:57 PM
