Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Have to Vent
Old Aug 9, 2004 | 07:46 PM
LowRyder's Avatar
Car: 92 RS Vert
Engine: 355
Axle/Gears: 342
Have to Vent
So I had my stupid tranny problems (blown synchro and f'd clip on 5/reverse) then I put a "new" rebuilt tranny in after 2 weeks of not being able to drive my car and everything is good. On my way home from work tonight I jump off the highway and notice I have very little power. I then turn down the stereo and hear a clicking.... Spun bearing I assume! check the oil and its good so i dont know how it happened but I know the motor (l69)was just rebuilt like 2000kms ago and now its knockin like crazy. I'm really gettin sick of this F**kin' car.
sorry just had to vent
Old Aug 9, 2004 | 09:27 PM
87LG4FORMULA's Avatar
Car: 87 Formula/ 87 IROC-Z
Engine: LT1/L98
Transmission: modded700R4s
Axle/Gears: 3:23 posi/?posi
It could be worse, you could be having problems with an ugly car! Sorry about your luck tho, hope it's a simple fix!
Old Aug 9, 2004 | 10:01 PM
Demon355's Avatar
You buy these cars fully knowing that this sorta thing will happen to you it's just a matter of time. That's why owning such a vehicle is so much better than owning say a newer car. You love the car so much you just learn everything about it so that when something does break, you can pin point the problem, fix or replace it, than go back out driving. It's part of the fun. Just remember that next time
Old Aug 10, 2004 | 02:21 PM
RegaPlanet's Avatar
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
Re: Have to Vent
Did you check the oil filter as well(cut it open)?
What was your oil pressure?
Can you still start it up and check the pressure again?
I'd look in your oil filter and the oil galleys of your heads for copper/brass coloured flecks if you think its a bearing. You will definately lose oil pressure if its spun when hot. Could be something alot smaller like a collapsed lifter which will basically make you lose one cylinder and a noticeable amount of power. They'll make a ticking sound.
Old Aug 10, 2004 | 02:31 PM
LowRyder's Avatar
Car: 92 RS Vert
Engine: 355
Axle/Gears: 342
would a collapsed lifter be as loud as a bearing? cuz this is really loud when at high rpms. Also if it were that I'd be able to see it as soon as i take the valve cover off right?
Old Aug 10, 2004 | 04:45 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
Take a broom handle and set it on your fuel pump while it is running, place the other end at your ear. If you here the knocking coming throught the broom stick quite good, it's your pump. Alot of times the spring goes for a crap in the L69's and these make a very bad knocking sound, just like a bearing. Worth a look see. The L69 that was in my Monte SS did the same dang thing...
Old Aug 10, 2004 | 07:27 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Buddy I feal for ya ....the EXACT same thing happened to me . Turned down the radio ..... knock knock knock ! OOnly I am orse off than you ....mine is an ugly car
.... all just an excuse to upgrade Good luck to ya man
Old Aug 10, 2004 | 10:22 PM
LowRyder's Avatar
Car: 92 RS Vert
Engine: 355
Axle/Gears: 342
but this wouldn't only be when it heats up right? like i mean the knocking is always there but the power loss is only when it heats up
Old Aug 11, 2004 | 09:32 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
knocking= bad . I aint no mechanic ..... but if its banging away ...time to start thinking about what you are going to do about it $$$$$$$
...all depending on what the noise is too .... can't really say .....
Old Aug 11, 2004 | 09:43 PM
LowRyder's Avatar
Car: 92 RS Vert
Engine: 355
Axle/Gears: 342
I figure its a bearing which is time for new motor cuz its not really worth it to me to rebuild the l69. I've let the car sit in the driveway for a few days cuz i dont wanna touch it right now i'm still pretty pissed.
Pac J
May 17, 2020 10:44 AM
kkirch15
Interior Parts Wanted
Oct 15, 2015 02:21 PM
Fanatic1074
Oct 2, 2015 03:47 PM
shanelique22
Sep 24, 2015 06:30 PM
sleprock
Sep 24, 2015 04:33 PM
