Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Well guys...
Old Apr 3, 2005 | 07:51 PM
STIFFLER's Avatar
Well guys...
I know its been a long time... but I got some time today to mess around with the camaro.. and found out that my corvette valve cover will not for my heads.. I need tall centrebolt valve covers so if anyone knows where I can get some it would be much obliged.. The only thing I am worried about is that the smog pump will not fit anymore if I go tall. Anyone have any experience with this?
One thing after another I tell you.. My old 305 was looking really good to me today..
Old Apr 3, 2005 | 08:24 PM
RegaPlanet's Avatar
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
Good to see ya back Stiffler. I Know your pain with one thing after another. I'm not even done tuning my new motor and now I'm about to swap a 6spd in on top of it all. I miss driving the car more than I worked on it :P
I dont know why your smog pump wont fit due to tall valve covers? Isn't it located near the bottom passenger side of the block?
Old Apr 3, 2005 | 08:42 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
Why wouldnt it fit?Is it hitting the cover or the braces inside?..I have to cut the bracings on one side of the valve cover for it to fit my TFS heads before..Maybe thats all you need to do.
Old Apr 4, 2005 | 04:17 AM
STIFFLER's Avatar
Its hitting the cover.. I took a Allen key and put it beside the highest rocker than put my finger at the height. Put it inside the cover and it needs about a 1/2 inch yet to go..
Old Apr 4, 2005 | 05:54 AM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
Re: Well guys...
The GMPP centre bolt valve covers are 1/4'' taller than stock. The part numbers are 12497978 (Polished aluminum) and 12497979 (Black crinkle).
If your smog pump is up around one of your valve covers........you have seriously ****ed something up. Are you talking about the AC compressor or the alternator?
Old Apr 4, 2005 | 06:00 AM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
Moroso also makes a set. They're stock height but are machined for extra rocker clearance. They're part # 68036.
Your best bet would probably be the Jeg's ones. They're a tall design and are part # 555-50104. They're also $40 cheaper than all the other ones.
Old Apr 4, 2005 | 07:57 PM
freestylzz's Avatar
Car: 1987 Iroc Z28
Engine: The KING of the 3rd gen TPI's.
Transmission: Beefed up T5
Axle/Gears: Aussie 3.45's
WHy not remove it. You may not be needing it shortly anyways.
freestylzz's Avatar
Car: 1987 Iroc Z28
dp
Street Lethal
Sep 7, 2015 01:09 PM
jharrison5
Aug 19, 2015 05:53 PM
Street Lethal
Aug 14, 2015 08:25 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
87CamaroLT
Apr 27, 2001 06:18 PM
