Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
VSS Buffer needed
Old Aug 11, 2005 | 07:44 AM
kaptinkafeen's Avatar
VSS Buffer needed
Anyone have a working VSS Buffer that I can buy? I would also need if possible the wire connector that runs down to the VSS at the tranny. Or... Does anyone know where I can get one, besides the dealer?
Andrew
Old Aug 11, 2005 | 11:14 AM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
Junk yard, full size vans in paticular since they are easy to get under. I was just there today, if I had seen this post before, would have looked for you. From what I've read there are a couple of different ones. A tranny shop shouild be able to help you out as well.
Old Aug 11, 2005 | 01:13 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
Re: VSS Buffer needed
Andrew
Didn't you get a '91 or '92?
I think the buffer is in the ECM on the SD cars.
Old Aug 11, 2005 | 06:24 PM
Acceld Z
I got a '91 Z, but the power train has been change to carb/HEI so the ECM has been put in a box along with the whole TPI set up. The two ways that I can get my speedo to work are to get a VSS buffer which was how all the 5.0L TBI cars were equipped in '91, or to go and buy the Dakota Digital SGI box so that the VSS inputs can be "translated" to the speedo. (These are the ways that have been recommended)
Hey Half Inch,
Which years of full size GM vans are we talking about?, and where would I look? (under the dash - right or left side...)
The GM part# that I need is 25071437
Thanks guys,
-Andrew
Old Aug 11, 2005 | 07:06 PM
Engine: SBC, LS-x
Acceld Z
Hey Half Inch,
Around the same year of your car give or take -5/+5 years. Just trying to give you a hand, don't know the whole way thru myself.
Old Aug 11, 2005 | 09:54 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
I have a similar problem. I was just going to buy the Dakota Digital box to avoid the driven gear hassle. Check this thread out.............
https://www.thirdgen.org/techbb2/sho...hreadid=186037
Old Aug 12, 2005 | 06:28 AM
Acceld Z
that's some good stuff as well. Thanks
IF i can't get my hands on a used buffer, Not sure what to do... The Dakota Box is $80US and I have found a new Buffer for $115.CND. The box is more versatile, but I have been told it is a PIA to set up. THe Buffer it would seem is the easier install/calibrate. I really don't want to hack at the wiring harness behind the dash - this makes a mess even if you do things right, So the buffer "may" be a better bet - but from the looks of things, even to hook up the buffer will require some cutting and soldering.
Any thoughts or opinions?
You won't have any gear drive hassels with either the Box or the SGI unit. The gear driven speedo's were axed beforethe '91/'92 models - well before. (Was it in '87 that GM switched not sure...)
-ANdrew
Old Sep 2, 2005 | 07:23 AM
VSS Buffer part 2
Well I finally got out to a auto wrecker and picked up 7 VSS Buffers, and the harnesses. $20.00 for all of it - GM wanted $114.00 for a new one, and if you go the Dakota route, their system is worth $80USD.
I would like to thank the guys (HalfInch, AcceldZ etc...) who helped me out, I got my speedo working - just like new, no hacking ect..
If anyone else needs a hand, I would like to pass along that beside just TBI F bodies, and the 6cylers, I found a pile of the Buffers on mid 80's caddies with TBI - passenger side.
Hey AcceldZ if you still need to get your speedo working I can pass you along something through the mail or ?? just pm me. This project was a breez - just make sure you have a schematic of the gauge harness to aid in wiring up the buffer.
Thanks again guys
-ANdrew
Old Jan 14, 2007 | 03:15 PM
agood01's Avatar
Could one of you provide me with the wiring diagram for the 4out.buffer. I'm upgrading to a tuned port and need to provide the ECM with the proper input. I already have the module, just not all of the connection points.
Old Jan 14, 2007 | 04:41 PM
Here is a link with the pics :https://www.thirdgen.org/forums/elec...s-cluster.html
If that doesn't work, here is scan of the same info.
I have also added the schem diagrams for the ECM wire harness for TPI cars and the VIN E (tbi v8 cars) VSS wire schematic.
One thing tho, wire colour (and possible circutry) may be different from what I have posted. The two schems are for a '91 TPI and '91 TBI car -
depending on the year of ECM that you intend to transplant into your car the wire colours may be different and in different pin locations on the female ECM connector (or if you are splicing into the wire harness, then obviously on the male end...) From what year of F body is the ECM comming from?
-Andrew
Attached Thumbnails VSS Buffer needed-vss-buffer-pic.jpg   VSS Buffer needed-schem-1.jpg   VSS Buffer needed-scan0002.jpg
Old Jan 14, 2007 | 10:44 PM
agood01's Avatar
Exactly what I needed. Thanks!
Old Nov 9, 2008 | 04:53 PM
iceinespana's Avatar
Car: 1991 Z28 Camaro Convertible
Engine: LB9, 5.0 TPI
Re: VSS Buffer part 2
Thanks again guys
-ANdrew
Does anyone have a VSS Buffer I can get.
Thanks, John
Old Nov 10, 2008 | 07:07 AM
Check your pms. I still have a few.
-Andrew
Old Nov 10, 2008 | 09:14 PM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
I need a VSS sensor itself.mine doesnt send signal from the trans at all.tranny shop said the gear is intact and works properly but the sensor is shot.a new one is almost $150 :O
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
mizz0313
Aug 12, 2015 06:45 AM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
