Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Still at a lost....
Old Apr 15, 2006 | 01:48 PM
STIFFLER's Avatar
Still at a lost....
well I was back outside playing with the camaro. Did some more stuff and am getting the same trouble codes 23,34,51 and 44. I have replaced everyone of the codes with new parts.. Guess what car is still giving the same codes. So Iam going to get the gas now.. ttyl
Old Apr 15, 2006 | 02:02 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Seems that Dam mini ram is giveing you more problems than it's worth eh Gerrit ? You trying to run a big cam in it ?
Old Apr 15, 2006 | 03:00 PM
STIFFLER's Avatar
Not to big XR270HR com cam
Old Apr 15, 2006 | 03:30 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
Gerrit, have you done any troubleshooting or just replaced parts?
I'll try and scan some stuff I have and send it to you tonight. It's just GM stuff for killing codes but it may be useful.
Old Apr 15, 2006 | 03:36 PM
STIFFLER's Avatar
Buddy I have tried trouble shooting everything. replaced all parts, checked memcal to see if the info matched and it did. (But I am going out to buy a brand new PROM and see what it does) Checked all the grounds everything ohms back to the ecm. Swapped out distributors.. you name it I have done it.. Except for a BRAND new prom. I got one off ebay a long time ago and that did nothing aswell.. Swapped 3 Ecms and nothing..
Old Apr 15, 2006 | 03:56 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
Not just the PROM but the ECM too..Have you tried a stock ECM and PROM?Maybe you can scan it with the stock stuff first.
Old Apr 15, 2006 | 04:13 PM
STIFFLER's Avatar
Yes I have.. and I get the same problem. That was one of the first things I did.
Old Apr 15, 2006 | 04:20 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
How does the plug look?BLMs?O2 voltage?knock counts?
ESC working ok?
Old Apr 15, 2006 | 04:32 PM
STIFFLER's Avatar
ESC working ok?
Well now that you brough up the ESC.. if I get the car running I get the usual 4 codes. Then while its still running I dump the codes and get the ESC malfunction code. I have changed out the knock sensor aswell.. there are no knock counts at idle, BLMS are frozen computor won't go into closed loop.. black soot coming out of the tail pipe
Old Apr 15, 2006 | 04:47 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
how long does it get to operating temperature?You should check the O2 sensor again to see if its already covered with soot..Either replace or clean and take note to see if the code is exactly the same before.There should be a few knock counts on startup.The BLMs are frozen to what value?Did you change anything on the harness?.Did you disable/emulate the EGR on the PROM since (IIRC) you have a Miniram?I wonder if your IAT is either not working or you switched its connector with the EGR..lol I have done it lol
Old Apr 16, 2006 | 01:48 PM
STIFFLER's Avatar
10mins to operating temp but it keeps climbing, no fans kick in. O2 sensor is covered in Soot again. BLMS are frozen at 128. EGR was disabled through the chip. Looked for the other connector for the EGR couldn't find it. The IAt is pluged into a tan and black wire. If that tells you anything. and the O2 sensor climbed steady up to 960mv
KNIGHTE
Jun 9, 2015 08:57 PM
Toyota h8r
May 10, 2009 02:12 AM
hayesperformanc
Jul 23, 2008 09:45 PM
burtreynoldss
Jun 4, 2008 10:52 AM
