Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
IAC question
Old Aug 7, 2006 | 10:29 PM
transamice's Avatar
Car: 87 GTA t-top
Engine: L98 350 w/RMT
Axle/Gears: 9 bolt BW 3.45
IAC question
Im having a problem with my idle, seems like my IAC isnt working properly.
The car idles rough, never consitant at idle and takes some time to start as well.
I dissconnected the IAC with the car running, didnt make any difference, I would think it would flat the idle, is that normal?
Is there a voltage setting I can check on the IAC or somehow I can test it?
Old Aug 8, 2006 | 10:06 AM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
Look for the TPS/IAC reset prodedure in the tech section of this site. You need to do both at the same time.
Old Aug 8, 2006 | 10:36 AM
transamice's Avatar
Car: 87 GTA t-top
Just cruising at idle feels like the car is surging, like jumps back and forth, struggles, is very annoying.
Old Aug 8, 2006 | 05:16 PM
zedder 1 9 9 0's Avatar
Car: 1990 Iroc Z Convertible
Engine: LB9
Have you tested your injectore ressistance when they are hot and cold? My car had a problem similar to this when 5 of my injectores went south.
Old Aug 8, 2006 | 09:33 PM
transamice's Avatar
Car: 87 GTA t-top
IAC was bad, replaced today runs better however I need to adjust my timing, still outta wack.
I think I will look into some injectors soon as well.
Old Aug 9, 2006 | 02:36 AM
transamice's Avatar
Car: 87 GTA t-top
I dont get it, ran the car tonite still has the surge like problem.
After installing it seemed better but now its still acting up, this is getting anoying and seems like anyone who checks it cant figure it out.
Im lost, could it be my ecm prom or injectors? tired of this ****.
Old Aug 23, 2006 | 07:31 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
What year is your car again?? This is a common issue with the older TPI cars with the crappy Multec injectors...
Old Aug 24, 2006 | 02:08 PM
transamice's Avatar
Car: 87 GTA t-top
Its an 87 GTA 350 TPI 22lbs injectors with the cold start injector, auto .
Old Aug 24, 2006 | 02:23 PM
transamice's Avatar
Car: 87 GTA t-top
Now its 350 with the HSR intake, sorry it didnt post the edit.
bamaboy0323
Sep 3, 2015 06:07 AM
86IROC112
Aug 21, 2015 07:20 PM
86IROC112
Aug 21, 2015 12:39 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
