Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Fuel Pressure
Old Feb 13, 2002 | 05:16 PM
nblanchard's Avatar
Fuel Pressure
Hey guys.. have a problem, well 2. I got my AFPR in now... and an Accel fuel pressure guage.. first of all, the guage jumps all over the place... i do not know why... second, when i rev it up, the pressure seems to drop (i say seems, because the guage jumps around soooo much, its hard to tell).. any ideas?
Old Feb 13, 2002 | 06:24 PM
Cruz'N Bruz'R's Avatar
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
Your guage is jumpintg around because you have air in your lines. I don;t know about a fuel pressure guage, but my mechanical oil pressure guage did the same thing, I had to bleed out the air, just like bleeding brake lines.
Old Feb 13, 2002 | 08:23 PM
nblanchard's Avatar
ahhh.. could be... i had trouble with the guage leaking... air should work its way through though, shouldn't it?
Old Feb 14, 2002 | 07:18 AM
IROCKER's Avatar
Air will not stay in the fuel lines for long, it will eventually purge itself. I responded to your other thread...maybe replace the fuel pump relay?!? It's cheap and easy to do...perhaps worth a shot.
Old Feb 14, 2002 | 03:38 PM
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
you said you had trouble with it leaking. Well if fuel can leak out, then air could leak in.
Old Feb 14, 2002 | 04:19 PM
nblanchard's Avatar
yes I am aware of that, only thing is, I do not see a leak anymore since I fixed the original leak (stupid Accel guage had a bent tube on it)
Old Feb 14, 2002 | 05:18 PM
IROCKER's Avatar
*scratching head* Does it run ok? Or is it a bit hesitant? I'm very thankful that mine when back together with no major hick-ups. And my gauge is rock solid. The only difference is you've got a different AFPR than I do.
What have you tried or replaced so far...anything yet?
Old Feb 14, 2002 | 05:46 PM
nblanchard's Avatar
The car runs 100% No hesitation what so ever, it has mass throttle response. I am just gonna wait it out and see hat happens
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
