Getting near time to do mods
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
Here are some mods I am planning for April:
- installing some MAC SFCs (anyone recommend any shops in the KW area to install ? I was going to use Rudy Held).
- do a proper job on the cold air, eg: 3 inch ducting to the fender well. Been wondering if there isn't a way I can take advantage of that open power bulge on my hood ?
- get a Jacobs Ignition kit.
- maybe some roller rockers, sure don't like the idea of having to replace those springs !
- braided brakeline hose to the front calipers, upgraded rotors, carbon fiber pads.
- of course an aluminum driveshaft (takes the 'massage' out of the hiway drive).
I have been toying with the idea of some Torque Thrust II 17x9s with 275/45s as well (wow $$$ !!). This one would be particularily hard to get past the wife. She is bound to notice those new shiny things attached to the four corners of the car -- then I'll be in for it ! Maybe if I bought her that new sofa & chair first ???...
At the very least I expect to do the SFCs and the aluminum shaft. How about you guys ? Any late winter mods being done ?
RP.
RP.
Car: 84 Trans Am
man, who cares what the wife thinks....get those torque thrusts...they look amazing. i wanted some but i couldn't afford them so i went with Outlaw II wheels (also by American racing). they turned out to look real good. as for mods, i built myself a dual snorkel air cleaner a couple of weeks ago and i am currently learning how to tune my quadrajet carb for better performance. i also plan on replacing the wiper motor and i have a new door and hatch look set on order. other than that i cant do anything till schools out at the end of april and i start working. once i have some cash i will hopefully be able to afford to put full dual exhaust on.
trust me -- it matters what the wife thinks...
Originally posted by darbleinad
man, who cares what the wife thinks....get those torque thrusts...they look amazing....
Trust me -- it matters what the wife thinks. Depending on how you do things you can have new toys with GRIEF or without GRIEF. I prefer the latter and YES I do love the Torque Thrust IIs as well. Trust me on this too - when you are married you can still mod your car-- it just happens at a slower pace which in the end is ok by me.
Can you post a pic of your car ? I would like to see how it looks with the wheel upgrade.
RP.
Car: 84 Trans Am
hahhaha....i guess toys without grief would good. hahaha
unfortunately i dont have a photo of my car with the wheels...but hopefully soon i will. my buddy has a digital camera and as soon as i see him, we will get some pics of my car. i went with the 15x7 Outlaws cause 16" rims and tires are too expensive for me.
i will work on getting those photos.
later
later
Car: 84 Trans Am
what does an aluminum drive shaft cost here in canada? how much for the the one from the dealer and how much for an aftermarket one?
Braided lines
Originally posted by IROCKER
I'm planning on getting the steel braided flex hoses and a aluminum DS in the early spring. If you get any of those on before me, make sure you post the results.
RP.
too much new
RP.
Car: 1992 Z28
Engine: 355
I spoke with a tech a Baer for about an hour last year. He told me braided lines are no better than new high quality rubber lines. The braided lines do show improvements over older rubber lines though. As for the Jacobs ignition.....that's what I would have bought had I had the $$$. They are the best, bar-none. My Accel 300+ box sounds like it's producing some kind of nuclear energy
Would you be able to use a modified Camaro SS induction setup to make your "power bulge" hood funtional?
Would you be able to use a modified Camaro SS induction setup to make your "power bulge" hood funtional? Thread Starter
hmmm.... sounds interesting
Would you be able to use a modified Camaro SS induction setup to make your "power bulge" hood funtional? About the braided lines -- I have no opinion other than what I've been told. My connection can get me lines for about $80 so that is cheaper than the GM OEM rubber. I figured I'd give it a try ?
What is the scoop (pun intended) on the SS induction setup ? I have never seen the innards of one. Can you point me to a page that shows this in detail ? I would REALLY be interested in checking it out.
RP.
Car: 1992 Z28
Engine: 355
Re: hmmm.... sounds interesting
RP.
RP.
Car: 84 Trans Am
wow 600 bucks...i guess the olde steel drive shaft will have to say for awhile. i havent seen 600 bucks since i started school. *** damn western...i swear they are a bunch of thieves..all they do is take my money.
that would sweet if you could get the scoop on your car working. my carbed TA has a scoop like that, except its functional....it opened when you floored it....i fixed that by unhooking the vacuum/electric switch thing and then just pulled the rod that operates the flap on the scoop so that is was open and then i tied it open with some wire. now its sucks fresh air in all the time. (i know this is a real poor mans way to do things, but what can i say, i am poor).
good luck with you making your scoop work for your tpi. if you fab something up, take some pics
familiar with the setup
Also, I love that scoop on the '84 T/As. I retro-fitted one on a TBI powered '88 Formula some years back. With some minor mods it worked like a charm and really woke up the motor.
Hey have you installed a distributor advance kit yet ?
RP.
palric: Email me at work...I wanna talk to you about the brake lines. christopher.vagg@rbc.com
Car: 84 Trans Am
no i havent put an advance kit in yet. in terms of ignition mods, all i have is an MSD HEI in cap coil and accel 8.8 wires. i would like to get a kit for my vacuum advance HEI and i also want to get the MSD module and goes with the coil. are the advance kits and the HEI module hard to install? i dont know too much much about ignition stuff...i dont even know how to set the timing (the fact that i dont have a timing light compounds the problem). coil was easy to put in, but all i had to do was un dont the dust cover, take out the old one and put a new one in.
an easy mod
RP.
