Question for TPI guys
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
I have been going through the tear down for a re & re on the TPI lower manifold intake gasket (leaked oil) and am now at the point where am putting it all back together. I have re-installed the fuel rail and tested for fuel leaks.
Sure enough there is a fuel leak at the number 8 injector location (passenger side rear).
I should point out that I had removed all 8 injectors for backflush cleaning.
When I was re-installing the injectors to the rail the #8 would not fit very easily so I sprayed some silicon lube on it. None of the other injectors are leaking, just the one I sprayed.
Does anyone know if this will account for a fuel leak ? Also, I replaced all rubber grommets and rail clips with brand new pieces, these installed without incident.
thx in advance,
RP.
thx in advance,
RP.
leaking at the rail
Originally posted by Acceld Z
Is it leaking at the fuel rail or injector boss in the manifold?
Wonder if the grommet got twisted off when I was struggling to get the injector in place ?
RP.
Car: 1992 Z28
Engine: 355
Did you lube the o-ring with engine oil before you installed it? Also, sometimes the o-rings don't step down into the bore and wind up half in and half out of their groove. Make sure the rail clip is clicked all the way over as well.
thx for the help
I think the only cause can be a misaligned o-ring or a damaged injector (I have spares in either case). I did not lube the injectors with motor oil prior to installing them -- is this something that must be done ?
RP.
I didn't lube my o-rings before installation.. and they are fine. Sometimes the o-ring will twist upon installation... just take it out and check it out. I know its easier said then done... but its gotta be fixed
Dude...if you are taking them out again to fix it up then I strongly suggest lubing them with engine oil. I helps the o-rings go in easier and allows them to be more pliable. It also creates a barrier for sealing. same reason that you are suppose to pre-lube your new oil filter rubber gasket before putting it on. It probably went in askewed. The engine oil will help.
will do
RP.
Car: 1992 Z28
Engine: 355
When you lube them with engine oil, they expand. It's how they achieve the seal. They're made from neoprene. Once they dry out and become chalky...........that's when they leak.
not sure what else to do ?
thx,
RP.
Sanjay
Aug 12, 2015 03:41 PM
