what could be fouling my plugs?
Old Apr 15, 2002 | 08:57 PM
eddie89TA's Avatar
Car: 89GTA
Engine: 355TPI Edelbrock heads, base. SLP r
Transmission: TCI streetfighter 700r4
Axle/Gears: B/W3:27
ever since i installed the new engine the #3,6,8 plugs seem to b fouling. the car runs strong but it is annoying. the plugs right next to them run just fine the engine now has 12k miles on it. i get no blue smoke whatso ever. so i dont think it is the valve seals....(heads r new too) is hard to tell if the plug is fouled with oil or gas...the car idles grat and i get 16-18 mpg. i am changing my intake gaskets tommorow just in case there was oil sneaking in through where the intake meets the head. i am running stock 22# injectors at 48 psi i also measured the resistance of the injectors 3,6,8 and it measured with in spec. hmmm any suggestions? thanks
Old Apr 16, 2002 | 07:20 AM
Markolc's Avatar
Car: '87 IROC
Engine: LT1 350
Transmission: 700-R4
HEY - It's nice to see another thirdgenner in New Britain! That makes two others that I know of now
About your plugs fouling up, I'd venture to say you need to have your injectors cleaned and flow matched. The three bad injectors could be puddling up fuel by being dirty, or you can have a leaky injector that dumps fuel all over the cylinder after you let the car sit for a while (is it sometimes tuff to start the car in the morning?). If oil were sneaking into the cylinder, I think you'd see some smoke, even if it was a puff...But my beater car has been puffing smoke for YEARS and 30,000 miles later the plugs are not foul. Good Luck!
Old Apr 16, 2002 | 11:16 AM
chode1's Avatar
This could be your issue also...
https://www.thirdgen.org/techbb2/sho...hreadid=100505
wigmobile
Feb 26, 2025 02:56 PM
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
Jlanz55
Sep 9, 2015 09:09 AM
89 formula TPI
Sep 7, 2015 11:06 AM
